Question about Canon imageRUNNER C3200 Copier
Plesae describe the error code E00020 - Canon imageRUNNER C3200 Copier
  • 1,219 Answers
E020 There is a fault associated with the drum/developer.
For the first 2 digits of detail code xx12 through xxD0,
xx=01: Y
xx=02: M
xx=03: C
xx=04: Bk
xx20
xx24
xx25
xx30
xx34
xx35
xx40
xx50
The fault can occur as when a new drum
unit has been fitted. It is detected in about
90 to 120 sec after idle rotation of the developing
assembly.
unit has been fitted. It is detected during
ATR control or in about 150 sec after idle
rotation of the developing assembly.
assembly.
unit has been fitted. It is detached during
assembly.
The fault occurs when an image is being
formed. It is detected when toner supply
operation is started.
There is a fault/open circuit in
the ATR sensor. The drum unit
is not fitted normally, or is
faulty.
the SALT sensor.
the SALT sensor.
The ITB has deteriorated.
the ATR sensor. The setting of
the ATR sensor computation
value is wrong. The drum unit is
not fitted properly, or is faulty.
The sample image fails to be
drawn in ATR control. There is
a fault/open circuit in the SALT
sensor. The drum unit is faulty.
the SALT sensor.
The ATR sensor communication
value is faulty. There is a fault/
open circuit in the ATR sensor.
The drum unit has been fitted
improperly. (The machine cannot
detect the drum unit). The
The developer concentration
computation value is faulty (set
when a new drum unit is fitted).
xx60
xx70
xx80
xx81
xxA0
xxB0
xxC0
xxD0
target value is faulty (set when a
new drum is fitted; the value is
extremely small).
new drum unit is fitted; the
value is extremely small).
The actual value is considerably
high in relation to the ITB surface
reflectance when a new
drum unit is fitted. The SALT
sensor is faulty.
drum is fitted.
The measured value of the developer
concentration is considerably
low. The ATR sensor is
faulty. The SALT sensor is
faulty. The ITB is soiled.
The drum unit is approaching
the end of its life and is causing
the T/D ratio to drop. The ATR
sensor has an open circuit.
The supply of toner for the toner
container to the developing assembly
is faulty. The developing
assembly is supplied with toner
excessively. The ATR sensor has
an open circuit.
has failed. The toner
cartridge motor fails to rotate.
The toner container is empty.
The toner supply mouth of the
drum unit is damaged. The ATR
code xxEE,
xx=00: fault in access to drum
unit
xx=01: fault in access to toner
container
The fault occurs while ATR control is being
executed.
executed.
formed.
formed and, in addition, when the T/D ratio
drops while 20 prints are being made
continuously. It is detected when toner
supply operation is started.
Posted on Aug 04, 2010
Copier IRC 2570. What is the corrective action for error code e00020-0193?
Drum,developer related error,in your case yellow.Check the toner leak from toner buffer in the developing unit
Jun 27, 2015 | Canon Office Equipment & Supplies
Error code e00020-190
describe this error code as per the manual
Jun 20, 2015 | Office Equipment & Supplies
How to fix error code E00020-0022 on Canon Printer
I suggest you go to http://www.usa.canon.com/cusa/support/consumer
This is Canon's official (free) help site. You'll need your model# to find the right error code answer as every machine seems to have its own set of codes. They'll give you what the code means & how to fix it. Good luck!
Feb 11, 2015 | Canon Office Equipment & Supplies
Canon IR C 2880 Error code E00020-0101
This error code refers to the fuser unit not reaching temperature. A new fuser is required.
Feb 26, 2013 | Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
E000020-0010
you have a problem with your developer or toner add assemblys toneris not going into your dev unit
Aug 15, 2009 | Canon imageRUNNER 7200 Copier
Canon iR C3200 E00020 02d0
check or change the magenta drum unit
Jul 29, 2009 | Canon imageRUNNER C3200 Copier
Error code E00020-03a0
hello josephusjose,
E000-03a0-
this means that there problem with the CYAN drum /developer unit in case your machine is IRC 3200 series
Changing this unit will fix your problem
Jun 23, 2009 | Canon Office Equipment & Supplies
Error codes E00020-01b0
you need to replace your yellow drum unit with a new one, error code is as follows E020-01(yellow), -02 magenta, -03 cyan, -04 black. for future referrance
Jun 05, 2009 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3200 Copier Logo
352 people viewed this question
old marine
old marine
