Question about Garmin Nuvi 660 GPS Receiver
How to open a Garmin nuvi 660 for battery replacement ?
  • 1,514 Answers
Unfortunately the battery in the nuvi 660, like most garmin satnavs, is not user replaceable. To have it replaced it needs to be sent to garmin. Garmin contact details can be found at http://www.garmin.com/garmin/cms/site/us/support/supportcontact
Posted on Aug 04, 2010
SOURCE: voice not working properly on garmin nuvi 660 - very disdorted
i have been told that voice to street is not as clear as the voice just stating turns. If it really bothers you then try voice to turn. I cant remember the setting but it should work well for you.
Posted on Jan 07, 2008
emissionwiz
  • 81423 Answers
SOURCE: replacement battery for Garmin Nuvi 660
I read that the front cover around the screen can be pried off, this must be removed to gain access to battery, I would suggest a thin piece of rigid plastic as it will no damage the cover and body edges. Hope this helps
Posted on Jun 20, 2008
SOURCE: Garmin Nuvi 660 dead battery?
Normal 0 Garmin NUVI 660 instructions
It is pretty easy to open up your nuvi,(but not recommended by Garmin or me)...
looking at your nuvi from the back flip up the antenna. You will see two tiny torx screws on the antenna. Remove them and carefully seperate the antenna housing. Pay attention to how the antenna flex is seated because reassembling the antenna housing can be tricky. On the left bottom side the pin assembly that holds the antenna in is spring loaded. Pull the pin towards the center and you will be able to seperate the antenna housing from the unit. Underneath you will find two more tiny torx screws holding the main housing togather. Remove those two screws and you are almost home. Now you need the special plastic tool that you can get on ebay. The tool is used for opening ipods without mangling them. Gently pry the case apart with this tool. Start where ever it is easiest to get the tool in. Once opened you can figure the rest out for yourself. The battery is flat and rectangular and is seated behind the circuit bourd attached to the back cover.
Posted on Dec 26, 2008
Foxy_sister0
SOURCE: how do i unlock garmin nuvi 660 ? thanks
how do i unlock the gps
Posted on Aug 03, 2009
  • 4 Answers
SOURCE: Garmin Nuvi 660 touch screen freezes up. Soft
I sat on the phone for 30 minutes waiting for Garmin support when my Nuvi suddenly had no touch screen response. They had me delete a file on the device (with it hooked to my computer) then reboot and it went thru a touch screen alignment and it worked.
Sadly, it has frozen again and I don't recall the file (it had been a GCD file in all caps, that is all I know and I don't see a file in all caps any more). I will be calling support tomorrow.
My take is that it *is* a firmware thing *and* there is some way to reset the firmware.
Posted on Dec 02, 2011
Nuvi 660 lost password
open , remove battery for 15mins and put back the battery
Mar 10, 2012 | Garmin Nuvi 660 GPS Receiver
Install replacement battery in Garmin Nüvi 660 and 670. How is cabinet opened?
The Garmin 660 and 670 like most Garmin satnavs cannnot be opened unfortunately. Garmin say that the battery may be replaced by sending the unit back to them only.
Jul 24, 2010 | Garmin Nuvi 660 GPS Receiver
Unit shuts down after about one minute.
When you leave a Nuvi on a charger for several hours and don't see full green bars, this is an indication that the battery is defective. Most Nuvi batteries last about 2 years. Most of the batteries have a date code of 2007. I would have the battery replaced as soon as possible as it can bloat and crack the case open. More info can be found here:
http://www.sharc.net/gps_battery_repair.htm
- Jim
Jun 01, 2010 | Garmin Nuvi 660 GPS Receiver
Replace Battery
PLEASE!! Don't try this yourself.... you risk futher breaking the unit. Please see this link:
- Jim
Apr 05, 2010 | Garmin Nuvi 660 GPS Receiver
HOW DO I INSTALL A BATTERY IN MY GARMIN NUVI 660
Replacing the nuvi 660's battery is actually not all that hard as this video demonstrates:
utube.png You-Tube video "S2KEu_if7wA" placeholder (do not delete) utube.png
The company that produced the video sells a kit which includes the battery and tools necessary to do this yourself if you'd like. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+660&Show=ExtInfo I swapped the battery of a friend's dying GPS using the aforementioned kit and all went well. His nuvi 680 is back up and running smoothly.
Feb 18, 2010 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
How do i replace battery garmin nuvi 660
Please son't try this yourself. I receive weekly horror stories about people who now have permenent paper weights. Please see this link:
- Jim
Nov 16, 2009 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 won't turn on; have tried the reset button and nothing
you can try removing the battery leave it to dry for like 1-2 days then replace it back or replace with entirely new battery click here for a video instruction on how to open it up
Oct 08, 2009 | Garmin Nuvi 660 GPS Receiver
Nuvi 205 dead
Garmin support center----tomtom support center
http://www.gpscentral.ca/contactus.htm
all the gps information for 660 number model
http://gpsinformation.info/nuvi/660/660.html
Nov 17, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 shutting off
It sounds like your battery is defective. They can be replaced. The Motorola phone cable is not wired exactly like the Garmin, and your Nuvi thinks it's connected to a PC. Radio Shack carries a charger for the Nuvi. I have one myself.
Let me know if you need additional help with your battery problem.
- Jim
Nov 15, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
328 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
