posted by Papalote on Apr 26, 2008
My TV now refuses to come on and goes from a blinking green to blinking red on the power button. The lamp indicator on the front also flashes red with long pauses in between. What can I do, because I don't have TV.
Best Solution
posted on May 17, 2008
Your service manual on page 82 steps you through decoding the blinking
1) there are two lights on the front near the reciever of the remote signals (Temp indicator and Lamp Indicator)
2) If the Temp indicator is on then they recommend you contact a service center
3) If the Lamp indicator is on and the power light stays on (no blinking) then you need to replace the lamp. Otherwise it says to contact the service center.
4) Counting blinks with the lamp indicator (1 every 5sec - lamp will not light or is abnormal, 2 every 5sec - lamp voltage is abnormal, 3 every 5sec - lamp temp is too high, 4 every 5sec - other error)
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Panasonic PT-50LC13 50 in. Rear
Email this problem
Email this problem
Can you Help with these Projection Televisions problems?
Panasonic PT-50LC13 50 in. Rear Projection...
Remote control
Remote control
my remote control stopped... Answer This...
lamp meter
lamp meter
i haven't reset my lamp meter... Answer This...
pt-50lc13
pt-50lc13
will go on and work fine for... Answer This...
autoconvergence
autoconvergence
please explain how to do an... Answer This...
Panasonic LCD rear projection...
recently devoloped light blue... Answer This...
Repair Service
Find Projection TV Repairman Near You:
