Question about Acer Altos G710 Server
The SMPS fan is not working properly, so what i do now
  • 111 Answers
Replace yr SMPS, thats the best option.
Posted on Aug 04, 2010
Computer won't start up
Firstly check the power supply and all the cable are properly are plugged or not.
After check The SMPS FAN are working or not or cpu fan is working or not .
put out the ram and properly make it dust free. and after put is properly.
Apr 30, 2012 | Dell Dimension E521 PC Desktop
Chassis fan not detect
there are two ways a chasis fan can be connected....
1)to the motherboard(it should detect)
2)directly to the SMPS(it wont detect)
if its connected to the SMPS, then remove and plug to the fan port for external fan on your motherboard.......i wud personally advice you to leave it as it is if the fan is working properly......moreover its not necessary for the chasis fan to be monitored....HOPE IT HELPED................DO VOTE IF IT HELPS.........
Jan 18, 2011 | Compaq (283983-001) Motherboard
Seams like fan not working
if the fan is not working first you have to test the smps remove the smps connector from the motherboard and short the green and black pin it he smps fan is working then the smps is fine coneect the smps connector to the motherbord and switch on the computer still not working then remove the four pin connector from the smps and restart your computer if irts working the problem is in your motherboar
Dec 30, 2010 | Dell (6F858) Cooling Fan
I am able to turn on cpu but the monitor is not displaying it. Power is coming, Two fans are running in C.P.U. Some times fans not work. Kindly suggest me why this happens and give the solution for it.
093aba5.jpgYou have a problem with your SMPS. Kindly send your SMPS to a repairing shop. If the guy suggests you to buy a new SMPS then there is hardly anything that u can do instead of buying a new one. I had the same problem once had to replace the SMPS as even after two repairs the SMPS wasn't working properly. There is a prob with the switching regulator for sure if your monitor works perfectly then.
Sep 24, 2010 | Computers & Internet
My Smps is ok, when i switched on smps fan and processor fan not on
Check Following Instruction:
1. If your SMPS ok, Check 20 pins cable connect properly to the motherboard, or Fan 4 pin connect to the motherboard.
2. And Start your Motherboard. It will OK.
Apr 13, 2010 | Intel Motherboard
My new cpu can't start
I think there was some hardware issue in your CPU,if RAM is unplg or loose in that condition CPU will be not working,Replug the RAM properly and start the system if still cpu not working thats mean there was a problem with your cpu SMPS fan (place backside in cpu for cooling),cpu fan SMPS is not support,Please change it.
good luck..
Please rate me....
Thanks
Mar 25, 2010 | Sony VAIO PCV-W600G PC Desktop
System starts up, lights on power system but no
i thought that this problem due to the smps . the pg signal of the smps not send to the motherboard properly. replace the smps.
Aug 14, 2009 | NZXT Computers & Internet
CPU fan not detected
replace ur cpu fan...... if u hv a problem with SMPS the fan which u can see at the back of ur cpu do replace it.. this SMPS provides all the power requorements for ur CPU
Jun 29, 2009 | Computers & Internet
CPU is not getting started
In SMPS 20 pin Connector please short the green and black wire with a twisterand on the smps. if the fan is rotating then the smps is ok
Jun 19, 2008 | Intel D845GVSR Motherboard
Asus Premium Vista M2n32-Sli
Dear Riddler2002,
First thing u have to check the SMPS if it is not working properly then it will restart automatically not working properly it means that the SMPS not giving the excact power supply to mother board now the question is how can u check the SMPS working fine or not do one thing borrow a SMPS through u r friend connect that SMPS to u system if it working with u r friends SMPS then u have to change u r SMPS if still u r getting same problem then u have to check u r system RAM if RAM not work Properly then it will get this type of problem so Change the RAM and connect another RAM to u r system if the RAM is working fine then it will work properly.
Regards,
Bittu_8
Feb 13, 2008 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Acer Altos G710 Server Logo
88 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
