Question about Nokia 5800 XpressMusic Smartphone
My phone wont come out of offline mode it says insert sim but my sim in in
Iave a samsung phone and it is saying that my simcard is out of mode even though the sim should have been active.
Posted on May 27, 2011
My phone is in offline mode,when i insert a sim card it ask whether i want to continue in offline mode but when i choose no, it tells me to insert sim
when you insert your sim card and press ok when it ask you whether you would like to continue in offline mode . once your phone starts go to the settings option and click the master reset or restore factory setting. once restored swtich off your phine without removing the sim card and then switch it on after 5 mins . it should solve your problem
Oct 19, 2013 | Cell Phones
My nokia e7 stays offline mode while sim inserted
After inserting the sim card it goes restart and ask for changing the profile from offline,when i try to change the profile from offline to others it hang and restarts showing the offline while sim inserted!tried with different sim but no use.
Jul 08, 2012 | Nokia E Series E7-00 Touch Smartphone-...
OFFLINE MODE
Offline mode means that your phone aint getting any signal from your mobile service provider's BTS. You need to check it from your mobile service provider if there's an ongoing outage, you need to check as well if the sim card is properly inserted. Try powercycling your phone.
1. Turn off your device.
2. Remove the sim, memory card and battery.
3. Wait for at least 2minutes.
4. Plug back the SIM card, memory card and battery.
5. Turn on mobile phone.
6. Check if you are still getting offline mode.
7. If so, try to insert your SIM card to a different phone.
8. If using a different phone for your SIM displays offline mode still,then its your SIM card which is faulty. If it works fine make sure that you inserted the sim properly or the SIM card slot might be faulty.
Dec 05, 2011 | Nokia E52 Smartphone
My phone is N95.it shown the offline mode bt when i changed the profile and select the general profile after that it does not work.pls help me how i can open my phone lock..........
This is not a lock.This problem occurs when Sim card IC is damage,Sim Case damage.But one thing you can try is Clean the sim Case and Sim card.Insert the sim and switch in the phone .If the problem still persist Contact mobile repairing shop.Good luck Thanks
Jul 25, 2011 | Nokia N95 Cellular Phone
My phone is offline when ever i inserted my SIM it rejected
change offline mode ,
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.wickedunlock.com/nokia-5230-nuron/rs11wp9/
Jan 18, 2011 | Nokia 5230 Cell Phone
Wen i insert sim phone comes up offline - does this mean sim is not inserted properly?
Try the sim in other phone, if it works, you just have your Nokia in Flight mode. Disable flight mode.
Sep 17, 2009 | Nokia N80 Cellular Phone
My phone nokia 6680 has been in the offline mode.i want remove it
when you insert sim in your phone after using it offline,it should ask you if you want to continue using your phone in offline mode...select NO..Otherwise your phone cannot detect the sim card..clean sim terminals..if problem persists check and reheat sim filter IC..the crystal one, near the sim terminals itself..if all fails then UPP (CPU) or software problem..
Jul 16, 2009 | Nokia 6680 Cellular Phone
N72 mobile working only in ''offline''mode.
The phone is showing Offline, hence I have inserted the sim card and switched the phone on, and choose general profile too. But it is showing Please Insert Sim Card. Please help with a solution.
Nov 22, 2008 | Nokia N72 Cellular Phone
Phone in offline mode
'whether you want to continue in offline mode y/n'.,
when it displays this messege
press no
and u r done
Sep 15, 2008 | Nokia N70 Cellular Phone
Nokia 5800 XpressMusic Smartphone Logo
159 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
