Question about Mercury P4VM800M7 Motherboard
USB Port works slowlly
Dear sir,
I have an multi type USB Port extention where 4 ports are there. But when I access data between any pen drive and hard disk through this USB port the accsee is being to much slow. I could not found any USB2 driver (even in the Mother Board CD) which may help this problem. Now what shall I do ?
Biswarup
  • atul_pawar Dec 17, 2008
    gegggg
  • Anonymous Jan 08, 2009
    whit usb 2.0 pci card is the same thing
    Problem Solver:
  • 6 Answers
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
0066
Posted on May 15, 2009
  • 63 Answers
U can add hard to perform faster..
add hardware usb card 2.0..
u can buy it any acessory computer shop..
good luck..
thanks
wafirash
Posted on Apr 26, 2008
My mother board gigabit 61pme s2p series mother board.with amd althon 3ghz processor.the problem is when i connect the usb pendrive to back of the usb port...if i send data 1 or 2gb data to pen drive.the...
your problem is kind of complicated. Check if you have a defective usb flash drive or an usb connector by doing so:
  1. Try other usb flash drive. If it solves the problem you have a defective flash drive
  2. Try to plug in to other usb port. Observe each port. If you see that you have a problem with your usb ports, buy a new usb port card
Aug 01, 2011 | Intel Motherboard
Dead pen drive....not recognised by the usb port
hi
There is a problem with the pen drives circuit assy. Try follwoing
1. Open the pen-drive
2. Check to see if you can find a small SMD (Surface Mount Device) type fuse marked as '"0" on it.
3. make sure it is not shorted by checking with multi tester.
4. If no continuity then you have to replace it or short across the fuse to make it work if you know good soldering.
Regards,
Jul 14, 2011 | Computers & Internet
RES. SIR, CAN WE PROPERLY BOOT WINDOWS XP/7 TO PC USING USB PORT(PEN DRIVE/MEMORY CARD)? IF YES THEN PLEASE TELL WHICH BACK UP WE HAVE TO KEEP IN PEN DRIVE (XP IMAGE OR COPY OF DATA),PROVIDE THE VALIDE...
Sorry sn_sachin_99, I'm not sure if you can Boot up windows using a USB port. If it is possible. I'm not the type of expert that's know how to do so. I am very sorry that I could not answer your question.
- Steven ASAP
Here to help!
Apr 23, 2011 | Computers & Internet
I have a HP 4gb pen drive.Initially it was working fine but now even a small data transfer takes too much time,e.g. to transfer a data of 600mb it takes 45min or even more. What is the cause of this...
1. make sure USB port is 2.0
2. Try another USB port
3. Format your'e pen drive and try again
4. Finally, try another computer
if all fails, consider buying a new one.
good luck
Nov 08, 2010 | Office Equipment & Supplies
Hellow sir, I am mahesh. I have transcend 4GB pen drive (JF V10). My problem is, When i connected pen drive to my pc then it could not start but it was shown in my computer as a removable disk and...
its just simple MAHESH...
1st if your pen drive has no data inside.. don't hesitate to reformat it.. then try again..
2nd check the device manager on your computer if the pen drive of yours was updated with its USB port.. just look for the UNKNOWN DEVICE in the USB port in the bottom of the device manager..
if there's no name of UNKNOWN DEVICE it means you must go to the settings of your pen drive..
just right click your pen drive then properties,, then look for the AUTO PLAY then select the action to perform..
then apply and ok... now close all documents then go to my computer and right click your pen drive and click the AUTO PLAY if its work... restart your pc... then its done... ^_^
Oct 18, 2010 | Computers & Internet
Pen drive issue
Try a totally independant PC away from the ones you tried....if no go drive has failed and data will be lost sorry.
Jan 07, 2010 | Kingston (SDCZ2-512-A10-KT)...
Pen drive not getting detected? how to work it?
first go to my computer propery then hardware then device manager then go t ousb controller uninstall all usb drivers from there then just right click on any driver then click on scan for hardware changes then it automatic install usb drivers .
Connectyour pen drive to usb port check all port.
then if its not working check with other usb device is working with usb port?
Jul 15, 2009 | Iomega REV ATAPI HDR B/U KIT CA 6 REV...
Imation 4GB pen drive is not working................
you will have to re-install the drivers for it i think.
it seems like you pc is finding the drive but just can not access it.
Feb 25, 2009 | Transcend (589307) Media
Ttanscaned pen drive problem
I Have Cruzer micro (8Gb) pen drive When i Insert pendrive And open Show message (Pls Insert Disk) When I try to format Pen drive Show message (There is no disk in drive G) G Drive Right click And go properties Show 0byets Pls solve the problem Regards, Prashant
Jan 13, 2009 | Electronics - Others
USB 2.0 port not supporting for multi-use
check the driver status of usb ports, or check all the usb port of *********** board sepeartely,
Nov 03, 2008 | Mercury P4VM800M7 Motherboard
Mercury P4VM800M7 Motherboard Logo
494 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
