How to used it? - Office Equipment & Supplies
  • 137 Answers
Get a service manal to start with . It will walk you through all the set up.
Posted on Aug 14, 2010
Tip
How to Use 2 Whatsapp Account in Your Phone - Using OGWhatsApp
Use 2 Whatsapp Account in Your Phone Using OGWhatsApp No doubt, WhatsApp is the world's No.1 chat messenger app. today, I will explain you that how can you use 2 WhatsApp account in your phone by using OGWhatsApp . This trick is very simple and easy to use for every android user. It's very popular,...To read more visit - Use 2 Whatsapp Account in Your Phone Using OGWhatsApp
on Mar 14, 2016 | WhatsApp Messenger
Need to rest my password
you can reset your password by using these three options
1. reset your password using alternate email id
2. reset your password using security questions
3. reset your password using your phone number
Jun 25, 2014 | gmail.com
Master reset code for nokia 1202-2 IMEI # 358016/03/449348/0 CODE:0562271
Nokia Mobile Sets Secret Codes
Mobile Set: All Nokia Mobile Sets
Use For: Default Security Code.
Code: 12345
Mobile Set: Nokia Mobiles
Use For: Turn On Enhanced Full Rate Codec.
Code: *3370#
Use For: Turn Off Enhanced Full Rate Codec.
Code: *#3370#
Use For: Turn On Half Rate Codec.
Code: *4720#
Use For: Turn Off Half Rate Codec.
Code: *#4720#
Use For: Show Software Version.
Code: *#0000#
Use For: Also For Show Software Version.
Code: *#9999#
Use For: Show IMEI (International Mobile Equipment Identity).
Code: *#06#
Use For: Show Lock Status of Your Nokia Mobile Set.
Code: #pw+1234567890+1#
Use For: Show Lock Status of Your SIM.
Code: #pw+1234567890+4#
Use For: Show Security Code of Your Mobile Phone.
Code: *#2640#
Use For: Reset Game Score And Timer.
Code: *#73#
Samsung Mobile Sets Secret Codes
Mobile Set: All Samsung Mobile Sets
Code: *#06*
Mobile Set: Samsung 811
Use For: Unlock code / Change roaming code / ID.
Code: 47*869#08#9
Mobile Set: SGH-600 , SGH-2100
Code: *#9999#
Use For: Show Software Version (instructions).
Code: *#0837#
Use For: Show Serial Parameters.
Code: *#0001#
Use For: Activates the smiley when charging.
Code: *#9125#
Use For: Battery status (capacity, voltage, temperature).
Code: *#9998*228#
Use For: Program status.
Code: *#9998*246#
Use For: Change Alarm Buzzer Frequency.
Code: *#9998*289#
Use For: Debug screens.
Code: *#9998*324#
Use For: Watchdog.
Code: *#9998*364#
Use For: EEPROM Error Stack - Use side keys.
Code: *#9998*377#
Use For: Trace Watchdog.
Code: *#9998*427#
Use For: Change LCD contrast - Only with version G60RL01W.
Code: *#9998*523#
Use For: Memory status.
Code: *#9998*636#
Use For: Jig detect.
Code: *#9998*544#
Use For: SIM File Size.
Code: *#9998*746#
Use For: SIM Service Table.
Code: *#9998*77
Jun 03, 2012 | Nokia Cell Phones
Can I use all shelf positions. Which positions are best?
If you are referring to the main oven, all shelf heights can be used. If you are using the rear heating element with the fan, then I would always suggest using the middle shelf.
If you are using top/ bottom or both heating elements instead, then place appropriately i.e. if using top heating element then use middle or lower shelf positions and if using bottom heating element then use middle or top shelf positions
Sep 08, 2011 | Bosch Ovens
Lost owners manuel and need to know what type of engine oil to use for a Husqvarna 25-HP V-Twin Hydrostatic 54" Garden tractor
if engine is briggs use briggs sae 30 oil also change out filter use briggs black std oil filter or yellow filter if els version
if engine is kohler use kohler 10w/ 30 oil and use kohler oil filter
if its honda use 20w/50 oil and use honda oil filter
if its kawasaki use 20w/50 and use kawasaki oil filter
cheers pauly 46
Mar 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I need a fuse diagram for my 2003 ford ranger 2.3L engine
I don't know if this will help you but here are the location numbers. Can't figure out how to copy a picture of the box itself. I do have an entire owners manual I could send you as a PDF if you need it. Hope this helps. Good luck.
Description
1 50A** I/P fuse panel 2 - Not used
3 - Not used 4 - Not used
5 - Not used 6 50A** Anti-lock Brake System (ABS)
pump motor
7 30A* Powertrain Control Module (PCM)
8 20A* Power door locks, Remote entry
9 - Not used 10 - Not used
11 50A** Starter relay, Ignition switch
13 20A* 4x4 Motor 14 - Not used
15 - Not used 16 40A** Blower motor
17 20A** Auxiliary cooling fan 18 - Not used
19 - Not used 20 - Not used
21 10A* PCM memory 22 - Not used
23 20A* Fuel pump motor 24 30A* Headlamps
25 10A* A/C clutch solenoid 26 - Not used
27 - Not used 28 30A* ABS module
29 - Not used 30 15A* Trailer tow
31 20A* Foglamps, Daytime Running Lamps (DRL)
32 - Not used 33 15A* Park Lamp
34, 35, 35, 35 & 37 Not used 38 10A* Left headlamp low beam
39 & 40 Not used 41 20A* Heated oxygen sensors
Jan 28, 2011 | 2003 Ford Ranger Regular Cab
What type of oil to use when changing oil
For any four cycle engine (engines with separate oil and fuel fill locations) use high quality detergents in the following viscosity.
For Briggs & Stratton engines use an SAE30 oil above 40 degrees F (4 C) and below this temperature use 5W-30.
For Tecumseh engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30.
For Kohler L-Head engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30. For Kohler Overhead Valve engines use a 10W-30 above 0 degree F (-18 C), and below this temperature use a 5W-30.
For Honda engines,10W-30 is recommended for general use, and above 55 degrees F (10 C) you can use an SAE 30.
For MTD Brand engines, SAE 10W-30 is recommended for general, all-temperature use.
(From the MTD answer pages). Best regards, --W/D-- Please feel free to rate my solution. Thanx.
Jul 25, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Can you use synthetic oil in a 7hp Techumsen engin?
yes you can use synthetic oil. Use any brand you want.
for summer use use 30w
in winter (if you use for snow blowing) use 5w30.
Dec 21, 2008 | Ariens Garden
14 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
