Question about Ovens
Small elements on glass cooktop of westinghouse PAK808W 00 upright cooker do not work, however the large element and outside ring of dual element do work. The upright is approx 14 years old, and the grill and oven still work fine. Can these small elements be replaced with the modern PAK808W hob elements?
BADBOYJAY
  • 269 Answers
SOURCE: oven does not work
its just your heater element you will need to wright down your model number and go on ebay or go to your local appliance shop they might order you 1 there about £35 pound
Posted on Jan 07, 2008
barkencoa
  • 3463 Answers
SOURCE: Beko D533 cooker only half working
Is the cooker a new one? I fit is then it does sound like an internal wiring problem, in which case you should contact the supplier. Make sure it is wired correctly from your circuit breaker first, There should be a diagram showing the connections.
Hope this helps.
Please leave feedback.
Posted on Dec 07, 2008
barkencoa
  • 3463 Answers
SOURCE: Grill not working
Yes, you will need to replace the whole element.
barkencoa
  • 3463 Answers
SOURCE: how can i mend the grill and oven on my electric cooker?
If the rings work o/k then could be timer if it has one make sure it is set to manual and not auto.
Another thing it could be is a faulty selector switch, which selects the different functions.
Hope this helps.
Plz rate my solution.
Thanks.
Posted on Dec 31, 2008
  • 18 Answers
SOURCE: Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Posted on Jan 23, 2009
Trying to change element on westinghouse PAK806 stove with ceramic cooktop. cant figure how to lift hob.
Hi I have a Westinghouse PAK806. The oven works fine, heat and fan, but none of the plates will turn on.
Any ideas?
Jul 13, 2011 | Ovens
When using the oven the electicity tripped; after resetting the breaker the oven does not appear to get hot; however the grill works, the light works and the fan works what could be the problem?
Sounds like the oven element has gone. When these elements go they often short against the outside casing of the element which is earthed (or should be). This trips the main trip switch in the house. Having tripped and cooled down, the element is now broken inside & won't heat up. Usually 2 screws to remove, either inside oven or outside at back. Element usually taken out thro oven. Take it & cooker info to your dealer & ask for replacement. Shouldn't cost much.
Jun 13, 2011 | New World Ovens
Hotplate won"t turn off st george cc-600 cooktop
I have a St George glass cooktop with temperature sensor light.It takes forever for the light to go out when I use the main element and that section often feels like it is still heatinglong after it has been turned off.Can there be power leakage through the switch for the main element
Aug 21, 2010 | Ovens
I need to replace the element on my westinghouse freestyle 808 oven . where can i order one how do i change the element? thanx
pull the unit out of the housing and rest on a suitable work bench. turn off the power and remove the rear cover you will see the grill element, ring element and the bottom element. depending on whcih one has blown they are relatively straight forward to replace.
as for where to purchase one depends on what country and area you live in. best to search for someone local on line
Aug 19, 2010 | Ovens
Only one ring of the double ring element works
You have faulty regulator, or the element is faulty., not sure how you access the inside.
Hope this helps.
Dec 05, 2008 | GE Profile JTP18 Electric Single Oven
Replacing the element in a diplomat 5706 cooker
Hi.
You will probably have to remove the rear panel of the oven, this is on the outside that I am referring to, and you will see the 2 securing scews for the element, you might have to push the insulation to one side to see the screws.
This should solve your problem.
Please good feedback if this helps.
Thanks.
Nov 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
Only oven element will not heat
look on the oven element and see if you see any blow out holes,let me know-mike
Oct 07, 2008 | Frigidaire Ovens
Beko DCC4521
almost certainly the element. take the back panel off inside the oven and the element is exposed. often you can see the damage. if you want to go further and repair yourself, then get back to me
Sep 04, 2008 | Ovens
Ovens Logo
50 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
