Question about Brother HL 5150D Laser Printer
Strange Error Messages from my printer
I have the Brother 5150 printer for a Mac (Mac mini). When I try to print stuff, I get a mostly blank paper output with just a small block of letters saying "ERROR NAME; limitcheck COMMAND; image OPERAND STACK; --savetype--
    Genius:
  • 1,447 Answers
Which mac version are you using? intel or powerpc? are you running the leopard or the tiger? were you able to add the driver for your printer?
Posted on Apr 26, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 26, 2008
    If you are using 10.4 and connected via USB cable
    1. Switch off and unplug the product from the AC outlet and disconnect
      it from your Macintosh if you already connected an interface cable.
    2. Turn on your Macintosh.
    3. Connect the USB interface cable to your Macintosh, and then connect it to the product.
      Note:
      Do not connect the product to a USB port on a keyboard or a non powered USB hub.
    4. Open the "Printer Setup Utility". "Printer Setup Utility" can be found in /Applications/Utilities.
    5. Click Add Printer...
    6. Select "Default Browser".
    7. Select your machine.
    8. Select "Brother" from the "Print Using" list.
    9. Select your printer model's BR-Script driver from "Model" list. The name of BR-Script driver is "model name + BR-Script 3".
    10. Click Add. The printer will be available from the "Printer List".
    11. Select Quit from the menu.
    Applicable to ppc mac and intel core duo on tiger and leopard
    First open up printer setup utility and higlight present driver and delete it
    then
      Note:
    4. Open the "Printer Setup Utility". The "Printer Setup Utility" can be found in /Applications/Utilities.
    9. Select your printer model's CUPS driver from "Model" list.
    10. The name of CUPS driver is "model name + CUPS v1.1". Click Add. The printer will be available from the "Printer List".
    12. The setup is now complete.
    If that doesnt work download a compatible driver on this Link: Click here DRIVERS
    President:
  • 2,712 Answers
Hello Skinny Joe,
It could be a driver issue. If you are using OSX10.3 (Panther),
please update your Mac driver following the instructions below:
  1. Delete the printer name from the printer list.
  2. Click here and download the new driver.
  3. Once downloaded, double click on the file. The Installer Disk Image is mounted on your Desktop. You will find the icon BrotherXXXX.pkg on the desktop.
  4. Double-click the icon.
  5. Follow the instructions.
For USB Users:
  1. Switch off and unplug the product from the AC outlet and disconnect it from your Macintosh if you already connected an interface cable.
  3. Connect the USB interface cable to your Macintosh, and then connect it to the product. (Note: Do not connect the product to a USB port on a keyboard or a non powered USB hub. )
  4. Open the ”Printer Setup Utility”. The “Printer Setup Utility” can be found in /Applications/Utilities.
  6. Select "USB".
  8. Select "Brother" from the "Printer Model" list.
  9. Select your printer model's CUPS driver from "Model Name" list.
    The name of CUPS driver is "model name + CUPS.gz".
For Network Users:
  3. Connect the network interface cable to the product, and then connect it to a free port on your hub.
  4. Turn on the product by plugging in the power cord. Turn the power switch on.
  5. Open the ”Printer Setup Utility”. The “Printer Setup Utility” can be found in /Applications/Utilities.
  6. Click Add Printer…
  7. Select "IP Printing".
  8. Select "LPD/LPR" from the "Printer Type" list.
  9. Enter the TCP/IP Address(or DNS Name) of the printer into the "Printer Address" box.
  10. Select "Brother" from the "Printer Model" list.
  11. Select your printer model's CUPS driver from "Model Name" list.
  12. Click Add. The printer will be available from the "Printer List".
  13. Select Quit from the menu.
  14. The setup is now complete.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
How do i get to print my web stuff coz my brother MF-J470DW is sending blank papers without prints
If you machine prints other things without problem, then you should be more specific about what web stuff you are trying to print. Often web based images are in frames or links, and these can be very difficult to access or print. You may need to download or screen-dump the content before trying to print it.
Dec 02, 2014 | Brother MFC-J470DW Inkjet All-In-One...
MFC465CN-PAPER JAM- NONE IN MACH.CANT USE
Sir/Madam
MAKE SURE YOUR BROTHER MACHINE IS THE DEFAULT PRINTER
If the printer driver is not set as "default printer", you can not print. Make sure your Brother machine is set as default printer. If your brother machine is not set as default printer, set it as default printer.
  1. Click Apple Menu and choose System preferences..., click Print & Fax, Print & Scan or Printers & Scanners.
  2. Choose from pull down menu of "default printer".
DELETE ALL PRINTER JOBS
  1. Click Apple Menu and choose System preferences....
2 Click Print & Fax, Print & Scan or Printers & Scanners.
For Mac OS X 10.5 - 10.7 users
Choose the print job (1) and click Delete (2).
CHECK THE PRINTER STATUS
Choose brother machine's icon and click "Open Print Queue..." then check the printer status.
The Resume or Resume printer icon which is surrounded by red lines is displayed in printing when the printer is out of paper or the printer is turned off and on. Click Resume or Resume printer.
For Mac OS X 10.8 or later users
If you connect the brother printer via USB cable, the error message The printer is not connected or Offline is displayed on Print Queue when the USB cable is disconnected or the brother printer is turned off. Connect the USB cable and turn the brother machine on.
If the other error message is displayed on Print Queue, check if the LCD display or LED indication of your Brother machine is not showing some error. If an error is displayed, go to the Troubleshooting section and find a solution.
REGISTER THE PRINTER ICON AGAIN
  1. Choose your printer icon.
  2. Click [-] button to delete the printer icon.
  1. Click [+] button to register the printer icon again.
In spite of if you click [+] button, the brother machine is not displayed, then the brother machine is not recognized.
If you use the printer via USB connection, reconnect the USB cable or restart the Macintosh or your brother machine.
For Mac OS X 10.4 users
I Suggest You Go To Official Brother Printer Website For Brother Printer Troubleshoot:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000046/faq002646_001.html?reg=us&c=us&lang=en&prod=mfc5860cn_all
Or
If You still having Problem Then Follow Us For Brother Printer Support
Jan 23, 2014 | Brother MFC 420CN All-In-One InkJet...
Brother mfc-8480dn no paper error I have a new brother laser printer and it is telling me there is "No Paper" but the paper tray has paper. I have tried removing the paper and reloading the tray...
Open the file you are trying to print, go to "file", "page setup", "Paper" and choose "Default tray" under paper source. It may give you an error message that the margins are outside of the paper. Click on "Fix this", then you can print. I had the same problem.
Jan 12, 2011 | Brother MFC-8860DN Printer
I have a Brother MFC 240C printer that will not print black ink. I just changed all the cartridges. All the other cartridges print. I ran the clean cycle many times. No error messages just blank paper.
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 17, 2010 | Brother MFC 240C All-In-One InkJet Printer
Unable to carry out print command
Issue : Desk jet 5150 Not printing
Environment :
OS - Not provided
Printer : Deskjet 5150
Solution :
There could be 2 reasons for your problem
check the following links
Solution 1 fig are available
Step 1: Press the Resume button
Press the Resume button. Wait for approximately one minute and then print a self-test by pressing and holding the Power button and pressing the Resume button four times. Release the Power button. The self-test page should print. If the carriage is still stuck, go to the next step.
Step 2: Power cycle the printer
Turn the power off and back on, following these instructions:
1. Turn off the printer by pressing and releasing the Power button. If it will not turn off, proceed to Step 3. If it does turn off, proceed to the next step.
2. Turn on the printer.
3. If the Power light is on steady, print a self test with the instructions above in Step 1.
Step 3: Clear the paper path
Reset the printer and clear the paper path of any paper that may be jammed in it, using the following instructions:
1. Leave the printer turned on and disconnect the power cable and the USB or parallel cable from the back of the printer. Do not reconnect them until instructed later.
2. Remove the paper from the in-tray.
3. Remove the rear access door or duplexer (if installed) from the back of the printer.
Figure 4: Removing the rear access door
4. Open the top cover of the printer.
5. Check for and remove any paper still in the printer. A paper jam could cause the error message and the carriage stall.
6. Replace the rear access door, close the top cover, and replace the paper in the in-tray.
7. Reconnect only the power cable. If the printer does not automatically turn on, turn it on with the Power button.
NOTE: The printer may go through a warm-up period of up to two minutes. Lights may flash and the carriage may move. Wait until this warm-up period is complete before going to the next step.
8. If the Power light is on steady, do an internal test as described in Step 1 above.
If the carriage is still in a stalled position, contact HP Technical support to have the printer serviced.
IntroductionWhen printing with a HP Deskjet printer on Windows XP, the user may get the following error messages:
  • Error with USB
  • Out of paper message
  • Error lost communication with printer
  • Any other error messages related to communication.
The following performance failures could also be observed:
  • Partial page is printed, then ejects incomplete.
  • Blank page is ejected with nothing printed on it.
InstructionsThe error may be either a hardware or software issue. Firstly, make sure that all connections between the printer and PC are secure. Secondly, check if the printer can perform an internal test. Once the internal test has been printed properly, follow the instructions below to install a generic printer driver to know if HP printer driver is working fine:
  1. Click Start , Control Panel and Printers and Other Hardware .
  2. Click View installed printers or faxes .
  3. Highlight the printer to be removed.
  4. Click File and Delete .
  5. Click Yes when the deletion confirmation screen appears.
  6. Click File , Server and Properties .
  7. Click on the Drivers tab, highlight the printer to be removed and click Remove .
  8. Click Yes when asked to confirm deletion.
  9. In the printer folder , click on the Add a Printer task.
  10. Click Next and then, the Add New Hardware Wizard screen appears.
  11. Click Next on the Local or Network Printer screen.
  12. Click Next on the New Printer Detection screen.
  13. Click on the down pointing arrow next to Use the following port box and select USB001 or USB002 (virtual printer port for USB) and click Next .
  14. Under Manufacturer option, please select HP .
  15. Select the appropriate printer and click Next .
  16. Select Yes when asked Do you what to use this printer as the default printer? and click Next .
  17. Select Do not share this printer and click Next .
  18. Select Yes or No when asked Do you want to print a test page? and click Next .
  19. Then, click Finish .
  20. Try printing.
Jan 03, 2010 | HP DeskJet 5150 InkJet Printer
Error 0502 on lexmark 5150
does it happen when you want to print? when you want to print u must choose the long way, then select ure printer on the screen (windows office) and print with that, it can be that someone else used your printer,, and changed the options
Mar 21, 2009 | Lexmark X5150 All-In-One InkJet Printer
Printer won't print
Don't have a solution...only a problem. I compose a document with "Word" on my Mac OS X 10.4.11 and hit print, but my HP Deskjet 5150 spits out a  blank (on preview the document is also blank). Where do I go from here (on occasion, it does print out download material).
Andy revolutionary.net
Jun 26, 2008 | HP DeskJet 5150 InkJet Printer
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Not printing from mac computer
Usually trash on the page (hearts and shapes) indicates an incompatible driver. Verify you have the correct driver installed.
Aug 25, 2007 | Brother HL 1440 Laser Printer
Brother HL 5150D Laser Printer Logo
185 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
