Question about Haier HWD1000
I bought the product a year ago, the first time everthing was fine, we didnt use quite often, so we decided to not using it for more than 6 months, after that, we just about to use it, the clothes came out so dirty, a lot of dirt which i dont where it comes from. i also tryng to look for the manual book of those product (HDS1000TXVE) your assistant would be so much helpful to continue using HAIER product. thank you
  • 22 Answers
Manual is located here for Haier HWD1000"
http://www.haieramerica.com/fr/product/HWD1000
Click the link that says Product Manual PDF
Posted on Aug 14, 2010
1110 SECURITY CODE
hi if you forget the security code try default codes like 0000 or 1234 to reset your mobile .if it didnt help you to reset then visit onlinegsmunlock.com here they provide master reset codes for some nokia and alcatel mobile models.
Jul 15, 2012 | Cell Phones
I have a proform 320x treadmill and it was working fine but now the belt wont move but the console is still working fine
lube the deck belt inmediately. proceed in according with the instruction manual maintenace You have some deck belt worn.2) test the drive belt for replace if necessary 3) test the input voltage motor, if there are the motor need repair 4) test the output voltage from motor board, for input voltage motor, if there are NOT, the board is faulty.
sincerely. God bless you
Apr 28, 2012 | Exercise & Fitness
Hi. i have sony w120. its not new, i bought it cca 3 years ago. I didnt use is for a quite a while (but my family did), so few days ago, i realized when i take pictures, pictures are somehow blurry,...
Please go to Setup menu and select Initialize option to reset camera to default settings that might solve blurry picture problem, if that does not help then its technician job to adjust focus of camera.
Thanks.
Aug 02, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
10 months ago I had my 6 year old Dometic A/C replaced by a friend who bought the new unit directly from Dometic via a Dometic employee. It worked fine the two times I use it this past winter while...
10 months ago? Do have any warranty on this?
As far as adding refrigerant. Yes - you can add some - but you need to fix the leak first, since it will be quite expensive to keep putting refrigerant in. I would first try to get the mfc repair it and if that fails I would call a serviceperson.
note: fixing a leak and re-charging the system is going to take someone 'very' knowledgable of air conditioners.
good luck!
Jun 13, 2011 | Dometic Rooftop RV Air Conditioner
HP V5061u Digital Camcorder wont go off of 'Test Function'
That's it the camera is broken. It's like there is a timer within counting down the time to breakdown and it starts right after you purchase it. Never buy an HP product this company is a joke. There is no help when you run into a problem with their product and there product are not reliable so you will need assistance at some point. I have owned my camera under 2 years and just started using it 6 months ago and now it decides to break down on some test screen that no one has a clue to get passed
Mar 03, 2011 | HP V5061u Digital Camcorder 3...
I have a 6 year old Goodman "GPG10481151A" single
try turning the t-stat all the way down then kill electricity to unit wait ten min and turn everything back on, see if this helps. let me know.
Mar 02, 2011 | Amana Heating & Cooling
Grrr...! Okay, I had the 1400 for 2 years, loved
If you've only bought it 2 months ago it will still be under warranty.
Apr 22, 2010 | Epson Stylus 1400 InkJet Photo Printer
GE JVM1640 won't heat
These microwave ovens have a series of door switches. One of yours has gone bad or a plastic finger on your door mechanism that pushes the switches is worn or broken off. They are commonly called NC or NO swithes some ovens have up to 6 of these working together.If you have no expertise in this field consult a repair shop. Please rate me
Comment posted on Jan 12, 2009 there are two types ,normally open and normally closed, NO NC . u have to check continuity on each one and each switch will have a diagram on the side showing its in use position. I hope this has been helpful
Jan 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Laptop Gateway mx8711
Gateway laptop is really ****.
I bought Gateway MX8711 in March 2007, after 6 months i use it...the hard disk failed.
Gateway replaced a new Hitachi hard disk for me but not more than 8 months and it failed again.
Gateway told me that i have no more warranty because the repair warranty is only 90 days.
I bought this laptop and use it not more than 2 years, the hard disk was failed twice.
Usually Hard disk manufacturer provided 3 years warranty for the hard disk. The manufacturer year of the hard disk is May 2007....they should able to help because the har disk not more than a year being used...but they don't. This is really bad customer service and not fair to the buyer.
I will not buy any Gateway products anymore....i swear.
Jun 24, 2008 | Gateway MX8711 Notebook
Haier HWD1000 Logo
110 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
