Question about LG 22" FLATRON LCD Monitor
I have a problem with my LG Flatron W2234s monitor, that monitor went dim that i can't read from it, please help if you know how i can fix my problem, even if i need to change capacitors please direct me which ones I need to exchange as there is 8 of them.
    Scholar:
  • 34 Answers
I have a W2234s and the link to the service manual is ...
http://elektrotanya.com/lg_w2234s-sni-bni-axx-qp_sm.pdf/download.html.
To be honest it sound like a tube gone at the back , the easy way to find which one is to plug in another plate from another LCD, I' done this with 19 and 17 , just don't leave it connected for ever,
So select 1 of 4 the plate leads and leave it unconnect to your w2234s inverter and plug in one lead from your other plate to give 4 connection and see it it lights, your can do all 4 or in pairs. Having found the broken tube or part then replace it. If it still fails it the inverter, the manual will tell to where the 5v and 16v are using a voltmeter to check the caps if showing 15v to 20v then ok(brightness control) etc, I had to print the manual to read it. Check the 5 power transistor, three around the caps , two on the flip, all have silver heat sinks, they control the voltage in three steps from out side to the ccfls in 110v/240v to 5v and 16v to 750 volts , see where it stop flowing, it's in the circuit diagram. In the three that i have seen, the caps where ok , tubes where weaking, maded january 2008. I hope this helps.
Posted on Aug 26, 2010
  • LG Master
  • 32,281 Answers
It appears you have a backlight problem. This fault is caused by either a faulty inverter board or a faulty CCFL lamp. Please click on this link and follow my instructions to determine the fault and possible fix. :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Aug 04, 2010
Lg w2234s-bn Monitor Cycling randomly through Light View Modes/Power Button turning It's self on and off.
On and off cycleing could be caused by a bad power supply or a low battery on your remote. Check them both out. Good luck.
Apr 28, 2012 | LG 22" FLATRON LCD Monitor
My LG FLATRON W2234S monitor won't turn on. When I press the on/off button it lights blue for like 5 seconds and then it goes black again. Plugging the main power cabel in and out won't work. All help...
Try changing the Resolution for the lowest one, if it works it will see the letters and everything very big. I have same trouble, specially since I change the original Vista Starter for the new Windows 7, I have not found a free controler that helps me and I have seen many people with same the problem. Sorry for my english.
Oct 10, 2010 | LG Flatron W2243SPF Widescreen LCD Monitor
Lg w2234s no signal?
shut down the computer completely by pressing on the power button until no sound is heard. Then make sure that the screen is properly connected to the computer and turn on the computer. If this doesn't help, disconnect the cable that connects the screen with the computer, see that the connection looks fine (no broken pins) and then connect again to the computer.
Oct 04, 2010 | LG Flatron L1715S 17" LCD Monitor
Doese not want 2 go on !!
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 21, 2010 | LG 22" FLATRON LCD Monitor
LG Flatron W2234S 22 purple tint problem
your LCD monitor has bad ccfl lamps or inverter circut..
May 08, 2010 | LG 22" FLATRON LCD Monitor
Lg 22' monitor was widescreen now has black bars!! Cant remove ?
the grpahics from wowc burnd the sides of your monitor. your pretty much screwed if you keep playing that game
Aug 16, 2009 | LG Flatron L1710S 17" LCD Monitor
No picture lg flatron w2234s blinking blue light
Hi My screen developed exactly the same problem. It appears to be a hardwear problem associated with the screen it's self. continuity test is ok on the lead so I took it back to the shop under warranty and hey presto, the replacement works. I don't know what the problem is but there are a number of other folks on another thread with the same problem and their entries are dated May 09 too.  Dave
May 26, 2009 | LG Flatron L1750S 17" LCD Monitor
LG Flatron W2234S monitor seems to be in sleep mode.
the backlight fluorescent bulb is burned out
Dec 26, 2008 | Computers & Internet
LG 22" FLATRON LCD Monitor Logo
1,166 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
