Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
'ERROR: 2233 PRAM USB Device' - Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
3 Suggested Answers
  • 4 Answers
SOURCE: hi.. i hav a problem with Verbatim 8 GB usb drive,
they have lifetime warranty but not for the data. this is a damaged boot sector programming on the flash drive. It can only be recovered via a Level 3 data recovery company like ADR or Kroll. I used ADR.
Posted on Jul 08, 2010
  • 4 Answers
SOURCE: I have a kingston datatraveller 200 64GB. I cannot
You can not. This is a damaged Flash Drive. The portion of the chip that holds the programming has become damaged. I had the exact issue. It had to be sent to a level 3 recovery company. Like ADR or Ontrack. I used ADR. Then you can send the device to Kingston for a free replacement but Kingston will NOT do a data recovery for you.
Could you give me instructions on how to fit the parking device on my pram
Like a rear view camera?
http://www.bubhub.com.au/hubbub-blog/checklist-for-buying-a-pram-or-stroller/
https://www.productsafety.gov.au/content/index.phtml/itemId/974064
Design and construction-prams and strollers
Parking device Prams and strollers must have one or more parking devices that limits the movement of the pram or stroller.
The release mechanism of the parking device must be located so that it is not easily accessible to a child when the child is properly restrained in the pram or stroller.
The colour of the part of the parking device used to activate the parking mechanism (actuator) must be red, and surrounding framework and mouldings must be a contrasting colour.
Nov 27, 2015 | Baby Gear
Tip
How to Reset Parameter RAM (PRAM) - Macs
Resetting Parameter RAM (PRAM)
PRAM stores certain system and device settings in a location that Mac OS X can access quickly. Exactly which settings are stored in the computer's PRAM varies depending on the type of computer as well as the types of devices and drives connected. To reset PRAM:
1. If computer is on, turn it off by choosing Shut Down from Apple menu.
2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in Step 4. Note: If keyboard does not have an Option key, use Alt key instead.
3. Press power button.
4. Immediately press and hold Command-Option-P-R keys.
Important: You must press this key combination before the gray screen appears.
5.Hold down keys until computer restarts, and you hear startup chime a second time.
6.Release keys.
on Mar 01, 2011 | Computers & Internet
2261 pram
2261 pram
It's identified as 2261 pram usb device and not working
Jan 28, 2014 | Kingston Computers & Internet
My USB flash drive is not working. When I plug it into my Windows XP desktop, i get the message saying it is installing required drivers, and it says the USB is "2233 PRAM USB". The LED light on...
have you tried
control panel admistrive tools,computer management,device manager scroll to disk drives + to expand if you can see scan disk drive right click you can trubleshoot or select properties select driver update driver,roll back driver or uninstall remembering to reinstall the driver
hope this helps
Nov 12, 2010 | Computers & Internet
I have a kingston datatraveller 200 64GB. I cannot access it and I get the message 2233 Pram. HOW can I read my files?
Jun 17, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
Hi.. i hav a problem with Verbatim 8 GB usb drive,
Dec 28, 2009 | Verbatim CORPORATION 94933 USB 2.1GB...
G5 has insomnia won't stay in the sleep mode
Usually this is caused by a USB printer unnecessarily clamoring for attention.
Disconnect ALL your USB devices and the problem ought to go away. Then connect them one by one to find out which the culprit is.
To zap PRAM, shut down the Mac, then push the start button and immediately hold down Command-Option-P-R until you hear the chimes pass by three times. But I don't think this will affect your problem.
Apr 15, 2009 | Apple iMac G5 Desktop
PCM Ram full
PCM (or PRAM - Phase-Change memory) is similar to flash memory (NAND) in the respect that it is non-volatile (it doesn't get deleted when you power down). Expandability for PRAM can be proprietary and updating your keyboard may prove difficult, but there may be a better solution for you. Your synth has 3 usb ports. a front and rear high-speed USB2.0 port labeled as HOST, and specifically, a slower, but dedicated DEVICE port on the rear. The device port is a USB1.1 port but you can insert standard USB thumb drives formatted in FAT to this port for added storage for your samples.
Cheers!
-E
Oct 28, 2008 | Korg Pa800 Synthesizer
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
5,214 people viewed this question
Top Verbatim Computers & Internet Experts
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
