Question about Samsung HCM5525W 55" Rear Projection Television
Replacement convergence chips
When replacing the stk392 convergence IC chips, should one upgrade to the 11o, 150 or 180 version? THey have higher power ratings, but I don't know if they are direct substitutes. Do they require any resistor changes?
I have this repair to do this week, and want to order the right ones.
I posted this question in reply to an other query, but thought I should start a new question thread.
Thanks in advance. This is my first experience ith Fixya
  • Ed Michelson Apr 27, 2008
    Thanks. I need to get into the set, will take a look and get back.
    Last service was done by the repair guy, I have never been inside it before. Can you help me with the best way to get to the board?
    Does the front panel, under the screen pop off, or is it best to go in from the back of the set? The set is sitting in a built-in cabinet, about 6 inches up from the room floor, so I am going to have to round up help to get it out of the built-in to get to the back.
    THanks very much! I will order them tomorrow along with the heat sink grease! why don't they put a small fan on those heat sinks??
  • 121 Answers
I you give me your complete STK number such as STK392-010 as an example I can tell you what you can upgrade to also it does not require any resistor change when you upgrade but send me your complete IC number that you have and I can tell you what to upgrade to thank you
Posted on Apr 26, 2008
  • dawn garrett
    dawn garrett Apr 27, 2008
    okay you need to go into the back of your set as soon as you take off the back look about dead center and you will see 2 big heat sinks and your ic's will located on the heat sink I looked up your number and you have STK392-040 for that model and that is the highest you can go that tv. chances are the last person who repaired your tv may not have put on an adequate amount of heat sink compound and that could have caused your ic's to go out prematurely you need to replace both IC's and I will post you a link where you can get new ones also step by instructions (pic) also you get free online tech support where they will help you with any help you need while installing your new ic's
    http://servicemanuals.vstore.ca/
  • dawn garrett
    they don't put a fan on them because usually they would interfere with operation of the tv they would get video lines but as far as the grease you would be better off getting the grease at your radio shack that sight don't have the grease and plus radio shack has it for about $1.29 for a small tube and thats all you should need. thank you anything else I can help you with just holler
I got an AV-48WP74 projection tv and the convergence IC's werre upgraded from STK392-110 to STK392-150 and several of the resistors on the convergence board were bad. I need to know what to upgrade the...
The value of the resistors should not be changed (either resistance or wattage) as their job is to self destruct if one of the chips shorts.
It is very unusual in this set to see more than two of the resistors bad.
FYI: the 150 chip is a higher current device but will have no longer life than the original as the problem is that the heat sink grease drys out and this causes the failure.
The original resistors are metal oxide type and flameproof or carbon resistors should not be used to replace them.
Let me know if you have questions.
SD TECH
Sep 01, 2011 | JVC AV-48WP30 48" Rear Projection...
Convergance problem on lower half of screen.smeared red and orange double vision,but only on bottom ofscreen.top appears out of focus,but not double visioned.
Howdy,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The part(below) Number is from Toshiba, they provide good advice on replacement parts. Make sure what type of IC's your TV uses first. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number
23905094 (STK392-110) using the revised “T” version IC Part Number
23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version. Inspect the Convergence Output IC’s for the “T” type version as
shown in Figure 2. Replace the Convergence Output IC’s using the “T”
type version Part Number 23135090 (STK392-110T).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for choosing FixYA, Big Irish.
Nov 23, 2009 | Televison & Video
How do i fix my toshiba flat screen 57" tv when it looks like it is 3d
Howdy;
It sounds like the convergence IC's have failed.
Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is detected, it’s recommended that both IC’s be changed to the “T” type IC version. Inspect the Convergence Output IC’s for the “T” type version.
1420-B Toshiba Dr.
Lebanon, TN 37087
Fax: 615-444-7520
www.tacpservice.toshiba.com/tacp
Good Luck, Big Irish.
Nov 22, 2009 | Toshiba 61HX70 61" Rear Projection...
I have a Toshiba rear projection TV model # 50H71 for about a month the tv would randomly pop off (lose sound and picture) for about 45 seconds and then come back on now th picture is reduced in size by...
Good Day,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Nov 22, 2009 | Toshiba TZ50V51 50" Rear Projection...
JVC AV48WP30 convergence ic
I'm in the process of trying to replace both convergence IC's in my JVC also. I was able to buy both IC's (they look like black semi-rectangular components with 20 pins sticking out...like a computer chip only much bigger) at a TV repair shop for about $15 each. They were clearly labed STK392-110 (but could be 150 or 180 if you wanted to upgrade).
Jan 18, 2009 | JVC AV-48WP30 48" Rear Projection...
Problem with TV screen?
Good Day, deon453;
Sounds like a convergence problem.
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
version.
Jul 02, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 40who8b convergeance problem
Good Day, harri1234;
Convergence Output IC Failure
version.
Jun 23, 2008 | Toshiba 42H81 42" Rear Projection...
Stk392-110 chip replacement
stk392-110/150/180 all have same fit, form function except the 150's and 180's are basically upgrades for they're more stable (more heat tolerant than the original 110's); I'd buy the 150/180 myself; you can get the stk392-180 for just under 10 bucks on eletronix.com.
Mar 24, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Everything looks like a 3-D movie!
Replace convergence IC's IK04 = STK392-150 and IK05 = STK392-110. Also check resistors RK42,RK46,RK50,RK54,RK58,RK62 for burnt/discolored.
Aug 20, 2007 | Hitachi 46F500 46" Rear Projection...
Samsung HCM5525W 55" Rear Projection Television Logo
74 people viewed this question
Henry  Thomas
Henry Thomas
