Question about Proform Exercise & Fitness
How do i attach the motor drive to the treadmill
  • MONA STOUTE Aug 04, 2010
    I am replacing my treadmill motor, so i wanted to know how to reattach the new motor to the treadmill. so i was not searching for any power source for any project.
  • 857 Answers
If you have been searching for a reliable power source for a small wind turbine project, you can use a treadmill motor to achieve excellent results with a smaller unit. For instance a 260 volt, 5 amp continuous duty treadmill motor can help you create a wind turbine that will create about 100 watt and 7 amps in a 30 mph wind. This simple how to guide will show you how to install a treadmill motor into an existing wind turbine project.
What You Will Need
■260 Volt DC , 5 amp continuous duty Treadmill Motor with a 6 inch threaded hub
■One way 30 - 50 Amp Blocking Diode
■2 x 5/16” x ¾” Motor Bolts
■3" X 11" PVC Pipe
■PVC saw
■Drill and drill bits
■Screwdriver set
■Wrench set
■Clamps
■Wire strippers
■Tape measure
■Pen or marker
■1/4 inch #20 thread tapping set
■Square tubing
■1/4 inch bolts and washers
■Sheet metal screws
■Straight edge
Step 1 - Make a Protective Cover for the Motor
Take a straight edge and pencil and draw two straight lines down the entire length of the PVC pipe. Make sure that the lines are about 3/4 inch apart. Then, use the PVC saw to cut along these lines to create the protective sleeve. Finally, make a 45° angle cut at one end of the pipe.
Step 2 - Prepare Square Tubing
Place the motor flatly on one end of the square tubing, so that the bolt holes of the hub are lined with the tubing and are faced down. Mark the positions of the bolt holes on the square tubing with a marker. Then, take a drill and a 5/16 inch drill bit and drill a hole at each mark all the way through the piece of square tubing.
Step 3 - Make Adjustments to Blades
If you will be installing the new treadmill motor into an existing wind turbine, you'll need to ensure that the bolt holes for the blades are aligned properly with the threaded hub on the new motor. If they don't match up, you'll have to drill new holes so that the blades will align with the holes of the threaded hub.
Step 4- Secure the Motor to Square Tubing
Place the treadmill motor directly on top of the square tubing and use the two motor bolts to secure it.
Step 5 - Attach the Diode
Use the two self tapping screws to secure the diode on top of the square tubing. Place the diode approximately 2 inches behind the motor.
Step 6 - Wire the Connections
To wire the motor to the diode, you'll first need to connect the red wire from the motor to the negative terminal of the diode. Connect the wire where it is labeled AC on the '-' side. Then, connect the black wire from the motor to the diode where it is labeled AC on the '+' side.
Step 7 - Attach Motor to Base
Place the motor and square tubing directly on the base of the support pole. If you are using a floor flange as the base, simply line up the holes, and then mark them with your marker. Then, drill the holes with an appropriate sized drill bit. Then, secure the motor and square tubing to the base using sheet metal screws.
Step 8 - Attach Blades to Motor
Attach each blade to the hub and then secure with 1/4 inch bolts and washers. Then screw the hub into the motor and turn the hub counterclockwise until it is tight. Tighten with a wrench or pliers.
Step 9 - Install Protective Cover
Slip the PVC protective cover over the motor and diode to protect them from the elements.
Posted on Aug 04, 2010
Making very loud whistle noise
Be sure to verify if you are getting the noise while you are physically on the machine or with no one on it
Creaking or squeaking while running on the machine usually indicates an issue in your incline motor, deck frame, springs, and or pivot points
A loud grumbling noise getting louder and louder while elevating speed, usually means you have a bad bearing
Any knocking noise coming from a treadmill indicates bad bearings in your front roller, rear roller, or drive motor
Isolate the bearings in the front and rear rollers from the drive motor bearings
To test: Unplug machine, remove the main shroud, remove drive belt from drive motor and front roller pulley
After doing so, move the treadmill belt by itself by pushing it backward or forward with just your hands and listen for any noise, if you get any noise it is most likely coming from either the front or rear roller. To isolate the noise out of the two rollers you must remove the rollers and turn each one individually.
If no noise with the first test, go ahead and start the machine and run it at a low speed. You want to listen for noise, if you get knocking or grumbling while drive motor is running with no drive belt attached then the issue is in your Drive Motor.
A lot of times simple maintenance will save your treadmill from noise, you want to make sure and lubricate your treadmills *pivot points. Incline motor bolt, shaft, deck screws, and or any *pivot points on the bottom of your machine. Metal on metal *pivot points are usually the culprit in most cases.
*Pivot points are just areas of high friction where there may be a bolt, washer, and nut attached to the base of your frame or any hinges on your folding type treadmills. Metal to metal needs to be lubricated to minimize wear and tear of those areas.
Synthetic grease works best or any spray on lubrication works fine if you do not want to remove any bolts or hardware.
If you have any other questions please do not hesitate to call us or visit us online
888-713-2880 or
http://www.sportsmith.net/supportsearch.aspx
May 29, 2015 | Reebok RX6200 Treadmill Motor Control...
Tip
How to troubleshoot a noisy treadmill
First verify if your are getting the noise with a user physically on the machine, without anyone on, or both.
Creaking or squeaking while running on the machine usually indicates an issue in your incline motor, deck frame, springs, and or pivot points.
A loud grumbling noise getting louder and louder while elevating speed, usually means you have a bad bearing.
Any knocking noise coming from a treadmill indicates bad bearings in your front roller, rear roller, or drive motor.
Isolate the bearings in the front and rear rollers from the drive motor bearings.
To test: Unplug the machine, remove the main shroud, remove drive belt from drive motor and front roller pulley.
After doing so, move the treadmill belt by itself by pushing it backward or forward with just your hands and listen for any noise, if you get any noise it is most likely coming from either the front or rear roller. To isolate the noise from the two rollers you can loosen the belt and turn each roller individually.
If no noise with the first test, go ahead and start the machine and run it at a low speed. You want to listen for noise, if you get knocking or grumbling while drive motor is running with no drive belt attached then the issue is in your drive motor.
A lot of times simple maintenance will save your treadmill from noise, you want to make sure and lubricate your treadmills pivot points. Incline motor bolt, shaft, deck screws, and or any pivot points on the bottom of your machine. Metal on metal pivot points are usually the culprit in most cases.
Pivot points are just areas of high friction where there may be a bolt, washer, and nut attached to the base of your frame or any hinges on your folding type treadmills. Metal on metal needs to be lubricated to minimize wear and tear of those areas.
If you ever find yourself needing technical support, please do not hesitate to call us 888-713-2880 or visit us online at www.sportsmith.net
on Jul 13, 2015 | Exercise & Fitness
My treadmill when I step on stop. The motor is going but no the bell
Your belt is either worn or out of adjustment and too loose. Some treadmills actually have 2 belts depending on the drive system. Some have a small belt that goes from the actual motor to a pulley that is attached to walking belt drive system. If the big walking belt is tight you may have that system and the small belt needs tightened. Other systems have the motor connected directly to the big walking belt and in this system my guess would be the big walking belt is loose. Most have adjustment screws at the back end of the treadmill frame along side the belt to make it tighter. Adjust both sides the same so it tracks straight.
Apr 02, 2015 | Exercise & Fitness
Treadmill jerks back while running. I feel like i might fall off of it
see the video attached, lube the rollers bearing front +back too.Test the drive belt motor for tight or faulty .
God bless you
Sep 29, 2013 | Treadmill Doctor Weslo Cadence Dx12...
How do i remove the weights to facilitate moving the treadmill?
see the video attached. and proceed according.
God bless you
Sep 27, 2013 | Nordic Track NordicTrack ELITE XT...
Reebok tr2 incline wont work, back of machine starts to rise when you prees the incline up button
1) lube the motor elevation, shaft +gear and adjust the POTentiometer a little
2) see the diagram attached,
3) Run the software calibration for troubleshooting,
4)test the relais for open or faulty coil,and clean the contacts very well
God bless you1_22_2013_5_10_05_pm.gif1_22_2013_5_10_34_pm.jpg1_22_2013_5_11_02_pm.png
Jan 22, 2013 | Treadmill Doctor Reebok S 9.80 Treadmill...
Motor hot and smells
Step 1:
Please LUBE the deck belt+rollers bearing INMEDIATELY and proceed according see the video attached.God bless you
Step 2:
test the motor drive belt for loose
+ test the input voltage motor and see my personal TIPS for motor help.
Step 3:
test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram attached. use the VOltmeter.
Jan 03, 2013 | Keys Fitness Ht502 Treadmill Motor...
Treadmill only works for 15 secs
1) If the the belt is moving during that time then stop I would suspect that speed sensor maybe defective. Replace the sensor
2) Now if their is no belt movement then either Motor Control board or Drive Motor is defective. Do Motor Test
I would check the drive motor first to eliminate an expensive component, unplug unit then remove motor shroud then unplug the connectors leading to the motor itself. If you have wire leads and a 18v drill battery2_bing.gif connect the leads into motor then attach the other end to you battery and if the motor will rotate ( approx. 1mph) if that is accomplished then the only other component to be replaced would be the Motor Control Board. Call Matrix for parts @ 1-866-693-4863 option 3
May 14, 2010 | Matrix T3Xi Treadmill
Exercise & Fitness Logo
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
