My Haier HWR05XCJ window unit sports an E2 error. What does this mean and how do I fix it?
  • jamyerayne Aug 04, 2010
    E2 error code on my Haier room AC unit....I get that the pump may be clogged. Turning it on it's side to get to the pump etc. Does this mean I have to take the metal hosuing off the unit? And do I find the pump on the units right side or left? (if I'm facing the controls)
    Any other details would be helpful. I don't want to ruin it my taking apart things I shouldn't.
    President:
  • 4,070 Answers
Hi! Please click on the link to download the HAIER HWRO5XCJ USER MANUAL. From here you can learn about the unit and decide on the fix. Hope this helps and have a good one! Please click here http://homeappliance.manualsonline.com/manuals/mfg/haier/hwr05xcj.html
Posted on Aug 04, 2010
  • 857 Answers
Hi You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump.
    If I am facing the front of the unit (where the display is) do I lay it on it's right side or it's left to do this?
    And how do I get to the pump? Take off the metal cover or what?
I am using a Haier HWR05XCJ, and the unit will do nothing but display "E0" when plugged in. Not even the power button responds outside a couple of beeps. Filter's clean, so I'm unsure...
As you have probably discovered, Haier for whatever reason, doesn't list any of the Error Codes in your Owner's Manual. To find out what "EO" means and the solution for it, you must contact Haier Customer Support 1-877-337-3639.
Hope this helped you and thanks for choosing FixYa.
Aug 24, 2011 | Heating & Cooling
Dehumidifier not turning on showing an e2 code
Lisa, unfortunately, Haier for whatever reason does not list what error codes mean, in their Owners Manual. You will have to contact Haier Customer Support 1-877-337-3639 for that.
In the meantime, turn the ON/OFF Switch to OFF and unplug the unit for 15 minutes. Then, plug the unit back in and turn the ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the electronics reset and reverted back to the original factory settings. If they did, you can set the controls as you like.
Hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Haier 45-Pint Dehumidifier
Haier dehumidifier model de45ej-t What does code e2 mean? Unit does not run.
Dehumidifier (DE45EJ-L) shows only E2 on the display -- no "buttons" work. Had been working perfectly -- we turned it off a few days ago. Any suggestions??
Jan 09, 2011 | Haier DE45EAL Dehumidifier
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Jun 30, 2010 | Haier HD451E Dehumidifier
My Haier clothes dryer (HDY-C70-F) spins but doesn't heat, then displays an ''E2'' error. Could it be a simple fix I can do myself?
Guess the answer is too late for you, but for others:
E2 means that the heating element is broken. You can buy a new heating element and replace it. Unscrew the backpanel and you see an aluminium block which looks like a radiator. Replace this by the new element and you are ready to go.
Don't know what the price is though.
Nov 25, 2009 | Haier Dryers
E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Jun 13, 2009 | Haier Mechanical Air Conditioner HWF05XC7
Power cuts off
The machine beeps E2 all the time. Actually E2 error code means washer door is not closed properly. However washer door does close properly, but the machine still beeps with showing E2 error code. Please help solve this problem.
Many thanks,
Robert
Jul 04, 2008 | Haier XQB60-91AF Top Load Washer
Haier HWM5TL E2
I looked at the Haier website and all other usual sources but could find nothing. I think you should e-mail service@haier.com.au with the same query. Good luck
Sep 30, 2007 | Washing Machines
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
