Question about Casio Exilim EX-Z750 Digital Camera
I have to reset the country date time etc every time i turn my camera on, i have tried going through menu and reset but this hasn't solved the problem. Please help
    Problem Solver:
  • 10 Answers
There is a built in battery that can keep the time date etc. info for 20 something hrs. without any other source of power. If your camera has a charged battery, is plugged into an active USB or powered by an adapter and you shut it off and then immediately turn it back on again, what happens? If the clock needs to be reset are you sure that you have completed setting the time. After adjusting all the settings you hit set. Most likely it seems that your internal battery is bad. It should charge when the camera is being powered by the main battery.When you say every time you turn it on I'm not sure what that means. If you turn the camera off and remove the battery for more then 30 hrs. it will have to be reset. If that is the case you need to leave a fully charged battery in long enough to charge the built in battery. If the built in battery is bad you will need to find out if it can be replaced.
Posted on Aug 07, 2010
How do I reset my canon a95
Try removing the battery for 15mins. then replace the battery. Then go to the camera's Menu and set the Date & Time.
Nov 18, 2012 | Canon PowerShot A95 Digital Camera
Date/Time resets every time i turn on camera.
Hi, yes, there is a small coin memory battery, usually something like a CR3032 lithium battery. Turn off the camera and insert a new 'coin' battery (correct side up). Close battery cover, turn on camera and go to menu and set time and date. It should remember the time and date for a year or two, provided you put a regular battery on the camera on a regular basis. Also note, some older Sony cameras allow you to set it so that it shows only the date for the 1st 5 seconds when you first turn on the camera that day, then shuts it off unless you want it to superimpose the time and date on the video. Good luck, and let me know if this solves your problem. John
Jan 17, 2012 | Sony Handycam HDR-XR520 High Definition...
Have never set date on my camera. What do I need to do to accomplish this? Do I needsoft ware, any cords, etc? Tried to go by instructions on line but it didn't work. What am I missing? Thanks
Welcome to FixYa,
Hi I have here the steps on how you can update the date and time of your digital camera. You can chaged it if its your first time to set the date and then you also have here the steps if you want to changed it anytime you want.
Setting the date & time, first time
The Date and Time have been reset message appears the first time you turn on
the camera or if the batteries are removed for an extended time.
1 SET DATE & TIME is highlighted. Press the OK button.
(Select Cancel to set the date and time at a later time.)
2 Go to step 4 below, Setting the date & time, anytime.
1 Turn on the camera. Press the Menu button.
2 Press to highlight Setup Menu , then press the OK button.
3 Press to highlight Date & Time , then press the OK button.
4 Press to adjust the date and time. Press to advance to the next
setting.
5 When finished, press the OK button.
6 Press the Menu button to exit the menu.
Reminders:Depending on your computer operating system, Kodak EasyShare software may let your computer update the camera clock when you connect the camera.
I hope this steps will let you to resolved your issue.
Feel free to reply on this e-mail if this steps will work or won't work.
Thank you for using FixYa.
Mar 23, 2011 | Kodak EasyShare CX7330 Digital Camera
I have to reset date time etc everytime i turn camera on
If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
1. Confirm that the camera power is turned off.
2. Slide the memory card slot / battery cover lock and open the cover.
3. Hook your nail onto the date battery holder and lightly pull up.
4. Remove the battery holder in the direction indicated by the arrow. a570isbackupbatremove.gif 5. Remove the battery by pulling it up in the direction indicated by the arrow.
a570isbackupbat.gif 6. Insert a new battery with the (-) side facing up.
7. Replace the battery holder and close the memory card slot / battery cover.
8. When the Date/Time menu appears set the date and time.
Feb 05, 2011 | Canon PowerShot A590 IS Digital Camera
How do I set date and time
1. Press MENU to enter SET UP menu.
2. Press right or left arrow to reach the settings.
3. Then go on to view the menu
4. Find Reset Camera Settings.
5. Reset your camera.
6. Turn on the camera
7. Date/Time settings will appear.
8. Set your date/time.
Jun 03, 2010 | Kodak EasyShare V550 Digital Camera
Camera Keeps Restarting
What we always did at tech support was had the customers take out their memory cards first. Power on the camera, press the menu button, go to setup, go down to reset, press right arrow and cofirm through there. Then press menu again, go to setup, go down to format, press right arrow and confirm again. You will have to enter your time and date HOPEFULLY one last time. Try it and if that doesn't work then it is an internal electrical error and needs to be sent in. :)
Mar 20, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Setting date, time, etc.
just go to menu dude!....
go to adjust time and date...
its prett much easy from there.
Mar 16, 2008 | Casio Exilim EXZ75 Digital Camera
Set date and time comes up every time i turn on camera
Try resetting your camera. In picture taking mode press menu. Go to setup, go up to reset, press right arrow, make sure reset is highlighted and press set.
Then TAKE OUT MEMORY CARD. Go back into menu, go to setup, go up to format, press right arrow and highlight format, press set. Input ur date and time again and then power off and back on. If that doesn't help then you have to send into repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Feb 11, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Having to reset date and time
Solution: Replacing the date battery PowerShot A510 and A520
Replacing the Date Battery If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase. caution_a70.gifBe particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids could damage the stomach or intestinal wall.
  1. Confirm that the camera is turned off.
  2. Open the terminal cover and use your finger nail to pull out the battery holder.
  3. Pull open the battery holder in the direction indicated by the arrow (1). Remove the battery by pulling it up in the direction indicated by the arrow (2).
  4. Insert a new battery with the ( ) side facing up.
  5. Replace the battery holder back and close the terminal cover.
  6. When the Date/Time menu appears, set the date and time.
note_icon_a70.gif After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery. If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your country.
Dec 24, 2007 | Canon PowerShot A520 Digital Camera
Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Nov 06, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
260 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
