Question about Dishwashers
I have zero water pressure in the rinse cycle
    Problem Solver:
  • 13 Answers
Inlet filter mayby blocked, remove pipe and check filter might be limescaled up
Posted on Aug 04, 2010
Have a hotpoint aquarius wml540 that is stopping on the rinse cycle, when it stops the rinse light is on and the red lock light is flashing, is this an error code?
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Apr 07, 2015 | Hotpoint Washing Machines
Amana washer will not go through rinse cycle
TIMER
Mar 28, 2015 | Amana Washing Machines
Bosch classix 1200 exprss washing machine will not move on from the wash cycle. it will keep on washing and never moves to the rinse cycle. pump and motor works ok.
TIMER
Mar 25, 2015 | Bosch Washing Machines
My GE 15 cycle heavy duty plus washer the water keep running in the rinse cycle
Hum the water inlet valve may be going out or defective, have u noticed any water in tub at bottom when machine is not in use or after a day or so? check it with multimeter. Another suspect could be a bad timer sticking on rinse cycle, or a bad water pressure switch, which is suppose to shut water off at certain water level then start the agitation? In other words when in rinse and water is draining, the pressure switch continues to read low and opens to keep the water flowing to replace water that is lost? Need a multimeter test on all of them
Sep 26, 2014 | Washing Machines
Washer continues to run
Ok. So you are getting ZERO water in the washer or just in the rinse cycle?
Apr 07, 2014 | GE Washing Machines
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Water pressure for Washer (rinse only)
you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
Nov 18, 2009 | Kitchen Ranges
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Machine leaks at beginning of rinse cycle
have you checked the rubber seal round the door might be torn
Mar 03, 2008 | Samsung WF337AA Front Load Washer
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
