Question about Cycling
My son's 2005 10" Dynacraft Rhino Road Racin Bike's pedal (and whatever holds it's in place) fell off and is gone. How do I fix this problem (e.g. pedal parts and replacements)?
    Brigadier General:
  • 8,546 Answers
Bike Shop
Posted on Aug 05, 2010
Dynacraft Girls 16" Barbie Bike pedals don't move
The problem could be the coaster brake hub, it could be that the cranks are not properly adjusted, or any number of other weird things. My advise--take it to a bike shop. If they're kind, they should be able to get things moving in the proper circular motion quickly for a reasonable charge. If they're not kind, they'll laugh at the bike first, but they will still help.
Dec 28, 2013 | Dynacraft Girls 16" Barbie Bike
How do I fix a bike pedal that fell off and is stipped?
If the pedal post is stripped get a new pedal. If the crank side of it is stripped you can just replace the crank and put new pedals on it.
Aug 12, 2012 | Shimano Cycling
Left pedal arm for a barbie bmx bike broken. Where can I find a replacement?
You should talk to your bike shop because they can find the correct one and also install it because you need expencive bike spicific tools to remove them and replace.
Jul 22, 2011 | Dynacraft Girls 16" Barbie Bike
REAR WHEEL WONT TURN WHEN TURNING PEDALS
Take it to a bike shop because it could be any number of things. It could be a very cheap fix like lubricating everything or as expencive as needing a new hub and cassette
Jul 18, 2011 | Dynacraft Cycling
My son has the Huffy rock out bike. The pedal fell off, and so I was sent the whole single arm crank and new pedals. I have no owners manual, and no assembly instructions whatsoever. Along with the crank...
The reason the pedal fell of is because of a bad set up. Who assembled the bike? If, you did, guess what! You did not tighten the pedal to the crank arm to begin with. If, Walmart or other discount store did it, have them fix it. You have to understand. you bought the bike without professionals putting it together and sometimes that is a problem when you don't have the knowledge of what you are doing. You have to pay one way or another. When you let a kid ride a bike that is not assembled correctly you are endangering them. My advice is :Get it fixed right.
Sep 16, 2010 | Huffy Cycling
Barbie bike petal broke
You'll have to replace the pedal-it's not really wise or safe to reuse or fix the old one if they break.-they may hurt your little one's feet.
On a side note, pedals are usually only sold in pairs, so you would have to replace both of them-if you want them to match.
Also, take note: the left pedal is a left hand thread, the right pedal is a regular(right-hand) thread. This is so they don't unscrew while the bike is being pedaled. On a standard bike you need a 9/16" wrench to screw/unscrew the pedals. Put the wrench where the pedal goes to the crank, and unscrew it there. The left hand thread means it will be the opposite of the "righty-tighty,lefty-loosey" rule for unscrewing normal right hand thread screws.
Might want to hit it with some penetrating oil and let it soak for a bit, before you try breaking it loose, it might be stiff!
Hope this helps!
Nov 07, 2009 | Dynacraft Girls 16" Barbie Bike
How to remove a 1994 magna road warrior crank????
hello you need a crank extractor when you get 1 take plastic cover off the pedal you should see a nut this hold the pedal on take it off then with your crank extractor screw the first part on then screw the second part start to turn you should see the pedal start coming off do this on both sides once of there should be a ring with notch in it take this off you will see bearing case beware there might be bearing loose .replace bearing cases make sure you use plenty of greese good luck
shaun
Aug 06, 2009 | Dynacraft Cycling
Cycling Logo
161 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
