Question about Polaris Ranger RZR Ride on Toy
Reverse doesn't work - Polaris Ranger RZR Ride on Toy
    Genius:
  • 1,016 Answers
You need to check that the switch under the pedal is operating correctly.
If that is ok make sure that the power is get in the polarity box which is either under the seat or by the rear axle, if this is getting power then check that the power is reversing polarity before it gets to the axle motor.
This can be the only area where you will have a problem as it would not go forward if there was a problem with the axle drive motor.
Let me know how you get on, or if you need more information.
Thanks
Jason
Posted on Aug 04, 2010
I have a polo classic 97" model rev speedo doesn't
I tried the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. it wont move forward or reverse, engine is good both solenoids for forward and reverse work.
I don't have much technical knowledge but I just followed it step-wise, and works perfect!
got it from www.reliable-store.com
Feb 25, 2018 | Cars & Trucks
Reverse Light doesn't work, fuse good and bulb to.
I haven't worked on an escape, but i can tell you that switch is on the transmission.
Jun 02, 2013 | 2010 Ford Escape XLT
No reverse o transmission
run fault codes and look for reverse solenoid fault.
Apr 26, 2013 | 1994 Volvo 850
I got my 2001 dodge ram 1500 with the 5.9L v8 stuck in the sand at the beach. While my buddy was pulling me out from behind, I was flooring it in reverse to get out. Then my my rpm went down and the...
Need more info: is manual shift if so 4sp ,5sp or 6sp speed?
or auto w/overdrive ?
2) wont go into gear or selects reverse gear but acts
like no gear?
3) does forward gears work?
4) how's the fluids?
Jan 30, 2013 | Cars & Trucks
Shredder doesn't shred.
Shreader wont cut will reverse ok
Dec 17, 2012 | Office Equipment & Supplies
I have a 1993 mercury grand marquis and reverse doesn't work after it warms up. It does work when cold.
You can check with a local transmission shop, but usually the problem is a worn band or a weak pump. The reverse band also affects low gear.
There may also be a solenoid involved.
Sep 15, 2012 | 1993 Mercury Grand Marquis
1996 Jeep Grand Cherokee. Transmission problems. when the gear selector is in reverse, it doesn't engage in reverse. When you go to neutral, it drives forward but doesn't shift through the...
Put the vehicle in Park, disconnect the shifter from the shift lever on the trans, adjust the linkage or cable so the connection is clearly a slip in/on connection and tighten things back up. Hopefully this will solve your non-reverse. As for all the gunk and metal shavings, friend, you better have another tranny standing by in your garage when this one stops working completely.
Jun 09, 2017 | Jeep Grand Cherokee Cars & Trucks
JAMMED SHREDDER
if you have reverse, run reverse.
if you don't have reverse, you will have to disassemble the drive shaft/cutters and clear manually
Apr 05, 2010 | Aurora Electronics AS662C Shredder
Transmission works fine in Drive, but reverse doesn,t work
The possiblities for your problem are: Worn out lo-reverse clutches, broken sunshell, fluid leak in the reverse apply circuit, or a worn boost valve. You are looking at having to replace or rebuild your transmission for this one.
Feb 26, 2010 | 1999 Chevrolet Silverado 1500
Polaris Ranger RZR Ride on Toy Logo
85 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
Gregg Mahin
Gregg Mahin
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
