Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Another Question You said the main problem is the power supply. Can this be fixed by me? If so, how/ Thanks
    Problem Solver:
  • 16 Answers
It depends if you have a some knowledge in electronics or if you know how to troubleshoot the parts inside.maybe you would need a TV service technician, in order to locate the damaged parts.
Posted on Apr 26, 2008
Replaced Main power supply,inverter board,Digital main on Emerson LC320EM1F but it doesn't turn on,except stand by red light
The power supply board is at fault. You have a shorted diode. Location of this diode is D639. Replace it with an NTE 5087A. The board you will fix, has the power AC cord attached to it! Thanks for asking, Matt of Martins TV.
Nov 23, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Vizio sv421xvt issues
It sounds like a main board issue but could be a power supply issue. I will tell you from my experience with Vizio TV's, main boards are more likely to fail than power supplies. But to be sure, you will want to either get a diagnoses or if you're handy do a little troubleshooting. The power supply and the main board are not cheap so you will certainly want to be sure before spending any money.
Nov 24, 2012 | Vizio SV421XVT 42 Class LCD HDTV - 1080p,...
Why wont my tv turn on
That problem is usually have 2 causes..Its either power supply board or main board..
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Thanks for using fixya...
Jun 06, 2012 | Sylvania LC320SS2 TV
Dead Vizio V047. No picture, no sound. I do measure 5v dc on three of the power supply board pins going to main board but I don't think the main board is sending a signal back to the power supply to...
Modern Displays/TVs cost more to fix than they are worth, plus electrical problems can become a fire hazard.
I suggest recycle this and upgrade to a new one.
Nov 19, 2017 | Televison & Video
I have a 2000 Sony KP-53HS10 color rear video projector, Just yesterday it turned off in the middle of watching it and the timer/standby light merely blinks. When I unplug it and replug it in, the same...
Good day!!!
That problem is usually have 2 causes..Its either power supply board or mainboard..
Hope thissolution will be helpful..
Jul 05, 2011 | Sony KP-53HS10 TV
Cannon-3300 Copier Error code E000-0000 rectify the problem
E000 0000
The reading of the main thermistor does not reach 30°C 1 sec after the main
power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
Main cause:
The fixing film unit is faulty. The main thermistor has an open circuit. The
fixing heater has an open circuit. The main power supply PCB is faulty. The
DC controller PCB is faulty.
Caution:
To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action:
1. Connector
Is the connector of the fixing assembly connected?
a. main power supply PCB (J8) <-> relay connector <-> heater
b. DC controller PCB (J320) <-> relay connector <-> thermistor
NO: Connect the connector.
2. Fixing film unit (thermistor)
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectosr (4-pin) of the thermistor for electrical continuity. Is it ¥W
(open)?
YES: The heater has an open circuit, or the thermal switch is open. Replace
the fixing film unit.
4. Main power supply PCB, DC controller PCB.
Press the Start key. Is the drive voltage of the heater supplied by the connector
J8 of the main power supply PCB?
Main heater: between J8-1 (FSR1) and J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) and J8-5 (FSR COM)
YES: The heater drive power supply is faulty. Replace the main power
supply PCB.
NO: The thermistor control mechanism is faulty. Replace the DC controller
PCB.
Jan 18, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
I HAVE A CANON IR 3300 MACHINE I HAVE ERROR E00000-000
WHAT: Either the main thermistor doesn't attain 30?C 1 second after the power switch is activated or it doesn't attain 70?C 2 seconds thereafter.
WHY: It has a faulty fixing film unit, lack of connectivity with the main thermistor, lack of connectivity with the fixing heater, a faulty main power supply PCB, or the DC controller PCB is faulty.
NOTE: You can reset the error by performing the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
CONNECTOR FIX: Make sure that the connector of the fixing assembly is seated.
A. main power supply PCB (J8) relay connector heater
B. DC controller PCB (J320) relay connector thermistor
FIXING FILM UNIT (THERMISTOR) FIX: With a multimeter, check the interval between pin 1 & pin 2 & between pin 3 & pin 4 of the connector (4-pin) of the thermistor for electrical continuity. A result of ?? means that the circuit is open (lack of connectivity). Resolve this by replacing the fixing film unit.
MAIN POWER SUPPLY PCB, DC CONTROLLER PCB FIX: Press the Start key. If the drive voltage of the heater is supplied by the connector J8 of the main power supply PCB, then the main power supply PCB should be replaced. If not, then the thermistor control mechanism is faulty & the DC controller PCB should be replaced. Use the following to ascertain this:
Main heater: between J8-1 (FSR1) & J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) & J8-5 (FSR COM)
Sep 25, 2010 | Office Equipment & Supplies
Hi - We have an error code on a Canon Model 2800 : E000001-0002 Any ideas on how to fix the problem? Thanks! Paul
E001
0000 The main thermistor detects 250°C or higher.
0001 The main thermistor or the sub thermistor detects overheating (hardware
circuit detection).
0002 The sub thermistor detects about 295°C or higher.
Main cause The fixing film unit is faulty (i.e., the thermistor has a short circuit). The
main power supply PCB is faulty. The DC controller PCB is faulty.
Caution To clear the error, execute the following in service move:
Action
1. Fixing film unit
the connectors (4-pin) of the thermistor for electrical continuity. Is it 0 ?
(short circuit)?
YES: The thermistor has a short circuit. Replace the fixing film unit.
REF.
If the thermistor has a short circuit, the indication in service mode
(COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC=250°C
for the main thermistor; FIX-E=310°C for the sub thermistor.
2. Main power supply PCB, DC controller PCB
Try replacing the main power supply PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
BUT FIRST: under service mode *28* copier, function, clear , err turn off and on maybe it will work.If it works check that you have good air flow around the copier.
Apr 19, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Have a Hitachi 55hdt79...no pictures only sounds.
It might be the power supply, check the main power supply. Audio power supply is seperate to main power supply, thats why you have a sound.
Jul 24, 2009 | BenQ PDP-46W1 46 in. HD-Ready Plasma...
IR 2000
Fuser error probally needs fuser replaced and the reset as below
try this
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
or this is explaination of the error and required fix from service manual.
E0000000
Main cause The fixing film unit is faulty. The main thermistor has an open circuit. The
Caution To reset the error, execute the following in service mode:
Action
1. Connector
(open)?
YES: The heater has an open circuit, or the thermal switch is open. Replace the fixing film unit.
Press the Start key. Is the drive voltage of the heater supplied by the connector J8 of the main power supply PCB?
supply PCB.
PCB.
Nov 18, 2007 | Office Equipment & Supplies
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
24 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
