Whirlpool 6th Sense displaying FP and clean pump is lit ! How do you clean pump ?
  • 343 Answers
On the lower front panel is a small door which may be behind the kick panel. Behind this door is the drain filter.. Do not undo this filter till you have emptied the machine, as any water in the machine will flow from the pump, when opened.. Leaning the machine back against the wall will help contain what water is left in the machine..
Undo filter, check and clean.
Check that a coin or hairclip has not fouled pump impellers.
If the impeller has come away from the pump shaft, the pump motor needs to be replaced.. A tech should be called for this job!
Good luck....Nomess
Posted on Aug 04, 2010
  • dvdcrainey Sep 03, 2010
    I have the same problem but cant get the filter out, is it normally difficult? There was a black lid which I loosened but that left a white plastic part which i assume is the filter. I messed about with screwdrivers and pliers but it wudnt come out more than just level with the face of the front panel. I couldnt even see see in far enough to see if anything was blocking it!?
  • Paul Todd May 03, 2013
    The filter behind the kick panel has a thread, turn anti clock wise and the filter should come out, most likely you will find coins and air clips that will stop the machine working
Sounds like a hair clip stuck in there, brute force required to remove filter using grips and screwdriver
Posted on Nov 28, 2011
Whirlpool 6th sense - pump issue
The drain pump probably just needs cleaned. If you've never cleaned it i can direct you to videos that are step by step. Let me know.
Jan 20, 2013 | Whirlpool Washing Machines
Were is the pump on whirlpool 6th sense
Whirlpool recently launched a new site and I find they have made it easier to find the solutions I need for DIY. www.whirlpoolwaterheaters.com/products/natural-gas/n50t61-403/
Jun 24, 2012 | Whirlpool 6th Sense 50-Gallon 6-Year Tall...
Am getting FP error message on a Whirlpool 6th Sense washing machine. Have removed foreign objects from filter but still getting error message. What more can i do?
your right the error code is filer pump now disconnect power and let unit sit for 1 hr should reset its computer
dam computers
Dec 29, 2010 | Washing Machines
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
My Whirlpool Washing Machine 6th Sense 10kg Dreamspace has stopped washing mid-cycle and has a F09 warning flashing
my whirlpool 6th sense dreamspace has a red ligth lit indicating water tap closed can anyone explain why?
Mar 15, 2010 | Whirlpool Washing Machines
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
Dec 26, 2008 | Whirlpool AWM8143 Front Load Washer
Whirlpool 6th sense awm8163 programes never stops now cannot get it to work at all
The pump is at the lower left of the front of the machine covered by a white plate. Use a bowl to catch any remaining water when opening the screw thread inside and then clean and replace. If it is truely beyond repair then a new filter pump can be bought from ebay for £3 or thereabouts.
I have just drained mine manually in this way and am going to run it empty with soda crystals to glean a few more days use whilst the new pump arrives.
Good luck :)
Jan 20, 2008 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
805 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
