Question about Stoves 720EF Electric Double Oven
My stoves 720ef oven keeps cutting out after 20 minutes and will not turn back on, the grill continues to work ok. I know the timer is set to manual so I guess it must be a thermal trip. As I do not have a wiring diagram does anyone know which componant I need to replace to solve this. Many thanks in advance.
  • 250 Answers
There are seperate thermal (overheat) cutout devices for both the top and bottom ovens. First check to see if the lower oven fan is running ok and is not restricted by grease or fat (there are 4 self tapping screws that hold the fan cover on) and the thermostat is switching off and on as it should. You should also check that the main background cooling fan is running and switches off a few mins after the ovens have turned off. If these check out ok, then it is possibly the lower oven thermal cutout.
Posted on Aug 05, 2010
  • Geoff Manby
    Geoff Manby Oct 17, 2014
    It seems that on my stoves 720EF oven that the background cooling fan does not run when either oven is switched on. The oven cuts out after 20mins or so and will not come back on again until it has cooled down. Any suggestions?
Stoves 720EF oven switches off after 20 minutes
CHECK THAT THE OVEN TIMER IS OFF AND NOT OPERATING EVERYTIME YOU TURN THE OVEN ON IT AUTOMATICALLY SWITHES THE OVEN OFF AFTER 20 MINUTES
Oct 16, 2014 | Ovens
Rcd trips after 1 minute of using top oven or grill
It could be the top oven overheat thermostat going faulty. With something like this the only way to find it is to take the oven to bits and use a test meter to see what is causing the problem. Just to let you know, on the 720, the grill works independent of the timer/clock. So if both the top oven and grill are generating the problem, that is where I would start to look.
Dec 13, 2011 | Stoves 720EF Electric Double Oven
I have a stoves 720ef oven and cannot get rid of the auto
The handbook says:-
To cancel the automatic setting and return the oven to manual operation, press the cook time and ready time buttons simultaneously. These are the second and third buttons from the left. If you have done that and it is not working, try turning the complete oven off for awhile - say 30 mins and turning back on. If this still doesn't work then it may be that the timer/clock has gone faulty.
Nov 10, 2011 | Stoves 720EF Electric Double Oven
Just moved address, new house has a Stoves 720 EF built in oven.Model 059040437. I can't work out how to turn on the grill or set the timer, don't understand what any of the symbols on the front left next...
I don't know if this will help. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Jan 10, 2011 | Stoves 720EF Electric Double Oven
Electric grill is intermittant or cuts out after 5/10 minutes
There are two overheat devices in the oven. One feeds the oven timer/programmer for the main oven and the other feeds the grill. If the cooling fan is running ok, then I would suspect it is the cutout feeding the grill elements that has perhaps with age is not working as it should do.
Nov 21, 2010 | Stoves 720EF Electric Double Oven
Stoves efa700h grill cuts out after around 20 mins, the grill gets very hot, read a cpl of posts about fans and thermo cut outs, easy job? appreciate any help
On the 720 there are two thermal cut outs. Looking at the wiring diagram, the cooling fan and the clock are the only two items that will run independant of the cut outs. So, is the cooling fan running ok or not? If it is and the grill is cutting out, then it could be the thermal cut out that has aged - or the fan may be running slowly because of age or there is a build up of dirt grease under and around the oven and on the outlets that stop air curculating properly.
If the fan isn't running then you need to replace it or the fan timer PCB may have failed. Once you have gotten into the oven's inards, you can test the fan to see if it runs or not.
Nov 16, 2010 | Stoves 720EF Electric Double Oven
MY STOVES COOKER'S OVEN AND GRILL HAS STOPPED WORKING?THE HOB IS WORKING FINE.
The hob is normally totally independent of the oven. What is actually working or not working on the oven? i.e. does the grill still work, is the clock OK and can you set it, or is everything totally dead?
Oct 16, 2010 | Stoves 720EF Electric Double Oven
No Grill operation for stoves 720ef
Supply an email address for you and I will grant you access to my BT Digital Vault where a copy of the complete handbook is lodged. It includes circuit diagrams.
With your fault, can you here the switch operating, if not it just may be stuck?
Dec 12, 2009 | Stoves 720EF Electric Double Oven
Stoves 720EF - main fan not working
When you say the main fan, do you mean the background cooling fan or do you mean the circulating fan in the bottom oven?
Do you have the handbook for this oven as the wiring diagrams are included in it. If you haven't, you can take a copy from my BT Digital Vault - all I need is an email address to register you.
Looking at the diagram, the power for the cooling fan comes via the timer board. If, as you say, the fan doesn't work at all, the timer board could have gone faulty.
Nov 15, 2009 | Stoves 720EF Electric Double Oven
My stoves 720ef oven goes off if it turned up over 140 deg c also the grill in the top oven does not get red hot
Is the cooling fan running in the oven? Does it also continue to run when the oven controls are turned off to let the oven cool down?
There are ventilation grills below each door on the oven. You can see these when the doors are fully open, just look under each door to see if they are clear and not blocked up.
Jul 21, 2009 | Stoves 720EF Electric Double Oven
Stoves 720EF Electric Double Oven Logo
1,282 people viewed this question
Top Stoves Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Oloyede Monsuru
Are you a Stoves Oven Expert? Answer questions, earn points and help others
