Question about AEG U3100-4 Electric Double Oven
How do i replace the element in the bottom oven of an AEG U3100-4 cooker ?
  • AEG Master
  • 3,463 Answers
If it is a fan assisted oven, remove the screws securing the rear cover inside the oven compartment, remove cover, and you should see the oven element there.
Undo the element, and fit new one.
Posted on Aug 04, 2010
Testimonial: "Very helpfull much appreciated."
The oven is on and lights work. When I select a function, cooker remains on but when I select a temperature the cooker trips the mains
In a simple oven, this could be be due to a heavy current due to a fault (check with resistance meter) or if the resistance is OK the tripping could be cased by an 'earth leakage' which typically presents when an appliance is damp or a heating element has not been used for a while...
Aug 18, 2014 | AEG B8139-4-M Electric Single Oven
Can't get the bottom oven working on my Zenith 50 cooker
Is it electric oven? Element gone most likely cause. Does the light and fan still come on?
Sep 05, 2012 | AEG Ovens
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 27, 2011 | Ovens
My oven does not heat up when in fan oven mode, the inner element does not get hot, the outer element does, Both elements get hot when using the main oven full width grill. ...
From your descritpion and if you already replace elements there are two options.
One is that there is an open curcuit either by a loose contact from selector switch to the elements this can be check with a mutlimeter.
The second option the selector switch itself is mulfuction and this normal after long time use since it consist with power contacts they fail to conect after long and you will need to replace it. If your familiar with electric then you can check it with power on and multimeter to see if it conects the elements or not. This operation need extra extra safety and experience.
We have here one side just to see what part you need the cooker selector multifaction switch
Aug 25, 2011 | AEG D5701-4 Electric Double Oven
My bottom element is not getting hot at all. There is power going in the back on both sides of the element when i check with a tester.thanks
If you hold the probes of meter to both connections I take it you are getting full voltage across them,if this is correct,then power off the cooker,now take the wires off the element,now set your meter to Ohms and check across terminals of element and see if there is resistance. If not then the element has blown and needs replacing.
Hope this was helpful.
May 21, 2010 | AEG U3100-4 Electric Double Oven
Fan comes on in the oven but the oven does not heat up, not sure if I have messed with the timer
Hi.
If the fan is working o/k, then there is nothing wrong with the timer, you need to replace the fan oven element, this will solve your prob.
Please rate my solution.
Thanks.
Sep 05, 2009 | AEG B3101-4 Electric Single Oven
AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 29, 2008 | AEG D5701-4 Electric Double Oven
I have an AEG cooker but the marking around the cooker knobs have
Hi.
You need thermostat knob and main oven control knob.
Nov 19, 2008 | Ovens
AEG U3100-4 Electric Double Oven Logo
632 people viewed this question
Top AEG Ovens Experts
Sal De
Steve
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
