DeskJet 895Cxi Printer ran out of black ink before my summerholliday. Back on job monday I replaced a new inkbox, HP 45 Black. The colour ink was changed just before my holliday. Still the orange light for ink is blinking rapidly and the printer will not start working. I have carefully cleand the yellow spots with a wet towel, but with no success. What more can I do? Kirsten
  • 1,218 Answers
Follow each of these steps until the problem is resolved:
Remove and then reinsert the print cartridge(s) into the printer.
Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
Manually clean the print cartridges and print cartridge cradles:
Open the printer cover and wait until the carriage moves to the center.
Press the Power button to turn off the printer.
Disconnect power cord from the back of the printer.
Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
Lightly moisten a cotton swab with distilled water.
Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
Reinsert the print cartridges.
Close the printer cover.
Connect the power cord to the back of the printer.
Press the Power button to turn on the printer.
Calibrate the print cartridges.
If the light is still flashing, replace the print cartridges.
http://www.fixya.com/support/t5472914-hp_deskjet_932c_went
Posted on Oct 05, 2010
Why does the the left hand orange button flash ?
Here's what worked for me,
Obviously check and make sure you deficiently haven't ran out of ink.
Turn the printer off Remove the colour cartridge
dab the cartridge point with a slightly damp tissue, if ink comes out then turn printer back on without the colour cartridge and try and print some thing in black and white.
turn printer off again and insert the colour cartridge
This strangely will get rid of the blinking light.
If there was no ink reissue on the tissue when dabbed, you'll need to get a new cartridge.
If problems persist I'd recommend getting the printer properly cleaned.
Hope this helps.
Jul 17, 2011 | HP DeskJet 990cxi InkJet Printer
Have hp d1430 printer, I only use the color print cartridge, the printer will print color but will no print normal black lettering, have tried two different hP22 cartridges. Is the printer done for?
YOU SHOULD USE HP 21 BLACK INK CARTRIDGE FOR BLACK PRINTING.IF YOU USE 22 COLOUR CARTRIDGE YOU WILL GET ONLY GREAY PRINTING ONLY.I AM RIGHT?IF YOU USE COLOUR CARTRIDGES MAY YOU WILL GET MONEY LOSE. BECOS IT WILL FINISH EARLY.BLACK INK COST IS LESSTHAN COLOUR INK CARTRIDGES. SO YOU SHOULD BUY BLACK CARTRIDGE FOR REAL BLACK PRINTING.
Jun 29, 2011 | HP Deskjet D1430 InkJet Printer
It ran out of ink, when I replaced the ink cartridge it will not print any more.
It is possible that your new ink cartridge is bad, but it is more likely that your jets on your printer are clogged - and that is preventing the ink from hitting the paper.
You can purchase an ink jet cleaning kit from your local office supply store and try that.
Also, if there is an available ink head replacement kit for your printer, it might be beneficial to go ahead and change that out now too.
Hope this helps!
Feb 23, 2011 | HP DeskJet 895cxi InkJet Printer
I thought I was out of black ink, so I replaced the #45 black ink cartridge in my DeskJet 932C printer and it still won't print in black ink.
check the printhead especially the black partition and see if the nostril on the printhead are not damage. does the ink lid blinking if yes clean or replaced the cartridge
Aug 30, 2009 | HP DeskJet 932c InkJet Printer
The black is printing dark redish brown
Dear friend, your Black Ink Cartridge is Empty thats why your printer is using the Colour Cartridge to produce the Black Colour. This is the reason you are having Dark Reddish Brown colour instead of Black.
Apr 08, 2009 | HP Deskjet 6940 InkJet Printer
My printer will not accept a new black cartridge.
ITS NOT THE BLACK CARTRIDGE!!! Try changing the colour cartridge and see what happens. When a 9600 checks ink levels it does the black ink first, then the colour, if the colour is low it goes back and checks the black again but will constantly give an error message for the black cartridge. Sounds bizarre but try just the black cartridge in with no colour. print a test page in black only, if that does not print then it is a fault. Also make sure the driver is updated!!!
Feb 16, 2009 | HP DeskJet 9650 InkJet Printer
HP Officejet T45 keeps telling me I have the wrong Ink Cartridge
Clean the cartridge contacts and the printer contacts as shown here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jan 17, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Hp deskjet 1280 black colour problem
remove the Printer Catridge & clean the belw points where the INK come out, & shake properly & insert,
May be catridge ink got dried,
kiran
Jul 29, 2008 | HP DeskJet 1280 InkJet Printer
Colors Murky... HP DeskJet 1120c
REPLACE COLOUR CARTRIGE.IF THE CARTRIDGE IS DAMAGE ON THE INSIDE THE THREE COLOURS SOMETIMES MIX CREATING A COLOUR WHICH LOOKS BLACK
May 11, 2008 | HP DeskJet 1220c InkJet Printer
D1360 black ink didn't print and green light keep flashing
just unplug the power cable and usb cable from the back side of the printer and let it be for an hour it will help
Apr 15, 2008 | HP Deskjet D2360 InkJet Printer
185 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
