Question about Kitchen Ranges
The Lamp of Olympus Light Source ILH-2A Light Source is blown. What is Part no. of this Lamp? Is there any alternate Lamp? Please confirm its availability with price. From: A. Dasgupta Alliance Air, India. dasgupta.a1@gmail.com
jon_than21
  • 30 Answers
SOURCE: My sharp AL-1217 greets me with a flashing "L1" error
try to clean the scanner glass, it has a white stripe at the home position of the scanner optics, clean it well.
Posted on Jul 28, 2008
  • 9 Answers
SOURCE: I had a Compaq presario c765tu laptop.There was a
reinstall driver for sound card
try different headphones
Posted on Apr 30, 2009
  • 8457 Answers
SOURCE: i need new lens to install in tt 1620
Not worth the money u can buy a basic dvd player very cheap.May not even sell this part,because very cheap video digital device.
Posted on Aug 24, 2009
  • 10 Answers
SOURCE: I require a new blower fan for Ryobi Model
If you are in the uk then go to a company called firth powerfix in leeds. They use to do ryobi spares.
Posted on Jan 02, 2010
aka_jazmat
  • 276 Answers
SOURCE: It seems that my yahoo account has been hacked and
what you will do is to change your password and keep protected from any one.so it will happen again.
Posted on Jul 10, 2010
98 ford explore just put a new alternator in .I got power from yellow wire but not the green wire .green is ground rite
green/red is the charge lamp circuit. when grounded it should turn the light on,if it doesnt, you may have a blown fuse. the lamp circuit provides the "turn on" signal to the alternator as a positive voltage. the voltage regulator is a gounded load until the alt starts charging, than it puts out a positive voltage to turn out the light.
Nov 08, 2014 | Ford Cars & Trucks
The green light blink for a while and then shuts off and the lamp light blinks once red???
The green blinking lamp means that the TV is getting ready to start the lamp, and then one red LAMP blink means the lamp will not start. You may need a new lamp (Part TYLA1001.)
If a tech confirms this, and you can source the part, you can find TYLA1001 installation instructions here to save a few dollars, and PT-52LCX66 lamp timer reset steps here.
I hope that helps.
Mar 20, 2010 | Panasonic PT-52LCX66 Projection Television
2003 kia optima battery light came on and headlights went dim and then out but high beams still work, dash lights are dim and the car still runs.
The alternator has stopped charging for some reason.
First check alternator drive belt is ok;
Check dash 'battery' (or 'ALT') light illuminates when ignition on and motor not running- if not, check 'ALT' lamp is not blown and connections to alternator are ok;
If all above ok, the alternator may be faulty.
Jan 16, 2010 | 2003 Kia Optima
Battery light glows faintly even when ignition is off
You have a diode blown in the alternator,unplug it to confirm.If the light is out when the alternator is unplugged then that is where your problem lies.
Nov 24, 2009 | 2000 Jaguar S-Type
I replaced blown fuse with AUSTRALUX DA205-2A 2A 250V fuse for my Vox AC30cc2x. It blew after a couple of minutes in warmup mode. Have I used the correct fuse?
It's drawing too much current, make sure you install the excact replacement or an alternative approved replacement. Other than that, if it's still blowing the fuse than theres an overcurrent condition in the system...meaning a short.
Nov 21, 2009 | Audio Players & Recorders
Altenator issues i think ???
should have a fuse for the alternator, most likely blown. If the fuses are not labeled, use a test light to find out which one is bad and replace it. Possibly could have a bad fusible link instead of fuse with the age of the car.
Jun 02, 2009 | 1983 Lincoln Mark VI
Alternating power and lamp status lights
...replace the lamp. The lamp is most likely WAYYYYY past its prime so I suggest starting there. Sometimes even if you had just replaced the lamp the new lamp could've blown. When there is no signal running through the lamp circuit there is no signal to the display sensor, which means no image.
hope this helps!
Jan 28, 2009 | Mitsubishi XD300U Multimedia Projector
Lighting problem with Olympus E 500
It sounds like it may be a broken shutter.
Mar 16, 2008 | Olympus EVOLT E-500 Digital Camera
Turns on, sound comes out, turns off, no picture
You have a short in the tv.
I would recommend calling a repair man.
You may be able to find someone at this website.
Jul 30, 2007 | Toshiba 50HM66 52" Television
Kitchen Ranges Logo
135 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
