Question about Maxtor Hard Drive
How do i set the jumper when installing diamond max plus 9 80gb as a 2nd disk what does cs enabled mean thank you
  • 724 Answers
.....< slave is last 2 horizontal
^ is master jumper vertical
The new 80 conductor to 40 pin socket connector IDE cable does not use CS
Any thing on the maxtor lable has the location of the reference pins
Posted on Aug 19, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 122 Answers
CS means Cable Select .Parallel data cable have two conectors.If you set jumper set on CS ,in this way ,example,you have two HDD when you plug parallel data cable in middle connector ,1 Hard drive working like Master ,2 HDD work like slave,if you plug in last connector First HDD working like slave,second HDD Master.
http://www.tacktech.com/display.cfm?ttid=379
Posted on Aug 12, 2010
4 Suggested Answers
mumma_1
  • 903 Answers
SOURCE: diamond max 20 hard drive won't install - jumper problems - want as slave, my old one as master
on the back of the drive there should be a black, white or yellow jumper. If you look very carfully at the back of the harddrive where the jumper is, it will tell you which position you need to have the jumper in for slave and which position you need to have it in for master. If it is already in the master position, carefully pull it out then push it back into the correct position to act as slave. Some hardrives simpley have a M for master and a S for slave while other harddrive will actually have the words. I hope this helps.
Posted on Oct 23, 2008
  • 17 Answers
SOURCE: need jumper settings wd800 as Mast. & maxtor Dia.plus as slave??
To use the WD 800 as a master there must be no jumper attached to it.The maxtor has a diagram for the jumper and it MUST be set to slave not cable select.
Posted on Mar 24, 2010
  • 110 Answers
SOURCE: what is the jumper setting to service (format) the
This document might help you:
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/diamondmax_plus_9_manual.pdf
Posted on Oct 06, 2010
Jumpers Serttings on Quantum HD
CS = Cable Select
DS = Master
SP = Spare (Slave)
Nov 10, 2013 | Maxtor Computers & Internet
Where does the jumpers go on 1st+2nd harddisk? master+slave? cs+cs?
Look on the back of each hard drive. It shows you where to set the jumpers for the master and slave. Make sure you have them in the correct sequence.
Feb 13, 2013 | Gateway Computers & Internet
Im trying to install my harddrive but im not sure about the jumper settings
If you are installing the hard drive in the desktop computer, and this is going to be the boot disk then the jumper should be set to MA (Master) and the drive should be connected to the end of the data cable and the other end of the cable should be plugged into the 1st disk controller.
If the BIOS does not detect this as the primary hard drive then the jumper will need to be set to CS (cable select). Check the BIOS again to see if it detects the hard drive.
If you are installing the hard drive as a 2nd hard drive and you are putting it on the same cable as the 1st hard drive then the jumper needs to be set as SL (Slave).
If you are installing the hard drive on the 2nd disk controller and there is no other devices on this data cable then it does not matter if it is set to MA or SL. but if the is a CD/DVD drive on the cable too then the jumpers must be set differently on each device.
Dec 05, 2010 | Maxtor Hard Drive
How to set jumper to slave mode on maxtor 6y080m0(picture pls)
These are the jumper settings for a Maxtor Diamond Max ATA hard drive.
Sep 23, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
When installing a Maxtor Quantum Fireball Plus AS 20.5-GB hard drive as a second drive on a PC. You want the drive to be the slave drive, and you know what that you must change the current jumper settings....
DS=drive select meaning selected drive by the bios CS=Cable select meaning if you hook it to the second plug so set the jumper to CS and hook drive to the second cable if its is ide drive which that is what it sounds like the drive is!!
Jul 21, 2017 | Quantum Fireball Plus AS (QMP20000AS-A)...
Need jumper settings wd800 as Mast. & maxtor Dia.plus as slave??
Mar 24, 2010 | Maxtor DiamondMax Plus 9 160 GB Hard Drive
Maxtor harddrive jumper setting
If you only have a single hard drive (or multiple hard drives for that matter), you should leave the jumper setting as "Cable Select" or CS.
See if this PDF matches your hard drive:
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/quick_specs/dm10_ata_quickspecs.pdf
Apr 22, 2008 | Compaq Presario SR1800NX Desktop PC
KHCRW 52 24 52 CD-ReWriter not recognized
Change the Jumper To Master Or Slave.
CS Is cable Select, your computer may not support this Option.
If installing on a cable with a drive, already connected. i.e hard-disk. if the hard-disk is slave set the cd rom to master.
Enabling both channels, is the 2 individual slots on your motherboard. Primary And Secondary. Or IDE 1 And IDE 2.
This will solve your Problem.
Mike @ compurepair.
Feb 20, 2008 | KHypermedia (KHCRW522452) (20326452) CD-RW...
Video and photo files
Dear Friend,
Point your browser to
http://stason.org/TULARC/pc/hard-drives-hdd/maxtor/87000D8-DIAMOND-MAX-7000MB-3-5-SL-ATA3.html
or
for more drives to
Alternatively
JumpersMAXTOR DIAMOND MAX INSTALLATION SHEET
Jumper Setting
+---+---+---+---+---+ |J50|J48|J46|J44|J42| +-------------------------------------+---+---+---+---+---+ | Master/Slave | | | | | | | Only Drive in single drive system* | J | | | | | +-------------------------------------+---+---+---+---+---+ | Master in a dual drive system* | J | | | | | +-------------------------------------+---+---+---+---+---+ | Slave in a dual drive system | O | | | | | +-------------------------------------+---+---+---+---+---+ | Cable Select | | | | | | | Disabled* | | O | | | | +-------------------------------------+---+---+---+---+---+ | Enabled | | J | | | | +-------------------------------------+---+---+---+---+---+ J=Jumpered O=Open *=Default
Feb 05, 2008 | Computers & Internet
Maxtor Hard Drive Logo
682 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
