Samsung SHT 3005w intercom as per wiring diadram there is no voltade on pins 1-2 or 3-4 for door strike to work. Currently using 12v DC lockwood strike. Do we need additional power supply different strike? etc
    Welcome Back:
    Visited the website for 2 consecutive days.
I have a similar problem - I have an independent power supply
but the circuit on pins 1 and 2 doesn't close as expected
so the door release doesn't work - I have to have a separate button beside the SHT3005 that doesn't look good.
Posted on Oct 04, 2010
Have a Samsung 6200 series with no picture, but picture with a flashlight. I think it is the power supply board.
The LED's are getting low to no power, not likely burned out, but power supply is a good guess if it's not the electronic circuit that controls brightness.
More likely you are seeing something like 4.3 volts and misinterpreting the multi-meter display. Common DC voltages are going to be 12v, 5v and 3.3v but other voltages may be used for the LED back-lighting and may be variable per the brightness circuit.
Nov 06, 2017 | Samsung Computers & Internet
Why is my Remote showing relay fault
315Mhz remote relay switch kits - 2 channels - Seeed Studio
www.seeedstudio.com/.../315Mhz-remote-relay-switch-kits-2-channels-p...
This remote switch allows you to remotely control any 12 Volt DC device. ... to supply 3-5VDC to the "+12V" pin,(Caution: the 12v is an error silk screen on PCB, ... Is there a wiring diagram to show how you connect the sender to the GPIO pins?
Amazon.com: 1 Channel Wireless Controller (On/Off) 12V ...
www.amazon.com > ... > Lighting Accessories
Amazon.com, Inc.I wired this remote relay to a fuse block below the motorhome frame. ... Here's a (very) short video showing how the remote control works. I love it! It's very easy to ...
12v wireless 315 MHz remote control relay board 6-channel ...
? 4:36
https://www.youtube.com/watch?v=JBzL0MIno2w
Feb 2, 2013 - Uploaded by Julian Ilett
12v wireless 315 MHz remote control relay board 6-channel ... The relay board takes 12 volts in and there ...
Dec 03, 2015 | Cars & Trucks
I need a schematic for a LT2 echo board to install in my president grant PC-409AB
break audio line. J2 input goes to mic pin J1output to radio.
(leave the shielded ground wires disconnected. on audio)
Power use a 1k ohm resistor from 12v dc on pwr switch.
Ground run the ground wire to board ground
test and set echo level.
this will work for any radio. if the echo needs 12v instead of 8v remove the 1k resistor and just use a 1n4001 diode on the power wires . some models require 12v some are 5-8volts.
Jan 18, 2015 | Radio Communications
Were do I find the Wiring Diagram from Galaxy Fulcher 2007 Caravan to Ford Ranger 2010
http://www.narva.com.au/products/browse/wiring-diagrams
use a volt meter to work out which light is connected to which pin on Ford Ranger trailer plug . Hopefully it corresponds to standard trailer wiring diagrams. Test each wire could also use a light bulb with two wires soldered to it or a 12v dc probe.
http://www.amazon.com/6V-12V-24V-Motorcycle-Circuit-Voltage-Electroprobe/dp/B00GYVS0E2
http://www.ebay.com/sch/i.html?_ssc=1&_nkw=Voltage+Detector+Tester+Pen+Non-Contact+Probe+Pen&_sop=7
Dec 09, 2014 | Ford Cars & Trucks
I have an Astec DS 1500-3-001 power supply that I want to use a a stand alone PS. What pins do I need to connect to get +12v DC output with 120 VAC Input.
Mike
I take it that this is a standard power supply out of a PC (switch mode)
These are a common connection point on any brand PC
Use a DC Voltmeter to find the Ground, +5 Volt & +12 volt wires to power your 3.5 inch Hard Drive. The 2.5" Hard Drives (laptop) has only Ground (Black) & +5 Volt.
Oct 30, 2014 | Computers & Internet
We have DMC-10RS intercom system in our house. All them squeal when the power source is on. I had to unplug the hub to make them quiet. I cked the power supply and its putting out 12.2V,ok. Any ideas what...
Check power supply for proper voltage of 12 volts DC.
-If there are multiple Hubs, check voltage on all Hubs
If the voltage is not 12V, try replacing the power supply
226888 Power Supply
-If the voltage is ok, disconnect 1 room station at a time. If there a multiple Hubs, disconnect the last Hub. As each room station and/or door station is removed, have someone else listen to see if the squeal goes away. There is a chance that one bad room or door station is causing the issue.
oIf the squealing stops, add in the previous stations that had been disconnected. If all stations other than that room station are ok, do not hook up that station. There are no replacement stations available for this system. If the squealing continues with any of the stations hooked up, there is a bad HUB. DMC-10 Hubs are NLA and cannot be repaired. The best option for a replacement is the I2000 Kit
IntraSonic Intercom System Kits Quality Home Systems
Please visit our website if you have more questions.
Central Vacuum Intercom and Whole House Audio Systems
Don't forget to like and visit our Facebook page..
https://www.facebook.com/QualityHomeSystems/?ref=hl
Apr 25, 2014 | M&S DMC-10RS: Intercom Room Station
Does lockwood and kwikset use the same keys
The popular Kwikset keyway is used by many companies, and will fit into one of Lockwood's keyways. The spacing is a little different, so if you are trying to make locks of both brands work with the same key, double check the width of the cuts while you have the locks apart to make sure the pins you are using will sit on the bottoms of the cuts and not on the slopes of the sides of the cuts.
If you just want to copy a key, then there won't be a problem. Lockwood does have 6 and even 7 pin locks, so make sure your key is the right length.
Oct 28, 2013 | Kwikset Locks & Locksmithing
I can't not open the door whith sht 3005
try to reset the monitor by pressing mode button and choose default by using + /- buttons
Oct 09, 2013 | Samsung ) Shs-3120 +sht-3005 Intercom
865 MOTHER BOARD VOLT OUT PU PIN
Hi Dear, well, you can get 1v dc or 1.5v dc from any pc motherboard but I'll never recommend you to do that. You can use Black and Red wire combination to get 5v dc or Black and Yellow wire combination to get 12v dc from motherboard's power supply. 3 LEDs in series can b use for 5v dc input.
Mar 31, 2009 | Intel D865GBF Motherboard
Televison & Video Logo
156 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
