Question about Autodesk AutoCAD 2004 for PC
How to install autocad 2004 in windows 7 - Autodesk AutoCAD 2004 for PC
  • cma_mcp
    cma_mcp Jul 07, 2013
    Also worked Autocad 2007 for Win 7.
  • Md Zakir Hossain
    Md Zakir Hossain Aug 19, 2015
    New Friend:
I had no issues installing AutoCAD onto a Windows 7 x86 Professional system. User is making and saving new drawings as well as opening existing drawings.
AutoCAD 2004 works fine on Windows 7 Professional 32-bit.
Posted on Jan 17, 2013
    New Friend:
  • 10 Answers
I've been searching around for a solution for my AutoCAD 2004, and have now found one - so I thought I'd update everyone on Fixya since I've always used the solutions and never posted! I used a tool called the Longbow Converter, it installed my AutoCAD 2004 on 64bit Windows 7 perfectly - hope it helps. Nex
Posted on Aug 17, 2012
    President:
  • 2,340 Answers
Autocad 2004 is not compatible with Win 7. You have to install Autocad 2010 for Win 7.
FYI,
Windows 7 Support for Autodesk 2010 Products
Published date: 2010-May-25
Applies to:
AutoCAD® 2010
AutoCAD® Architecture 2010
AutoCAD® Civil 3D® 2010
AutoCAD® Electrical 2010
AutoCAD® Inventor LT™ Suite 2010
AIP 2010 with Autodesk Inventor Tooling 2010 Add-In
AutoCAD® Inventor® Professional Suite 2010
AutoCAD® Inventor® Routed Systems Suite 2010
AutoCAD® Inventor® Simulation Suite 2010
AutoCAD® Inventor® Suite 2010
AutoCAD® Inventor® Tooling Suite 2010
AutoCAD LT® 2010
AutoCAD® Mechanical 2010
AutoCAD® MEP 2010
Autodesk® Algor® Simulation 2010
Autodesk® Productstream® Professional 2010
Autodesk® Vault 2010
Autodesk® Vault Collaboration 2010
Autodesk® Vault Manufacturing 2010
Autodesk® Vault Workgroup 2010
Posted on Aug 05, 2010
5 Suggested Answers
RescueTechLA
  • 2653 Answers
SOURCE: AutoCAD 2004 / Windows 7 compatibility?
If it works in Vista you shouldn't have any problems. Easiest way to find out is to install it!
You can always just uninstall the program fi you run into problems.
Posted on Dec 06, 2009
WhiteFox4
  • 641 Answers
SOURCE: I am trying to install AutoCAD 2004 on my new
Windows 7 is a 64 bit operating system, and autoCAD is only 32 bit software, which is not compatible with this operating system.
Posted on Jan 03, 2010
  • 261 Answers
SOURCE: NEED TO INSTALL AUTOCAD 2004 OR 2005 ON WINDOWS 7
you must download last version
Posted on Aug 10, 2010
SOURCE: when I install autocad2004 in
yes can be, just follow these steps:
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Posted on Dec 06, 2010
Autocad 2004 win7
pleas do not install any antivirus after the instalatio of window s 7 after installation of window 7pleas install all the softwere that you need to use and then install any antiviurs i hope all the softwere or programs work properly
Apr 08, 2014 | Autodesk AutoCAD 2004 for PC
How to install autocad2004 on windows 7
On window 7-32bit, you can install AutoCAD 2004 normally, but AutoCAD 2004 is not supported on window 7-64bit
Aug 28, 2011 | Autodesk AutoCAD 2004 for PC
My autocad installer is autocad 2007 while my pc is windows 2007 when i install the installer it was a success but my problem now is the worksite wont appear it doesnt run
I've been searching around for a solution for my AutoCAD 2004, and have now found one - so I thought I'd update everyone on Fixya since I've always used the solutions and never posted! I used a tool called the Longbow Converter, it installed my AutoCAD 2004 on 64bit Windows 7 perfectly, the website says that it supports your version too - hope it helps. Nex
Apr 30, 2011 | Computers & Internet
When I install autocad2004 in windows 7 ,autocad can't run. untill now AutoCAD 2004 can't be compatible with a Windows 7 ?
Nov 29, 2010 | Autodesk AutoCAD 2004 for PC
How to install autocad 2004 on windows 7
Autocad 2004 is not compatible with Windows 7. Use a newer version.
System Requirements
For 32-Bit AutoCAD 2011 @
http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=13784795
Aug 09, 2010 | Autodesk AutoCAD 2004 for PC
AutoCAD 2004 for PC: Are AutoCAD 2004 and Windows 7 compatible?...
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
May 18, 2010 | Autodesk AutoCAD 2004 for PC
I am trying to install AutoCAD 2004 on my new computer with windows 7 and wont install. Any ideas?
AutoCAD 2004 and Windows 7 are NOT compatible. You will need to upgrade to AutoCAD 2010 either 32-bit or 64-bit. Even with the upgrade, there are known limitation issues.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14056444&linkID=9240617
Jan 03, 2010 | Autodesk AutoCAD 2004 for PC
Dec 05, 2009 | Autodesk AutoCAD 2004 for PC
Autodesk AutoCAD 2004 for PC Logo
9,169 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Alex Krenvalk
Alex Krenvalk
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
