Question about Tools & Hardware - Others
How do I oil a paslode nail gun - Tools & Hardware - Others
  • 2,176 Answers
Depending on the model, the general rule is to put "6" drops of air tool oil into the fitting at the beginning of the work day and when you get back from lunch put another "6" into the fitting. Do not use anything like 3in1 oil. Make sure a good quality air tool oil
Posted on Aug 15, 2010
  • 700 Answers
Just put oiler somwhere in line between compressor and gun, this should be sufficient. another method is to put single drop of oil into air intake every hour or two - depending on workload, i use oiler. but sometime when this is not feasible, i just put drop or two of oil into air intake on the beginning of the job and maybe another one on midday.
Posted on Aug 04, 2010
4 Suggested Answers
jj505
  • 195 Answers
SOURCE: i have paslode finishing nail gun , i cleaned it, not working now
The smoking is normal for a few times after cleaning ,but you might have put to much oil drops in chamber and piston chamber is getting a "vapor lock". Try recleaning with degreaser. Also have you forgotten to set the depth gauge at front of nose.
Please Rate jj505 Thanks
Posted on Apr 09, 2009
  • 128 Answers
SOURCE: Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Posted on Feb 19, 2010
  • 67 Answers
SOURCE: Paslode finishing nail gun won't fire? Battery is
Give it a thorough cleaning.. if it still does not fire you might have to replace the spark plug.
Posted on Sep 13, 2010
I am using senco gas in a paslode 2nd fixing nail gun. Is the senco gas 'bad for' my gun in any way as i am having a few firing problems
You can use most gases in your gun, but paslode is the best that's why its more expensive. Try warming the gases in your pocket that sometimes helps.
Dec 17, 2014 | RTO Paslode 902000 IM250 Ii Cordless 16...
What type of lube oil for my hitachi brad nailer
Needs very little oil, just few drops of sewing machine oil or nail gun oil sold at lowes or home depot. Purchase smallest size bottle of Paslode or bostitch nail gun oil (most likely they will not have hitachi oil). Do not by air tool oil as this oil is for air powered impact etc. Good luck
Aug 03, 2013 | Hitachi Air Tools & Compressors
Paslode framing nailer: compressor powered, hisses but will not shoot nails, appears to be in the sliding mechanizism that touches the wood first before it will shoot, help
I've used paslode for years and whenever there was a "hiss" of air and no fire- it was o-rings- When were the o-rings changed last? And how do you know they are in 'good shape'? You can't tell by just looking at them. If that isn't the problem then I can't help. Just as an aside- do you oil the gun (down the air intake nipple) every time you use it? Lack of oil will wear out o-rings fast. Sorry if this isn't overly helpfull but most gun problems are o-ring or seal related unless you've worn out or damaged a mechanical part.
Feb 10, 2013 | Air Tools & Compressors
Where do you oil this airless nail gun
Oil can be added through the back cap, remove your air filter first though....
Dec 06, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Gun is only a few yrs old and has had moderate use. Problem is that when depressing the nose piece I get a hissing of air and it will not fire. It will sometimes fire but after a few nails it just hisses...
Your o-rings are wore out. Paslode makes(made) a Tool Repair Kit, PN219235 and Trigger Valve Kit, PN219224 for your gun. Always use all of the o-rings in the kit and liberally lubricate them before installing them using grease in the kit or nail gun oil. If the kits are no longer available you'll have to get a breakdown of the gun, (www.paslode.com/uploadedFiles/PowerMaster_Plus_Parts_Diagram_Schematics.pdf) and order all of the o-rings. Be very carefull to put everythng back together properly, you are working with a gun.
Aug 31, 2010 | NRS Paslode 501000 Powermaster Plus...
My paslode f 16 nail gun wont fire nails,new gas. it actually fires but nails wo nt eject.
i found this happening to me and i oiled (light oil like 3 in 1) the driver (hammer) in the tip. that way it could retract and drive the next brad.
Jul 30, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
My paslode nail gun needs to be cleaned
Use the Paslode cleaning spray (Lowes and home depot stock this)
Detailed instructions can be downloaded from the paslode site. http://www.paslode.com/owners-manuals.html
Jun 24, 2009 | RTO Paslode #650027 2500CT Placement Nail
Paslode nail gun not firing
Yes you need to oil driver blade piston.
You need to check for spark. With no nail or gas in it. Take of main cylinder(4bolts on top, 2 bolts on nose. And then put in battery. And then push upper switch(behind roller at top) and the fan will come on. And then pull the trigger. You should have spark.
Thanks,
Jeff
May 16, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Tools & Hardware - Others Logo
244 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
