Question about Philips 32PF7421D 32 in. LCD HDTV
Philip LCD 32". Model ID : 32TA2800/98 S/N : B25B0745250339 (1) Control Board (Audio) (2) AIC1586 (50pm5) 509
5 Suggested Answers
yungdub
  • 93 Answers
SOURCE: Philips 32TA2800
The Way Im understanding your problem is,
it seems like you need to hook your rcas directly to the tv and switch the surround to aux or something similar to that.
Posted on Jun 14, 2009
rylee_smith
  • 8619 Answers
SOURCE: MY NAME IS PHILIP I
Hi
Thanks for using FixYa. If the TV isn't turning itself on then the fault protection circuit has detected a fault and has turned down the TV. The blinking indicates a fault. You'll need to check various things to find an answer which part is bad. Please check these---
1. Check for signal cables at the back and also try unplugging the TV for 8-10 hours to reset it.
2. Swollen /bulged capacitors on the power supply board-- This happens due to overheating of capacitors.
3. If the capacitors are fine then you'll need to check for connectors on all the boards and also the fans if they are working fine.
4. Make sure the lamp connections are fine and ballast is not burnt.
Note-- Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition, so please be careful.
Try to reset the TV by unplugging it for 6-8 hours.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Oct 25, 2009
SOURCE: hi all, i have a
Turn it off fully for 48 hours. If after that it won't switch on, you should get it back to a service ot a repair shop.
Posted on Feb 28, 2011
diodeic
  • 1622 Answers
SOURCE: WHEN I TURN ON MY
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
I hope this will help in solving the problem.....
Posted on Jun 13, 2011
Audio going out
id look for bad connections to the built in speakers, des it do this with external headphones? if so id guess main board
Dec 09, 2013 | Vizio L32 32 in. LCD HDTV
WHEN I TURN ON MY PHILIP 32 INCH LCD THE SCREEN APPEAR IN 2 SECOND THAN BECOME BLACK BUT SOUND AND ALL CONTROL BUTTON WORK ONLY CANT SEE THE PICTURE AITHER POWER BOARD OR PANEL SPOIL?
Jun 13, 2011 | Philips 32PFL3403D/27 32 in. LCD TV
Sony model KDL-32L5000 does not respond to the commands of its remote control model RM-YD028. We have been using a Direct TV remote as well to control volume but its not reacting this remote either...
If the only thing not reacting is the audio, then the audio board or the main board has gone bad. Enter the model number and tv make on you tube to get more detailed info.
Dec 15, 2017 | Sony KDL32L5000 32 in. LCD HDTV
8 blinks from a sony bravia model klv-32s400a tv
8 blinks in KLV-32S400A shows Audio Error
Check audio voltage supply from power supply board, if OK, replace GP Board (main board)
and if audio volts are not available, check/ replace power supply board.
Feb 09, 2010 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
My lcd tv 32pfl5332 broke the lcd screen what should I do?
Sorry it junk,sell it on Ebay.com for parts or save it for parts for the new purcharse tv with the same model.U can try Shopjimmy.com for some tv 32"LCD screen,but don't if they have Philip LCD or LCD work with Philip LCD tv models.But basicly LCD broken in 40 and up is not possible to get LCD screen.Tv compannies sell LCD Screen out the same as a new tv price or well exceed the price after part and labors.
Feb 04, 2010 | Philips 32PFL5332D 32 in. LCD Television
Inverter Board
Go to encompassparts.com they have it and you can download the svc manual.
Dec 21, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
Color just changed drastically, getting darker and with any movement there are trails. This is a 2 year old 32" samsung lcd
lcd controler or T-con board has failed you will need atech to find the creect board to put in youe set there are so many differant LCD panels used in the same model
Dec 07, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
I have a Element 32" HDS LCD TV, movel ELEFLX3210. It won't tunr on, but has a red light that is on. The TV was purchased 09/09/2007. Do you know how to repair or address this? It's a $549 TV.
There were two runs of parts on this model, one using a powersupply board that included the inverter and one with a separate inverter. The red standby light failure was typical with the second run with the all in one power supply board. You can tell if you have the second run by opening the back. If the power supply board says proview and is black then you need to replace the board underneath it. The main board. This model also had a MASSIVE factory defect. If you hook up the VGA model, pin nine on the control box lead shorts out and it goes into limbo like you have now. So, replace your mainboard and Fill the vga input with hotglue. That should get you back and kicking again. Try shopjimmy.com or ebay for parts.
Good luck
Aug 01, 2009 | Element Electronics FLX3210 32 in. LCD TV
Rs2100 bookshelf stereo
The Audio System does not respond to the remote control.
1. To reset their connection, turn on the remote control and switch the Audio System to Standby mode.
2. In Standby mode, press and hold both INFO and SOURCE on the front panel of the Audio System. It is reset to default when"RF ID clear" displays.
3. Press and hold both PROGRAM and SELECT on the remote control. When “ID claer” displays on the LCD of the remote control, the connection is reset.
4. By now the remote control and the Audio System should be connected to each other. Press and hold PROGRAM and SELECT on the remote control again. When
“ID Locked” displays on the LCD of the remote control, the connection between the remote control and the Audio System is locked.
Jun 06, 2009 | RCA RS2100 Shelf System
MY REMOTE ALWAYS SHOWS ME REM506....
May 07, 2009 | RCA RS2100 Shelf System
Philips 32PF7421D 32 in. LCD HDTV Logo
346 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
