SOURCE: I have a new key board but I don`t no how to remover the broken one its a dell inspron 1525 lap top
The link below will take you to a step by step guide for replacing the keyboard:
http://support.dell.com/support/edocs/systems/ins1525/en/SM/keyboard.htm#wp1180346
Good luck and please let me know how you do with the replacement.
~ Spoem
SOURCE: I have an Inspiron 1525 Dell Laptop with windows
You may have a bad connection. You could try taking the keyboard off and unplugging it, then plugging it back in.
If that doesn't work try using a usb keyboard and see if you're able to type. If you can type, try changing the laptop's keyboard, and if you can't type you may have a currupted OS.
If none of these are the problem, you have a bad keyboard port on your motherboard.
SOURCE: Dell Inspiron 1525 on board mic not working in win 7
download the driver from the maunfacturer site it will work when it is installed
SOURCE: dell laptop inspiron 1525 spacebar sometimes acts
Since you don't mention your operating system, I'll just try to help generically. In the Control Panel, find where your keyboard icon is and open it. Somewhere in the contents of the windows opened by different tabs, you should see an opportunity to reset your keyboard to its "defaul settings". I'd recommend that.
Many Dell's have what are called "'sticky keys" where if you do a certain number of keystrokes repeatedly, the laptop thinks you want to change a certain key to do a different command.
If this doesn't solve your issue, it's possible that a short of some kind has wires activating commands they should not. If that is the case, there may not be a less expensive nor easier to replace keyboard than on a Dell.
Good Luck
SOURCE: what hot keys will unlock
There isn't a hotkey to unlock a hard drive. It's locked from within the BIOS.
When you boot the computer you should see a message saying Press " key " for setup.
Inside there is where the hard drive password is set.
Let me know if you have any more questions.
