Question about Ricoh Office Equipment & Supplies
RICHO DIGITAL COPIER ONE SIDE OF THE DOCUMENT USE TO CLEAN AS IF THE DOCUMENT IS NOT DRY
  • 67 Answers
Check fusing unit
Posted on Aug 26, 2010
WHEN I MAKE COPY IT IS ALWAYS VERY LIGHT.
First you need to carefully clean the copier optics: Open document glass, use clean, dry and soft cloth to wipe the small mirrors on the scanner. Clean also the fluorescent lamp carefully not to break it. Wipe the document glass both inner and outer sides then securely screw it back. Remove the drum unit and wipe clean the underneath mirror on the laser unit then test the copy quality.
Oct 31, 2013 | Sharp AR-5520N
I have richo aficio 2020 copier .toner motor is not rotating please help
Remove the toner botle clean the area and check the hole and the gear mechanism in developer station.
Feb 07, 2013 | Ricoh Aficio 1018 Printer
Richo 1013f copier problems-grey lines on copies
Most often this problem is coming fro the PCU or Photoconductor Unit. If you open the right side door just look for the long greenish colored cylinder. It should be clean. If you see a toner film or more specifically the same "lines" on the surface of the drum that you see on the copies then you will know. If this is the case you will need a new PCU. Installation is a piece of cake.
Here is a link with pictures, part numbers etc.
http://www.precisionroller.com/search.php?q=ricoh+1013+drum
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Ricoh Aficio 1013F Copier
In richo 1045, paper is contineus jam in the upper side of fixing unit
Clean oe change the upper fuser roller,fuser roller cleaning roller and clean the lower pressure(red) roller.
Jun 03, 2010 | Ricoh Aficio 450 Copier
Paper is getting jammed in the document feeder
This problem occur due the DF is not detecting the Orginal size.
Check the Size detection sensor,located when u open the ADF cover u can see, Clean the sensor by blowing.
Aug 12, 2009 | Gestetner - DSm675sp Digital Imaging...
Code 541
hi!!!!!
may be the was damaged
or
try to clean use dry tissue
or replaced the drum
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Copying on my 7210 hp all in one
are you feeding in the copies from the Automatic Document Feeder? Open the top of the flat bed scanner and look to the left you will see a small piece of glass that is used for the ADF and then you will see a large piece of glass that is used for the flat bed scanner. Clean the small piece of glass used for the ADF and let it dry before trying to use the copier again. Test the copier and see if the gray line is still there. if you are using the flatbed portion of the scanner, clean the larger glass on the scanner and as before let it dry before trying to use the copier again and then test the copier.
Sep 18, 2008 | HP Officejet 7210 All-In-One InkJet...
Solve my problum
I have a richo 2018d all in one copier machine it can be a error code SC541.
what is its solution ....
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Sharp AL-1340
Try this: make a copy from the table and then one from the document feeder. compare the two. If the copy from the table looks good and the document feeder one is bad then clean the glass on the document feeder. If both are bad remove the top glass and clean the mirrors using rubbing alcohol and a lint free cloth. you can also clean the wheels on the feeder and in the tray with rubbing alcohol if you ever have feeding problems
Hope this helps
Apr 12, 2008 | Sharp AL-1641CS Laser Digital Copier
14 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
