Question about Garden
I do not know how to change to bit in my dremel rotary 7.2v tool
  • 700 Answers
It is easy, you may find first time that it will not be so, but if you follow advice, it will become even more easy.
1. switch off motor
2. unplug from power
3. find button on the base close to rotating bit, press and hold, this is shaft lock which if applied correctly (you may need to rotate shaft a bit till it fully engage) will stop shaft from rotating
4. apply small spanner (provided with set) to collet collar (collet have two indentations fitting perfectly little spanner)
5. if shaft is held up, turn spanner anticlockwise, then use your hand to undo collar completely
6. remove collet and bit - separate bit from collet
7. collet comes in many sizes, select correct size for new bit
8. insert collet into throat
9. lightly screw in collar
10, insert new bit, at least 2/3 of the bit shank must be inserted into the collet!
11. held shaft lock button pressed
12 hand tighten the collar till bit is locked firmly in place
13. do not use spanner to tighten! if collar do not held properly, re-tighten by hand only!
14. wear always glasses when operating dremmel, or any other rotating machinery, it is not a toy! and exploding bit will penetrate not only your bit of woo, or metal but your eye as well... and your have only two and no spares...
if you find my advice useful, please do not hesitate to vote4 for me, or leave comment, or both... thanx!
Posted on Aug 04, 2010
You can change to any bit, but have to change the compression collar inside the end of the shaft. For example if the tool shaft size is 1/8" you need to use the 1/8" collar etc. Make sure you use the corresponding bit with the corresponding compression shaft size or the bit will not lock in position when you tighten the collar.
Aug 10, 2014 | Dremel Tools & Hardware - Others
I need someone to tell me how to remove the entire attachment bit from the tool
dremel have a collet adaptor available to allow interchange of bits. They are available from dremel or hardware stores.
Feb 07, 2013 | Dremel Variable - Speed Multipro Rotary...
Dremel 3100 won't release the drill bit. Button at the top is pressed in and won't come out.
The button is only to keep the shaft from turning while you loosen the collet (the nut) with the little wrench. THEN the tool comes out.
Sep 25, 2012 | Dremel Variable - Speed Multipro Rotary...
I had a dremel passed down to me but don't know what it is for. Please advise how I can make use of this tool.
http://www.dremel.com/en-us/projectsandcommunity/projects/Pages/default.aspx
this website is directly from dremel. It shows different projects, crafts, or hobbies you can use it for. It is a real simple tool to use, and also is very handy. You can obtain several types of bits for it ones for sanding, engrving, cutting all types of materials, and much much more. Hope this helps
Jan 23, 2011 | Dremel 395 Variable Speed Multipro Rotary...
Dremel will not turn on?
IF you don't release the bit lock, it won't run.
Aug 01, 2010 | Dremel 395 Variable Speed Multipro Rotary...
I don't know how to change the bit on my dremel multipro rotary tool . . .I keep turning the gizmo but don't see anything getting smaller or lager.
Push the pin on the side next to the tip and hold it while Your wrench is turning the hex shaped piece around the bit that is what is holding your bit in. this should help as i am a proud owner of a Dremel. Hope this helps . if you have any further questions write back.
May 06, 2010 | Dremel Variable - Speed Multipro Rotary...
I inherited a Dremel Pro from my son who passed away...
you should have a little wrench that came with it
and on the neck of the dremel there is a shaft stop button
push the button and manually rotate the dremel head till
it clicks then hold the button and use the wrench to loosen the bit
Mar 27, 2009 | Dremel 300 1/40A "Multi Pro" Rotary Tool...
Wires on switch
On my rotary tool the white wire goes on the left if pointed away from me. Hope this helps. Mamabear
Sep 18, 2008 | Dremel Variable - Speed Multipro Rotary...
How do I change bits????
there is a screw at the tip of the dremel, take it out and it is pretty basic after that
Aug 05, 2008 | Dremel Variable - Speed Multipro Rotary...
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
