Question about Gaggia Baby Espresso Machine
I require a new on/off switch for the machine below
  • Gaggia Master
  • 1,711 Answers
Tip
The washing machine is under filling water?
This problem is due to fault in the Water-level switch in washing machine.
The Water-level switch is the part in the washing machine that senses the filling water in the tub. When the water reaches to its required quantity the Water-level switch sends the command to stop the water supply. But if the Water-level switch is faulty. It will sense the wrong quantity of water in the machine. And makes the water supply stop bit early then required. So washer does not fills with required water .The Water-level switch is located at the bottom of the outer tub in the washing machine. Many a times removing and reconnecting the switch makes it proper. in other cases it needs to be replaced.
These will help. Thanks
on Mar 18, 2010 | Washing Machines
Can i insert a dedicated graphics card to improve graphics performance?
Kevin:
As a certified technician since the late '80s I've never seen a portable (laptop) computer that could be upgraded excepting hard drive and memory upgrades (short of purchasing a new system board from the manufacturer - cost prohibitive). IMHO that is the single biggest shortcoming for portables. That issue also applies to many name brand desktop machines too. Only the top end (gaming) machines have the better GPUs. I've worked on only a few Acer machines; but, it's highly unlikely it's GPU can be upgraded. To determine your machines exact system information go to acer.com at the below link. Enter your SNID (located on bottom of your machine).
If you want a machine that is upgradeable instead of just replaceable consider manufacturers such as ASUS
The hardware requirements for Minecraft can be found at the other link below.
All that being said, a memory upgrade to 8GB (if your machine will accept it - see System Requirements link) might get you some performance boost.
Sorry I didn't have better news for ya.
In His Grace
Elton
System Information Hardware requirements
Mar 29, 2015 | Acer Aspire E1-521-0851 - 15.6" - E1-1200...
I require the wiring diagram for the interloch switch on bosch exxcel washer/dryer
go on line type in free bosch exxel circiut diagrams when they come up put your model number in and you should find it free or you might have to pay
Sep 27, 2012 | Bosch Washing Machines
Have Neff part of Bosch washing machine require to know\r\nhow to change over the on/off switch Have the new one and can get to the part but dont want to use to much force to I assume pull out???? Len
Can you tell from looking at the new switch if there are plastic springing bits with lips on the sides which would keep the switch in place once it is 'clicked' into the 'cut-out'?
If so use a thin blade, or similar (but not a sharp knife!), to compress one side of the old switch then the other side to extract. The other point is that you have a new switch if you damage the old!
Success I hope ;-0)
John C
Feb 28, 2011 | Bosch Washing Machines
LG wf-t6517tc, stop after fill water, dE code error
Strange that it should fill as that means door error. You would think it would not fill if it thinks there is a door error. Have you tried switching off, unplug leaving for a few mins? If you can empty it check the door seal,/ latch it may require a new door switch.
Also check that the pump filter is not partially obstructed, be careful water will come out when you check. I read that in another post, I also read that it means drain error but that is at odds with what is written here: read this below it should help and there are pictures
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
regards
Jan 27, 2011 | Washing Machines
Cimbali M27
First, the switch is a 3 position(off-on-on). Second, I am assuming you have a 2 group machine, check the element wires use the schematic below.
Sep 29, 2009 | Espresso RMI La Cimbali Espresso Machine
Dishwasher adp 4601 when switched on the pump activates.and after 2 mins start lamp bliks and pump goes off
The number of flashes indicates the fault. Reset machine by holding down the start button for 3 secs, then start a new cycle. If fault reoccurs, the number of flashes indicates fault eg 3 flashes, stop, 3 flashes stop, indicates F3 fault.
Faults listed below- advice on repair depends on which fault your machine is indicating, but may give you an idea of what to look for
1flash=NTC (temperature sensor) break- NTC outside normal range.
2flash=water leakage-float switch in base activated.
3flash=heating fault(check element.NTC,control board).
4flash=drain error-blockage in pump or drain system,or faulty water indicator switch.
6flash=water inlet fault-check inlet valve, check inlet hose not kinked
7flash=flow meter failure (flow meter measures water intake volume-large plastic weir located on left hand side of machine-reomve side panel to access)
These a most common faults, but further advice on repair requires counting flashes when fault occurs.
Aug 09, 2009 | Whirlpool Dishwashers
Machine cannot switch on
I have a whirlpool machine here now that I have just repaired. It sounds like the main control (like a small computer) has failed. Requires a new control unit.
Sorry but hope this answers your question
Regards jb
Mar 02, 2009 | Whirlpool AWM5125/1 Front Load Washer
Embellishine machine
To my knowledge this is requires a special machine, a felting machine. Brother, Janome, Babylock sell models
Oct 13, 2008 | Elna 2007 Mechanical Sewing Machine
Gaggia Baby Espresso Machine Logo
162 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
