Question about LG GMA-4020B Super-Multi DVD-RAM/R/RW&CD-R/RW Writer, Original Retail (DVDRRW4020B) Burner
I have a LG DVD Writer. After pressing eject button the light blinks, means that it is receving proper power. But after inserting any CD/DVD the drive is unable to read its contents. What exactly the problem be??
  • 212 Answers
How much is the lifetime?maybe the lens need to cleaning.try another CD/DVDs .
Posted on Aug 11, 2010
Lightscribe dvd drive won't work. the eject command does not make it open either. seems to be jammed. if i break it down can it be "unjammed" without ruining it?
Actually it's probaly just got some dust or something in it. What you do to manually open it is take a needle, thumb tack, or safety pin and simply insert it into the tiny hole above the eject button on the dvd drive itself. You'll feel the tip of the button when you push the pin into the hole then it will pop the door and the drive will open properly. This has gone on for cd/dvd drives for years. Usually just the cause of dust or what have you being stuck in the mechanism.
Jul 01, 2013 | Computers & Internet
My LG DVD Writer is not reading any disk when i am inserting the disk in Drive. IT stops blinking also.
Hello Ammit,
It seems that the lens of the DVD writer is not working properly. Please try to clean the lens of the DVD writer with help of CD/DVD lens cleaner disc. The lens cleaner disc is easily available in market. After cleaning the lens try to run the CD/DVD again
May 08, 2011 | LG (GSA-H42NK) Burner
CONNECTED TO WINDOWS XP PC BUT NOT SHOWING IN WINDOWS EXPLORER. IF I TRY TO VIEW CD OR DVD I CANNOT FIND THE DVD ICON ON THE PC AT REMOVABLE DEVICES
make sure that the IDE/SATA Cale that you are usin is workin properly and also make sure that the power cable from the powersupply is workin..while restartin you can press the eject button to see if there will be a Green liht to check if there is a power on the DVD..
3 thinGs to check:
*sata/ide cable
*Power cable from the PSU
*DVD writer if all cables are workin try to connect the dvd writer to a diff computer to check if it is faulty
Jul 24, 2010 | Samsung SpeedPlus DVD-Writer 20x, Black ...
MY CD ROM DOES NOT EJECT EVEN CAN'T BE SEEN IN MY COMPUTER AS WELL. WHAT STEP SHOULD I TAKE?
that means power connections to the CD rom is not proper, check it out. if you find the problem again the CD drive might be damaged
Apr 20, 2010 | HP 530i (Q6750A) DVD±RW Dual Layer...
My LG writer only opens with the manual open by inserting paperclip in the pin hole...doesnt eject thru MyComputer too...
Hi, the problem is tape cable inside the writer , replace the tape which in LG Writer. (better to take to service center)
Apr 17, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
LG CD-ROM not ejecting the tray
you need a pin..ir a small object...
do you see the small hole in the front of the cd rom??/you need to hit it so that it will open...
try it first...
hope i've help you.. rate me,..
Feb 06, 2010 | Computers & Internet
Dvd writer/cd writer will not eject the cd
Look at the drive where you normally eject the disk you will see a pinhole near the button now get a needle or a pin and insert it inside the hole and push slightly and this will eject your disk. You can also open My Computer and right click your dvd drive and select eject.
Dec 30, 2009 | HP Pavilion a620n (PC028A) PC Desktop
My LG multi dvd writer lightscribe tray wont open. the green light is steady. no matter how many times i try to eject the tray ang it wont open. there is dvd+r inside.
use a unfolded paperclip and insert it into a small hole below the disc tray. This is the manual eject port. Stick it straight in and push, a little bit of pressure will be needed.
Apr 20, 2009 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
My LG CD Writer ejects automatically without any operations...
This is normally as sign that the writer is faulty, especially if ejecting on your pc's start up. Just go through this first to check if it's just a driver fault. Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers
Apr 02, 2007 | LG GMA-4020B Super-Multi...
Computers & Internet Logo
101 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
