Question about Refrigerators
Ice Maker problem
I have a Kenmore Sidexside (57542). The Icemaker makes hollow Ice shells and or gets stuck in rotaton by Ice build up onthe fingers. My water dispenser on the door just recently began to work only sporadically!
Side-by-side 57542 icemaker not working . Cold water is.
Posted on Sep 08, 2010
    Genius:
  • 1,073 Answers
Check if it has one the filter, hollow ice = lack of water flow into the icemaker
Posted on Apr 26, 2008
Icemaker not making ice
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 13, 2010 | Kenmore Refrigerators
Icemaker is making ice but it will not drop into container
Ice maker has built in heater to thraw ice alittle so the finger scooper lifts up ice and out. Be sure the ice cubes are not stuck in between fingers cause that will jam it. if you dont see any jam then replace ice maker
Mar 28, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Kenmore icemaker
It sounds like the icemaker is making hollow cubes , and the unfrozen water in the cubes , after dumping , freezes and causes the ice shells to stick togather . This is a sign of " not enough water going into the icemaker " . Replace the water inlet valve , behind the refrig , the piece the wall water line connects to , on the refrig .
Oct 06, 2009 | Kenmore 57029 Side by Side Refrigerator
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Icemaker Arm stuck in up position
Hi, Check and see if the finger sweep has ice jamming it so that it can't finish it's rotation. This is a come problem. You might have to remove the ice maker to see what is blocking it. Usually two screws on top and one underneath the ice maker.
Please let me know if i can assist you further.
Vic
May 27, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice maker is not putting out ice GE
Low water pressure usually the cause of that, just like when you get hollow ice cubes as explained here:
http://www.applianceaid.com/icemaker.html#hollow (http://www.applianceaid.com/icemaker.html#hollow)
Jul 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Roper top freezer ice maker out of sync? Too warm?
sorry you must replace the icemaker.
Mar 30, 2008 | Refrigerators
Kenmore side by side - icemaker seems to run too fast because the ice cubes are often hollow and they stick together in large clumps. Everything else in the freezer is frozen solid, so I know the freezer...
IF FREEZER IS A THE CORRECT TEMP/ O-10 DEGREES, THE FREEZER IS NOT THE PROBLEM. THERE IS A THERMOSTAT IN YOUR ICE MAKER, IT IS NOT ADJUSTABLE. IT IS A SMALL BI METAL SWITCH THAT TRIGERS ICE MAKER WHEN IT REACHES ITS PROPER TEMP. THE PROBLEM IS, IT IS TRIGERING IT AT TO LOW OF A TEMP.NOT ALLOWING THE ICE TO FREEZE SOLID. IF YOU CAN HANDLE IT CHANGE BIMETAL SWITCH OR CHANGE ICE MAKER ITSELF.
HOPE WE HELPED YOURS TRULY FXIT
Feb 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
268 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
