Question about Toshiba Televison & Video
Now i am repairing a crown tv,its system ic 8873csng6pr6,its coplaint is seeonly horyzontal line,verticalic la78040 is and its supply are ok
SOURCE: shrarp tv 14v j100m
check if theres a 9 volts supply from lm7809..
Posted on May 17, 2008
bobhifi
  • 635 Answers
SOURCE: BPL i short model television
Did you check if 24v supply is coming to the chip ( through a fusable 10 ohm resistor ) ?.Look for dry solder on the sync chip ( 24 pin or 40 pin IC ).
Posted on Mar 11, 2011
gopakumarg43
  • 75767 Answers
SOURCE: center white vertical line on my t v screen "
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Check the 4 pin connector goes to it deflection yoke; from the main board for any loose solder terminals at the main board side.
Posted on Jan 22, 2015
Testimonial: "thanks knight"
gopakumarg43
  • 75767 Answers
SOURCE: How do I fix red vertical line on my crt t.v?
Horizontal scan out fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Check the deflection yoke connector [connector pin to its socket at main board] for any loose solder terminal.
Posted on Mar 23, 2015
SOURCE: I m ramchandra patil, i m used china kit which is
my tv on stake spear rested line
Posted on Apr 25, 2015
Where is horizontal scan out put section?
Hi Majid
Just contact any service technician to repair your TV. It will be best for you.
Gopakumar Gopalan Google
Feb 01, 2015 | Televison & Video
Where is horizontal output ic in my t.v?
There is no horizontal oscillator IC. The horizontal oscillation is generated and outputted by the main system control IC LA76810 itself. Refer some circuit diagrams using LA76810 to get more details about the horizontal oscillation output from the IC. Measure the frequency at that output pin. It should be some ever near 15.62KHz.
Type in the IC number, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Jan 31, 2015 | Televison & Video
Why come white vertical line on my t.v screen in center?
You said "I checked vertical output line from main ic pin 23 found correct"
But the problem is "Horizontal Output Line" Try that.
Jan 29, 2015 | LG Televison & Video
Center white vertical line on my t v screen "
Jan 22, 2015 | LG Televison & Video
I m ramchandra patil, i m used china kit which is used ic hay 22 8873csng6pr6. Eht ok, no picture, no sound. 5 volt,8 volt is ok. Pls give me solution tips. Thanking u
Disconnect the horizontal output transistor, and switch ON the set without it. See whether it switches ON. If yes, suspect both LOT and horizontal output transistor. This is a common fault to this kit. More to say, if the tuner get shorted inside, this might happen too.
Jul 17, 2014 | Televison & Video
BPL i short model television it's using La76931 ic problem is single horizandal line i cahange la78040 vertical ic but not cure.
Mar 11, 2011 | Televison & Video
Whent he tv is on, we see a thin horizonal line. the sound is good...you can hear what's going on, just a black screen with thin horizontal line. TV is only 2 years old. Toshiba TheatreView SD
HELLO
I wish I had a £1 for every time I answered this! This is field collapse where the probable cause is the Field Output IC itself, or dry solder joints on the board where the IC is soldered in.
If you are not familiar with electronics then I urge you contact a service centre in your area.
ALL THE BEST (:-)
Nov 09, 2009 | Toshiba 32A33 32" TV
Intermittant white line with subsequent shut down
You have a vert ic problem very common tv problem.
POSSIABLE SOLUTIONS
1 COLD SOLDER JOINTS ON IC REPAIR COST IS 95.00
2 REPLACEMENT IC 120.00
CALL LOCAL TV SHOP AND ASK FOR PRICES ON A VERTICALE IC REPLACEMT. THANKS DOCTOR VIDEO
May 17, 2008 | Hitachi 36UX59B 36" TV
Thin Horizontal line through tv blank screen.
Replaced vertical IC ( la78041 ??>.. Or La78040 ). Look for born resistor beside IC. Replaced capacitor 100uf 35V too!!! Good luck !!
Nov 08, 2007 | Insignia NS- 27" TV27 TV
Televison & Video Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
