Question about AEG 23 in. 6410KF-N Electric Cooktop
I need an instruction manual as I cannot work the controls. I turn it on by pressing the bottom right hand control (round with vertical line) an L comes on for each ring but when I press any button to increase temp for any ring it shuts down. there must be a sequence to follow but I cannot work it out without the manual. PLEASE HELP!!!!
  • 8,197 Answers
May I get the make and model # so I may help you more
Posted on Aug 07, 2010
How can I adjust the volume of the touch controls on our Amana Gas Range?
Hello not sure volume can be changed but if it can look on the back of the unit or inside the back top plate there will be a tech sheet if it can be done it should be on it
Dec 01, 2013 | Amana 30 in. White Freestanding Gas Range
Temp alarm chimes can't find control pad to turn it off
look on the internet they might help you , type in the info you have about it.
Nov 10, 2012 | Maytag MBF1958XES - 30% E-Star, 19 Cu....
The control knob on the left back pops and throw the breaker every time we turn it on. It also throws a spark.
I am having the same problem with similar model (all of the control knobs line up on the right side of the cooktop). I removed the controller that "popped" and then turned the breaker on -- it flashed in a different location (under the indicator light adjacent to the controller I removed). Just for additional fun, I turned on the breaker one more time and I got a flash under the controller at the opposite end of the controller panel. I am assuming that I have fried at least two controllers and an indicator light does anyone know what the source of the problem might be? Thanks!
Jul 26, 2011 | Jenn-Air JED8430 Electric Cooktop
Boch ceran 9000179011 try to turn on and red light flashes on right hand side of touch controls
Did you ever get a solution to this? My Bosch hob is doing the same wanted to know how to resolve or if I need to call out a technician.
thanks.
Sep 13, 2009 | Bosch 24 in. PIE675T01E Electric Cooktop
Hob says 'L' when turned on, tried solution but still not work
i called up AEG customer service, and they said: Press the '-' and bottom right '+' sign and this should take off the childlock. So it looks like there manual was correct. It seems like in some cases you need to do this, or the method suggested in the other post
Jun 25, 2009 | AEG 23 in. 6410KF-N Electric Cooktop
One of the heater elements would not turn off
switch is bad needs replaced
Jun 24, 2009 | Cooktops
Aeg hob
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
Sep 29, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Indicators
the 'L' means locked - to unlock turn on hob, hold down front right hand side plate control and minus botton to unlock - see manuals for further details
Sep 22, 2008 | Baumatic 23 in. B10 Electric Cooktop
Candy sprinter
Great.. finally. i manage find from solution from user guide.. L is Locked. below is the instruction. will check out tonight.
The locking function holds the current settings, or prevents anyone from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on. To lock the hob : -Press the on/off button     . -Press simultaneously " - " button and " + " button of the front right zone (PVD 633 front left zone), and then press again on the " + " button of this zone. The hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds. To unlock the hob : -Press the on/off button      . The locking indicator " L " is displayed on all zones. -Press simultaneously the " - " button and the " + " button of the front right zone (PVD 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Jun 24, 2008 | Cooktops
Have a baumatic ceramic hob displayin letter 'L'
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Mar 28, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
AEG 23 in. 6410KF-N Electric Cooktop Logo
90 people viewed this question
Top AEG Cooktops Experts
Charles T Nevin
Charles T Nevin
 Andrew Henderson
Andrew Henderson
Are you an AEG Cooktop Expert? Answer questions, earn points and help others
