I upgraded my memory fro 256 to 512 in my HP Brio BA200, and now it tells me that the BIOS is not AcPI compliant...what the heck do I do now????
  • 1,257 Answers
If you perform an upgrade on the BIOS to enable ACPI on a computer that is already running Windows XP , you must reinstall the operating system to enable ACPI support.
low feed backs hurt my ratings and I am tring to help you with your problem,so let me know about the information i provided you is helpfull or not..
Posted on Apr 26, 2008
Bios is not ACPI complaint
It's possible that the BIOS setup has been accidentally set to non ACPI mode. Check in the setup to ensure ACPI is enabled.Other possible causes are memory expansion, overclocking and incompatible driver software. Check out what you have recently installed or updated on your computer.This can occur if Windows has detected that the BIOS in the computer is not fully compliant with Advanced Configuration and Power Interface (ACPI). To correct this problem, contact the manufacturer of your computer to obtain a BIOS update that is fully ACPI compliant. (If your PC is an older model, a BIOS update may not be available). There are third party companies that will write a BIOS update for your computer for a fee which may make it more cost effective to replace your computer.You may also find help on this Microsoft Support Site.
Apr 09, 2013 | Computers & Internet
Blue screen of death says acpi bios noncompliance. Help!!
Did you change something in the bios? Enter the BIOS and check the Power Management or just Power settings and disable ACPI. This should solve the problem.Windows would again find new hardware and then should work normally.If ACPI not found under power it could also be under Advanced tab. Did you install any new hardware?.The hardware might be non ACPI compliant hence the error.
Jan 21, 2011 | HP Compaq Presario SR1303wm PC Desktop
When i go to install OS, it shows that bios isn't acpi compliant
This errror coming from motherboard because your BIOS version is different as compare with new version, so download new BIOS for ASUS Intel 815E Chipset CUSL2-C from web site of ASUS there is detailed step of How to upgrade BIOS, you can upgrade BIOS by creating Bootble Disc otherwise you can Upgrade from OS.
I hope that this has been very helpful for you
Dec 12, 2009 | ASUS Intel 815E Chipset CUSL2-C...
Upgraded mon pc dont shut off fan con to run
Computer doesn’t power down when users shut down
In some cases, Windows XP’s Setup program can misidentify the power management scheme in a computer’s BIOS as Advanced Power Management (APM) instead of Advanced Configuration Power Interface (ACPI). When this happens, users will notice that the computer no longer automatically powers down when they shut down Windows XP. Instead, they’ll see the message It Is Now Safe To Turn Off Your Computer and be forced to manually press the power button to turn off the computer.
You can verify this problem by checking the power management configuration in two places—Device Manager and the Control Panel. To quickly access Device Manager, select Start | Run, type Devmgmt.msc in the Open text box, and click OK. When you see the Device Manager window, locate and open the System Devices item. If Setup identified the system as having an APM-compliant BIOS, it will be listed as a Standard PC in the System Devices tree. (If it were identified as having an ACPI-compliant BIOS, you would see it listed here as a Microsoft ACPI-Compliant System.)
To check the power management configuration in the Control Panel, open the Control Panel from the Start menu. If the system is using Category View, select Performance And Maintenance and then click the Power Options icon. If the system is using Classic View, just click the Power Options icon. If Setup identified the system as having an APM-compliant BIOS, you’ll see an APM tab in the Power Options Properties dialog box. (If the system were identified as having an ACPI-compliant BIOS, you wouldn’t see an APM tab.)
You may be able to fix this problem with a BIOS update. To begin, check with the computer manufacturer’s Web site to see if it’s providing the latest BIOS update. If you’re troubleshooting an off-brand computer, you may be on your own as far as tracking down the BIOS update. Here’s how.
Once you obtain and install the BIOS update according to the manufacturer’s instructions, you must perform what I call a Refresh Installation, in which you reinstall Windows XP on top of an existing Windows XP installation. You must perform this reinstall operation because the power management features are tied to a special power management Hardware Abstraction Layer (HAL). During the Refresh Installation procedure, Setup will completely redetect all installed hardware, including the updated BIOS, and rebuild the power management HAL as well as the part of the registry in which information about the installed hardware is stored.
Jul 20, 2009 | Gateway M280E
ACPI is not a compliant
Enter you bios & disable ACPI. Restart the system. Than update your windows. There should be an update for ACPI through Microsoft update service. Once installed restart your system & enter into your bios. Now enable ACPI. Save & exit the bios.
If this does not help you can try the work around found on Microsoft's web site. See the link provided;
Jun 01, 2009 | MSI Computers & Internet
ACPI BIOS not fully compliant
w8000 a very old PC not supported by HP.
windows 2000 support ended like 15 years ago.. W2k. is gone. w2k only runs on very old pcs with very old ACPI
(power controls is that)
this PC is only supported with XP
never 2000.
HP tells you that if you looked.
park the 2000 disk or use it as frezzbee. IMO
id get w7 disk and use that, it might work.
but will cost you a license from MS,
about 5 times the value of w8000
why not just go here, and get used $20 w7 pc
save a bundle of case and grief messing with any legacy junk....avoid legacy junk and win.
a usa answers.... always...
Jul 19, 2017 | Compaq Computers & Internet
Dell Inspiron 1100 Bios and ACPI
Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
Manually install the Standard PC hardware abstraction layer (HAL):
1. Reboot the computer to restart Setup.
2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant
Mar 16, 2009 | Dell Inspiron 1100 Notebook
The ACPI BIOS in this system is not flly compliant with the
Hey there,
You havnt specified your problem clearly.
If ur motherboard is not compatible with the hardwre then u dont have to worry about it. Try upgrading ur M/B Bios. with latest version. This BIOS (*.ROM) fie u'll get on ur M/B manufacturer site. Type ur model no in the search pane of that site and provide the Model no of ur mother board.
Read the M/B manual to upgrade your BIOS.
Gime ur acknowledge by rating me.
Dec 23, 2008 | Computers & Internet
Acpi compliant
BIOS has no upgrade for VISTA to be installed. Contact the manufacture to write on update BIOS for that computer or motherboard as the case may be.
Dec 22, 2008 | Intel D845PT (KD845PTPAK10) Motherboard
Acpi complaint - reg
Fiend your solution direct from intel. Here is your solution........
Jan 17, 2008 | Intel Motherboard
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
