Question about EuroSteam Vapor Steam Cleaner Vacuum
Karcher Vaporapid 1501 Having trouble removing the safety cap. Also water doesn't heat enough to produce steam
2 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: my mini steam zapper heats but produces no heat
you should get steam in the amount of time it take to boil water
Posted on Feb 18, 2009
My shark steamer is foaming and no steam is coming out
You cant put soap in the steamers, only water. Clean out water container and start new. Also, clean hole where steam comes out with something thin. Make sure it is heating up enough to produce steam, otherwise heat assembly is broken.
Mar 08, 2017 | Shark Vacuums
Tip
Shark steam mop not producing steam
It is a design flaw having a check valve orifice built into the steam generator.<br />The plastic sleeve gets hot and get hard and shrinks enough to cause blockage at the inlet to steam generator.<br />Also a lot of sediment builds up inside steam generator from impurities in the water which eventually causes a problem and block at the mop head.<br />solution would be to move the check valve from the steam generator to the pump discharge line where it is cooler. and use only distilled water. they should also use a stainless heater element instead of pot metal as it corrodes.<br />
on Apr 24, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Karcher vaporapid 1105 manual
there should be a labeled fill line on the clean water resavore
Mar 26, 2014 | Karcher Vacuums
Cannot unscrew filler cap from steam cleaner SC 1.020
Get under it with something like a butter knife and lift with the knife while you turn it.
Mar 13, 2014 | Karcher Vacuums
Shark S3101 Steam Mop won't produce steam
You have to use distilled water in the steam mop. regular water clogs it up and causes it not to work.
Nov 27, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My polti vaporetto 2300 is belching with steam,have changd the safety cap seal,but hasn't helped --any ideas
My polti 2300 vaporetta is heating the water but not getting up to steam, could the problem be the safety cap?
Nov 17, 2010 | Polti Eco Pro 3000 Canister Steam Vacuum
I have just used the karcher steam cleaner and now cannot get the safety top off. Rio
i cannot get the cap off my karcher sc1122 even though its cooled down
Nov 16, 2009 | Karcher 1201 Canister Vacuum
Karcher SC 1502 steam cleaner can't get cap off water tank
Dear jrider784,
I solved a problem like this on FIXYA, just a few months ago. I gave this solution. Try to fill the machine from somewhere else. You can do this from the outlet. If you manage to do this, put on the machine. ( now you know that when there is hot water in the machine, the tap goes round free for safety). Now as the water starts to cool down....start trying to see if you can unscrew it. My plan is that with the hot water, the safety will start to work again. If the cap does not release the safety on cooling, then there is no other way but to destroy the cap and replace with a new one. Very important to mention that this job must be done by a qualified technician or some one who knows what he is doing. Working with hot water is very dangerous.
Regards,
Fulltech.
Jul 27, 2009 | Karcher DE4002 Steam Vacuum
My mini steam zapper heats but produces no heat
Feb 18, 2009 | EuroSteam Vapor Steam Cleaner Vacuum
EuroSteam Vapor Steam Cleaner Vacuum Logo
844 people viewed this question
Top EuroSteam Vacuums Experts
Marvin
Marvin
Are you an EuroSteam Vacuum Expert? Answer questions, earn points and help others
