Question about Nintendo 64 Console
N 64 does nothing
My wife got her old n64 back and when we hooked it up the red power light comes on and nothing else it is hooked into a vcr because we cant hook it into the tv directly im not sure that the game console is even running
  • mascwrestler Mar 29, 2009
    my n64 seemed to be working fine because i was playing it and it was all good. But then it made almost like a ripping or zapping noise and froze up. So then i turned it off and tried to turn it back on, the red light came on but the screen showed nothing at all. i waited about 20 minutes and tried again but still nothing. i dont know what to do now.
    President:
  • 894 Answers
Well its a power supply failure symptom for this to happen now.
Posted on Aug 11, 2011
    Problem Solver:
  • 6 Answers
The same thing happened to me, so I did was open itcleean all the dust, it worked for like 2 months and I stopped playing it.
Posted on Apr 27, 2008
Vcr/dvd player and nintendo 64
you N64 should have the cable with yellow/red/white connections(RCA) Those should plug into the VCR ports that say Input. Then run that to your TV through the screw on Coax cable.
Nov 25, 2013 | Nintendo 64 Console
I have a Samsung flat screen tv and cannot set up a n64
Upon looking up your tv I realize it has no composite (yellow, red, white) input. Without that you can not hook up your N64. There are other options though. You could buy an RF adapter for the N64 (Gamecube, Super Nintendo, and N64 cables are the same) but by doing so you will lower the picture quality a bit. Or you can buy a component to composite converter (like this but if you shop around you could probably find a better one for cheaper http://www.amazon.com/Component-Composite-w-Down-Scaling/dp/B003FJKHBU ) Lastly if you have a DVD player or VCR that has component cables you could hook that up to your tv and then hook the N64 into it. Good luck!
Apr 20, 2013 | Nintendo 64 Console
Nintendo 64 has power but does not work
Bring the console in to Gamestop or Rock30 Games and have them hook it up to their setup and see if it works. They buy sell and trade n64 games and will have a n64 system already set up at the store. Just switch your console and cables with theirs until you find out what is not working for you.
Jul 27, 2012 | Nintendo 64 Console
Why does the red light on my nintendo 64 come on for a fraction of a second and then not work
Well if the red light is flickering then it might be a bad ac adapter so you could buy a new ac adapter to see if it works then. Or bad capacitor inside of the console oe or the other. It might be time to buy a new N64 console.
Jun 02, 2012 | Nintendo 64 Console
I dont know how to set it up
- First you need a rather old TV, like maybe before 2002, if you have one. Because on newer TVs N64 graphics are terrible !
- Once you have your TV, check to see if you have two cables with your 64 (if you don't something is missing !). One shaped like a little box on one end and an electrical plug on the other : you hook up the little box to your N64 and plug the device in the nearest power socket. The other cable has a a strange black and rectangular input that hook up in your N64 and 3 sockets that are red, yellow and white. Connect the latter on your TV by finding the same sockets with the same colours !
- Connect your controller to the console (it's the round-ish sockets in front of it)
- insert your game
- THEN turn on your console. Don't turn it on unless everything hooked up !
(if it doesn't work you may want to try the famous turn-off-the-console-blow-into-the-cartridge-put-it-back-and-try-turning-your-N64-again trick !)
Good luck ! :)
May 28, 2011 | Nintendo 64 Console
N64 power light comes on, but nothing comes on the screen.
It appears that your power supply is fine (you still get a power light) however your internal game board has a problem. I realize you said that you have eliminated all the other components (very smart process of elimination) so the only thing that has not been swapped is the console itself. I think you've already come to the conclusion that the N64 needs to be repaired, and you just need to hear it from someone else. Unfortunately, the console needs to be repaired. Again, you did a great job isolating the problem, so you've done all the hard work.
Jul 07, 2017 | Nintendo 64 Console
The red light comes on for my n64 but nothing happens
Hi there, At a guess Id say the contacts on the Game Cartridge are dirty, you could try a couple of things:
  1. Blow on the contacts on the Cartridge and then push firmly into the N64 - Test game, if doesn't work move to next step
  2. Get some rubbing alcohol solution and a cotton bud and gently clean the contacts on the cartridge - Test game, if doesn't work move to next step
  3. Get some rubbing alcohol solution and a cotton bud and gently clean contacts in the N64 console cartridge slot - Test game
Cheers
Apr 03, 2010 | Nintendo 64 Console
I cant hook up my N64 to it im trying to figure out how to switch it to vcr but i cant :/
Okay here are a couple of options for connection of your 64 to your tv. Connect your 64 as usual to the input RCA on the vcr. I am assuming that you are using the coaxial cable to connect the vcr and tv together,place your tv in either channel 3 or 4 to tune to the vcr channel. Power on your vcr and your 64 you may have to select the source on your vcr to get the 64 signal but you should be able to now use the 64
Jan 17, 2010 | Samsung CXJ1964 19 in. TV/VCR Combo
N64 light comes on, but nothing comes on screen
Make sure that the game you are trying to play is free of dust and other obstructions.  I know that the label on the back of the game says that you should never blow on the edge connector, but it doesn't harm the game. (Trust me I've been cleaning the connectors for years now, and it hasn't been damaged.  After you throughly rid the game of dust, do the same with the edge connector on the N64.  Simply hold the opening open and blow the dust out.  This should work.   Please give feedback!! Hope this helps!!
Apr 16, 2009 | Nintendo 64 Console
Nintendo 64 Console Logo
418 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
