Question about Garden
Petrol Strimmer original manufacturer Dynamac make DB30L. I need a part for the strimmer head.
SOURCE: spear and jackson petrol strimmer
thread the cutting wire
Posted on Apr 10, 2011
1joester2
  • 74 Answers
SOURCE: What petrol/oil mix should be used in a McCulloch
The specified ratio is 40:1
40 parts gas, 1 part oil.
Posted on Jul 09, 2009
  • 148 Answers
SOURCE: RLT30HT 30CC PETROL STRIMMER difficult to start
The plug that I have in my 720r is a Champion RDJ7Y. Can I suggest that you pull the old plug out and look to see which one you have? Also when you buy the new replacement it should already be gapped for what you need.
Posted on Jul 28, 2009
  • 7 Answers
SOURCE: how to sort broken pull cord on petrol strimmer
Hi Baz, i will tell you a generic way of doing this as i don't know the model of your strimmer.
on the pull cord housing you will have 3 or 4 screws to secure the housing to the motor body, undo these. the housing will lift away from the main motor body, underneath this cover you will see a spring canister, there may be a screw or clip keeping this in place or some are just secured with the outcover. remove this canister you should see a coil spring in the middle and a groove around the outside where the cord goes. you should see a knot inside the cord grove where the cord is threaded through to secure, remove thisand remove old cord. Now the trickky bit! some times it helps to have a helping had, you will need to turn the coil spring so it tights up to its full tightness, then thread the new cord into the secureing hole where the old cord was located, then when you release the spring this will coil the cord round the cord groove. replace the pull handle on the end of the cord so there is no slack and replace on to motor in reverse order. Hope this helps.
Posted on Sep 04, 2009
  • 8 Answers
SOURCE: strimmer cord keeps breaking
the eyelets on the trimmer head may be worn and cutting the line ..look for groves in the eyeleys may need to replace the spool
Posted on Sep 13, 2009
Champion strimmer 25 cc cord
its a pdf
Champion Strimmer Manual - 64.140.158.30
64.140.158.30/champion/champion-strimmer-manual.pdfhomelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s ... kimmel manual kawasaki petrol strimmer tg24 manual ' champion ...
Jul 17, 2016 | Garden
What is the fuel mix for a dynamic DB30L strimmer
It is probably almost100 % 60Hz at 110V
Aug 29, 2014 | Computers & Internet
How to load new cutting line onto a McCulloch Strimmer TM250
You can probably find a Youtube demonstration video.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Jul 16, 2014 | McCulloch 41201-33 Line Head, Models...
Mcculloch petrol strimmer
Agnes take of the cutting head again and see if it runs at full speed without it. If it does you have either put the head on too tight or it's the wrong head.
May 11, 2014 | Garden
Purchased a gardentec petrol strimmer a while back from netto store...where can i get a spool replacment to fit my strimmer.
try Lowes or any Agway, and if that dowsn't work, try checking on line with your type of trimmer.
Apr 22, 2012 | Garden
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
I am after a manual for my Spear and Jackson Petrol Strimmer
You can download this from www.isc-gmbh.info/download/prod/21424791/3401760_01018_SPK1.pdf. The model is actually a rebadged Einhell BG-BC 30/1
Nov 15, 2009 | Garden
Petrol strimmer good spark but wont start
if it ran fine then it quit it is more likely the pick up tube in the fuel tank
Sep 14, 2009 | Garden
Strimmer cord keeps breaking
Sep 01, 2009 | Garden
Garden Logo
777 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
