Question about RCA D52W19 52" Rear Projection Television
Thomson 32WZ610 A LOW B RAIL NO EHT - RCA D52W19 52" Rear Projection Television
  • will368 Apr 26, 2008
    Thomson 32WZ610 A
    TV started to operate intermittently at first, then shut down completely. When opened, I found electrolytic CP150 burst open. When replaced I checked for obvious shorts and open circuit fuses/resistors etc, no problems, all appeared o.k. B+ Rail now reads 18v going down to zero, even with EHT transistor removed and light bulb in its place. Any advice welcome!!!
    Cheers and thanks,
    Will.
EHT NO. OF SONY T.V. MODEL KV-L34MF1 AND APPX.COST OF IT
The line output transformer to your TV should be checked and replaced.
Aug 27, 2012 | Thomson 14MG135 14" TV
Isn't turning on, goes on for a second then light blinks 8 times
That means the EHT has exceeded 33KV and it will shut down.
Probably caused by a faulty/maladjusted power supply. Check the 135Volt rail.
Hope that helps.
Mar 01, 2011 | Sony FD Trinitron WEGA KV-36HS500 36" TV
My crt tv have big oversize picture. what component should I replace is that bad capacitor??
That could be caused by a number of things. The first that comes to mind is low EHT. That could be either power supply or EHT Trippler unit.
It will be a guess.
Check the HT supply first and make sure it is correct then the EHT should be around 25KV.
Jan 29, 2011 | Televison & Video
EHT + SUPPLY IS (55 OR 60 VOLTAGE) LOW VOLTAGE,MICRO POSER VOLTAGE IS NORMAL ON /OFF VOLTAGE NO ,RESET VOLTAGE NO , N O RASTER WHY
EHT should be 22 - 25KV
Power supply should supply 130Volts not 55!
Check power supply feedback loop and poor contact pre set.
Jan 06, 2011 | Hitachi C1478FN 14" TV
Thomson Model no 29 DG91XD EHT PART RQUIRED
hi there.i presume you mean the line output transformer? the part number on the side is what you need ,then get in touch with grandata (uk company) who should be able to supply you with one.or alternatively chs.(chas hyde and sons).the problem now is that a lot of tv spares companies are now geared towards lcd and plasma spares,so its possible it would need to be put on special order.hope this helps, regards, steve
Oct 05, 2010 | Thomson 29DM400 29" TV
Help for TCL Brand of tv
I WANT THE SERVICE MODE CODE FOR MODEL NO: DP21E101 TCL TV 21"
Jun 15, 2008 | LG 30FS1D TV
Teac Problem
usually high b+ rail replace jungle caps first the reflow eht flyback
thanks
Feb 13, 2008 | Audio Players & Recorders
No picture
Hi.
Look on the rear of tv set to see if there is a chassis number it normally starts ICC
http://dysonmanuals.inc.io/
Chris
Nov 07, 2007 | Thomson 28VK25US TV
Thomson tv, model quadra 21
reset the memory of your tv,or the EEPROM.to reset it just simply unplug the unit,then press together the menu and the vol+ buttons,then press the power switch,when its on,release together the from pressing menu and vol+
Oct 18, 2007 | Thomson 21DC320 21" TV
RCA D52W19 52" Rear Projection Television Logo
167 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
