Question about HP Officejet 5510 All-In-One Thermal Printer
All 3 lights (coy, fax, scan) blinking, error message OxfOaf8004. it won't turn off or operate. what can i do?
    President:
  • 2,340 Answers
Canon MF4770n error light is flashing and there is no error. How do you get the light to go off?
IF the LED screen shows "TONER IS NEARLY OUT", the "ERROR" light will constantly blink and the "ENERGY SAVER" Feature is disabled YET printer copy-fax-scan operation working properly, the solution will be to replace the toner cartridge. This will solve these issues.
Sep 20, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
My Canon P-150 keeps giving me a "double feed" error and won't scan.
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer. Then reinstall software again
Jun 07, 2012 | Canon imageFORMULA P-150 Personal Document...
I've been trying to send a fax to an office in Sri Lanka for several days now, but it won't go. We are getting a Comm Error 388 in the fax error report. The unusual thing is we are able to send fax...
inernational fax calls quite often do not work on digitized phone lines or via satellite. You cannot fix that. maybe your fax has a "fallback 4800 bps" setting that might be helpful.
May 11, 2011 | Office Equipment & Supplies
I have a FO-2080 fax machine and it is displaying a message system error (E1-00) and will not work at all.
Page 69 on operation manual suite Source: http://files.sharpusa.com/Downloads/ForBusiness/DocumentSystems/FaxMachines/Manuals/fax_man_FO2080_suite.pdf
Error indicator is lit or blinking.
SYSTEM ERROR [XX - XX] REFER TO USER GUIDE
When [L1-00] appears, the scan head locking switch is locked. Turn off the power, release the scan head locking switch, and turn the power back on page 13 on the manual
The machine will not function. Turn the power switch off, wait about 10 seconds, and then turn on the switch again. If this does not clear the error, remove the power cord from the outlet, and contact your SHARP service center.
Mar 08, 2011 | Computers & Internet
Hp 1315 all in one won's scan
Does the copier make good photo copies?
Do you see any lights blinking?
Is there any error messages displayed on the computer screen?
What is the computer operating system?
Aug 18, 2010 | HP PSC 1315 All-In-One InkJet Printer
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
Error message Vista Fax setup
Right Click on My Computer icon and go to manage. Go to event viewer and under the System (and also Application) categories, check for errors.
In the same window, go to Local Users and Groups->Users->Your user profile->Member Of and check whether you have sufficient rights(are you an Admin???), then go to Seervices and check whether the Service can be started in your profile.
Thanks.
Good Luck.
If the solution is helpful, please rate the answer kindly.
from
Jul 06, 2009 | Computers & Internet
I've tried trouble shooting "print cartridge error" plus print still in queue message. I've cleared both but messages still returns with copy, fax and scan lights blinking.I've tried the posted fixes but...
I had this exact error not to long ago. There was nothing in the book to help. I just finally changed my black ink cartridge. That stopped the error message.
So if you haven't tried that, put in new cartridges. Hope this helps.... :0)
Apr 26, 2009 | HP Officejet 5510 All-In-One Thermal...
Red light blinking and printer error "check printer ##330" appear
## 330 Power Supply (Replace/Repair)
Replacement part number is HH3-5278
Apr 22, 2009 | Canon LaserClass 7000 Plain Paper Fax
Hi, Remote Fax Error being displayed
As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
Note: The scanned documents will only be saved in the memory before the whole fax is sent if the Scan Before Dial option is turned on. (This is the factory default.) Up to 50 black-and-white fax pages can be stored in memory at standard resolution when there are no pending faxes in the queue.
Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX mode.
Press Select.
Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
Change the setting from Yes to No using the + (right arrow) button.
Press Select.
Note: The Scan Before Dial option controls whether a document is scanned before a call is dialed. This parameter only applies to a mono fax that uses either 200x100 or 200x200 resolution. Higher resolution mono faxes and all color faxes are scanned after the call is dialed and the receiving machine's capabilities are known.
Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX.
Press Select.
Press Options 10 times until MAX SEND SPEED appears on the LCD display.
Change it to 9600 BPS using the - (left arrow) button.
Press Select.
Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
Press Select.
Press Options 11 times until ERROR CORRECTION appears on the LCD display.
Change the setting from On to Off using the + (right arrow) button.
Press Select.
Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes. The X6100 Series only supports 1-D MH encoding with the error correction. Fax transmissions without ECM and other ECM types can result in bad quality on the received page.
Dec 19, 2007 | Lexmark X5470 All-In-One InkJet Printer
HP Officejet 5510 All-In-One Thermal Printer Logo
137 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
