Question about HP Digital Sender 9250c scanner Printer
I ahve a HP 9250c scanner, and my computer doesn't recognize it from the usb cable. It says it's missing IEEE 1284.4 printersupport. What can i do to fix this ? I have already installed all the software for the 9250c i could find on the HP support site.
  • 111 Answers
It sometimes happens because of the USB cable. try it out with a different usb cable. Don't try it out with Chinese made usb cable because at times computers fails to detect a new hardware or gives error. As I had faced similar problem.
Posted on Aug 04, 2010
Panasonic IEEE 1284
Not sure what the question is. IEEE 1284 is a parallel cable interface, standard on most computers up until Windows XP for sure. http://en.wikipedia.org/wiki/IEEE_1284. This interface was substantially replaced by USB. If you have an older printer with this interface you can still connect this to a newer computer without the parallel interface by installing an interface card (into a desktop computer) or connecting via a Parallel to USB adapter.
http://www.pcfixup.ca/2010/03/connecting-parallel-port-printers-to.html
May 08, 2014 | Microsoft IEEE 1284.4 compatible printer
I am simply making a copy and it is printing super slow.
hELLO IDEAL58ST,
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. SOLUTION: Solution After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model.
THANKS.
Sep 06, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I have a citizen prolaser 6000 laser printer, it emulates HP Laserjet 3, I want to connect it to my laptop via a usb interface cable, currently it is connected to the printer port of a desktop (lpt1 for...
There is three things that you will need:
Proper port set up on laptop device manager (Check settings) LPT1 is for a parallel port - Need USB Correct Driver for the Citizen 6000 Pro Laser (Windows should auto install) Hub that will communicate via USB to the IEEE 1284 Printer via cable.
Driver Site: http://www.driverfiles.net/Printers/Citizen/Prolaser-6000-Printer-Driver/download/page,sh,38839,389,12,.html
I hate to suggest, but you may have to call Microsoft Citizen Tech Support for suggestions on the Hub that will communicate via USB properly. Check your manual for setup options.
TF
Jun 02, 2011 | Office Equipment & Supplies
I can't get hp deskjet 600c to work with Vista. Am using a IEEE 1284 to USB cable. HP site states Vista driver will automatically recognize and install printer, but my computer does not. Print manager...
The drivers for the 600C should be there in Vista, it should directly install the drivers. Check if the drivers is not in offline mode, right click and turn it to online mode. If the drivers were installed automatically when you plugged the USB cable, then the USB cable should be good enough.
Jan 27, 2009 | Office Equipment & Supplies
I just purchased a laptop with XP Home. I have an HP Laserjet 6L which does not have a USB connection. So I installed a "USB to IEEE 1284 Parallel Printer Cable." The computer found the...
Power OFF both Printer AND Computer.
Boot up computer.
Insert the USB cable into a port.
WIN XP will recognize and install needed software.
Attached the USB cord to the printer.
Power up the Printer
Next configure the Printer . . .
ø Start > Settings > Printers and Faxes
ø Right-click on HP LaserJet 6L
ø Properties
ø Ports
o Find “USB001 Virtual printer port for USB"
o Select this, if not already done
o Apply
Jul 08, 2008 | Office Equipment & Supplies
My HP LaserJet 6L Won't Print on new HP/Vista PC
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from http://www.bebo.com/andythoo
Jan 20, 2008 | HP LaserJet 6L Printer
HP Digital Sender 9250c scanner Printer Logo
190 people viewed this question
Seeker5211
Seeker5211
