Question about SmartPool PoolEye In-Ground Pool Alarm with Remote and Temp
I have a Pool Eye PE23 and the instructions don't show how to install it on an above ground pool. Do I put it on the railing as I haven't got a deck for the pool?
  • 640 Answers
This particular pool alarm is made for an inground pool. As far as I am aware, you cannot use in on an above ground pool. You will need a pool alarm that is designed for an above ground pool.
Posted on Aug 12, 2010
How can we take it apart after we drained the pool?
Question:
How do I properly remove my above ground pool?
Answer: by Osko Pool n Spa Onground Pool Removal Guide
Recently, a reader of one of my other articles asked the question;
" How do you take down an above ground swimming pool to move it? I can't seem to find anything to help me. I read your article on replacing a liner but I need to know how to move the entire pool".
Well, (I thought to my self), this is a very good question. So, here is a basic step-by-step guide on the basic proceedure: ( You'll need at least three people, to help with your wall).
1) Drain all water out of pool using a sump pump.
2) Remove skimmers, returns, lights etc.
3) Remove old liner, (use a razor knife and cut into manageable folded pieces). You'll need a new liner if your going to reinstall the pool.
4) Remove Top Seat Ledge covers
5) Remove Top Seat Ledges.
6) Remove Top Rail and Joiner Plates.
7) Locate Wall Bolt Joint on the Pool Wall and remove the corresponding Upright.
8) Now, get some help and remove all Wall Bolts and associated hardware.
9) Next, start pulling the wall out of the bottom rail (track). And roll the wall up as you remove it from the bottom rail. When finished, duct tape the wall so it does not unroll.
10) Pull the uprights, bottom rail and bottom rail joiner plates out of the ground in sections.
11) Remove uprights from bottom joiner plates.
12) Make sure to separate all components and save all hardware!
That's it!
Hope this helps!
Apr 09, 2016 | Intex 32 x 16 x 52" Ultra Frame...
How do you shock a saltwater system above ground pool
shock with chlorine until chlorine shows as free then let chlorinator take over or use non chlorine shock but that will lower your PH keep and eye on it
Nov 05, 2013 | Intex Automatic Salt Water System for ...
How much salt do you put in a 22,000gal. pool?
WOW... You have a huge above ground pool! Are you planning to use the Intex chlorinator to chlorinate your 22,000 gallon pool??? If you are, take a look at the max gallon rating and how long you may need to run... Here's a chart that should help you determine how much salt to add... After adding the salt, run the pump for 24 hrs without the chlorinator to properly dissolve the salt... Don't be surprised if you need to add above 500 lbs!!!
Good luck and hope this works for you...
Aug 22, 2011 | Intex Automatic Salt Water System for ...
We change our pool that we have had for 10 years over to the intex salt system. 4ft X 24 ft round above ground pool. 13500 gla water. We put in 10- 40lb bas of pool salt and have ran the system for the 12...
The pool is green because you didn't take the metal out of the water first. It is too late now to do that ... you will just have to let the filter grab it. It may trake several days. Run the filter 24/7 for those couple days for best results.
Next time you fill your pool ... get a sequestering agent to grab the metals before you introduce CL to your pool. Use the sequestering agent according to the container instructions.
Your salt level should be around 3200 ppm, is it?
Jul 07, 2010 | Intex Automatic Salt Water System for ...
How to set up a d2000 automatic pool vacuum
Here is a copy of the users manual for these above ground pool cleaners. It has detailed instructions and pictures for set up. This should help.
http://www.backyardcitypools.com/images/BWP/Dirt-Devil-D2000-Manual.pdf
May 21, 2010 | Dirt Devil Above - Ground Auto Pool...
How deep can we dig for oval deep-end pool
This blog has information about sinking an above ground pool. It is normally recommended that you do not sink the pool entirely into the ground becuase of pressure concerns and the risk of collapse. Generally, you leave 1-3 feet of the pool above the ground and install a deck or similar feature to make the pool appear to be in the ground. The type of pool liner that you have (expandable) is best for this practice, but it can be done with overlap or regular beaded liners also.
http://backyardcity.wordpress.com/2009/06/02/the-above-ground-pool-goes-underground/
May 08, 2010 | Intex 18 ft x 48" Easy Set Inflatable...
Need operating instructions for smartpool pe23 pool alarm
You can find the pdf version of the users manual for these pool alarms on the Smart Pool website. Here is a link to it:
http://smartpool.com/website/manuals/PE22.pdf
Sep 13, 2009 | SmartPool PoolEye In-Ground Pool Alarm...
I have a 21' round above ground pool and the wall is slightly pushed in at the base of 4 of the support post. What could be causing this?
Mowing while intoximicated...
angry woodchucks....
the pool boy..?
No wait....
the neighbors kids....that's it...
Blame the neighbors kid's .. lol
Jul 31, 2009 | Smartpool Above-ground Pool Eye
SmartPool PoolEye In-Ground Pool Alarm with Remote and Temp Logo
228 people viewed this question
Top Smartpool Pool & Spa Experts
Marvin
Marvin
Craig Butler
Craig Butler
Robert Plante
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
