Question about Bushnell Voyager 78-9565 (120 x 60mm) Telescope
The rack and pinion focus mechanism has broken. Both focus wheels have broke off. It was not dropped or mistreated in any way. How do I get it fixed? It has a limited lifetime guarrantee but I've had no answer from Bushnell (I contacted them direct)
  • 4 Answers
  • 3,186 Answers
You can buy another focuser from many online retailers here are two:
http://agenaastro.com/parts-accessories/focusers-accessories.html?SID=sec3c8oei3jjgitd04kestotj1
http://www.optcorp.com/category.aspx?uid=105-175
You can also contact Bushnell customer service and see if they will sell you this part:
Here:
http://www.opticsplanet.net/bushnell-warranty.html
Posted on Aug 04, 2010
4 Suggested Answers
SOURCE: Rack & pinon focusing mechanism
You can buy parts and get repairs on this web site:
Posted on Jan 30, 2011
SOURCE: Hi , I have a Bushnell 570 x 60 Rotary Compact
No it's not --- junk it and buy another telescope. This time avoid Bushnell- Tasco, and Edu Science scopes.
Check out the Orion web site here, for a Dobsonian reflector telescope. The most aperture for the least amount of money.
http://www.telescope.com/control/main/
Read my tips on my profile page.
Posted on Feb 06, 2011
Testimonial: "Thanks very much for your advice - much appreciated. Steve"
SOURCE: Rack and Pinion
Yes you can -- several different telescope retailers sell focuser here is one:
http://www.telescope.com/Accessories/Telescope-Focusers/pc/3/51.uts
You must buy the correct size that will fit your tube.
Posted on Jul 31, 2011
My steering wheel turns but it doesn't turn the wheels on the car... I dropped my girl off at work and came home and as I was parking it stated to Lock up on me, when I finally parked, the steering wheel...
Sounds like something broke. Either in the steering column or the linkage between the column and the rack and pinion. Take it to a reliable repair shop for examination and repair. Best case scenario is the linkage between the column and rack and pinion came apart but I have never heard of it happening. Worse case scenario you need a new column or rack and pinion. You don't say what make and model of your vehicle is.
Jul 11, 2017 | Cars & Trucks
Power steering hose keeps breaking, even when replaced by high pressure hoses. Replacing rack and pinion does not help either.
A bad seal in the rack and pinion would have caused low pressure from fluid by-passing the seal. This also would have caused noticeably increased effort to steer the vehicle. Excessively high pressure would indicate an issue between the power steering pump and the rack, and since the hoses have been replaced I would focus on the pump. PS, find a real mechanic, not a parts changer.
Apr 06, 2014 | 2001 Chrysler Town & Country
Installed new rack and pinion now steering wheel is upside down
They probably didn't center the steering linkage with the rack and the steering will that's the answer
Jun 01, 2012 | Dodge Cars & Trucks
My 2003 ford focus lost it's power steering, mechanic replaced the rack and pinion thing - lost steering again and now the mechanic says it is the power steering pump. The rack and pinion was replaced...
if the rack and pinion was not leaking or causing problems. then he may of made a wrong move! if the rack was fine before, and you just lost power steering. then it is most likely the power steering pump or the lines that go from rack to the pump. good-day ! if a rack goes bad, you will get a bad steering problem or just bad steering.
Aug 23, 2011 | 2001 Ford Focus
The rack and pinion focusing mechanism will not go in and out. how do i fix this?
There is a simple gear inside -- take the bottom plate off the focuser and see if they are engaged or broken.
If a gear is broken you will need to buy a new focuser.
Mar 03, 2011 | Bushnell Optics
Pontiac G5. Steering wheel spins freely, wheels don't turn. Is this a U joint issue?
either the steering shaft has broke or the rack and pinion is broke have someone turn the wheel and look under hood near where the steering shaft meets the rack and pinion. do you see it spinning? if so the rack is most likely broke inside. if not the steering shaft may have snapped. hope this helps
Jan 31, 2011 | 2008 Pontiac G5
Rack and pinion vibrate badly after installation. starts to vibrate (back and forth motion of the steering wheel of approx 2 inches each way) after trying to move the steering wheel.
The rack is incorrectly installed in the chassis of the truck and its position isn't fixed - it shifts around the securing bolts. The vibration is caused by the pressure of the servo pump and the movement of the pinion: when the rack moves even by a little fraction by itself but the steering wheel doesn't follow it accordingly then the pinion is forced to rotate a tiny bit more than it should and that is enough to open the valves of the servo and the oil pressure presses on the rack moving it all the way to one side with force. When the movement stops because the rack has nowhere to go no more the pinion stops and the valve close, the oil pressure drops, the force on the rack drops and it tends to go back to its original position. That opens the valves again, but in the opposite direction so the rack is slammed on the opposite side. The process continues as long as the steering wheel is turned , generating that vibration.
This is a very dangerous situation, the car is not safe to be driven on any distance, at any speed. Tow it to a repair shop and have the steering mechanism in its entirety inspected, most likely it will be necessary to replace it completely.
Dec 17, 2010 | 2001 Ford Explorer Sport
I have a minor broken seal on my rack and pinion
There is but it's not going to help, the rack and pinion steering has large amount of pressure on it when you turn the steering wheel. If the seal is bad, sooner not later. The seal will fail and you lose all the power steering fluid and the power steering which can in turn also damage the rack and pinion. The safest and cheapest thing to do is get it repaired before it get's worst and you end up replacing the rack and pinion too. Good luck and keep me posted. be glad to help
Jun 08, 2009 | 2001 Oldsmobile Aurora
Bausch and lomb professional 200 telescope
New focusers can be purchased at merridian.com or telescopes.com
Feb 19, 2008 | Orion 1.25"/2" Precision Rack-and-Pinion...
Rack and Pinion
Dec 22, 2007 | Bushnell Voyager 78-9440 (440 x 12.5mm)...
Bushnell Voyager 78-9565 (120 x 60mm) Telescope Logo
594 people viewed this question
Top Bushnell Optics Experts
Marvin
Marvin
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
