Question about HP LaserJet P3005n Printer
Mem check failure replace dimm error message shown on hp laserjet p3005n printer .please sugest me how to solve this error.
    Problem Solver:
  • 8 Answers
Hi<br /> <br /> The formatter board in the printer is faulty. The heat from the chips softens the soldier and makes the joints bad causing all types of misleading errors.<br /> To solve the problem you can try two differant methords, both will endevour to melt the soldier joints back to good.<br /> <br /> Slide the right hand cover to the back of the printer and remove.<br /> <br /> Open metal door to see formatter board<br /> <br /> Disconnect the three wires from the top left of board, they only go in one way so you do not need to mark them.<br /> <br /> Undo the screws around the board and pull the board free.<br /> <br /> Using a hot air paint stripper heat up the reverse side of the board applying plenty of heat to the soldier joints<br /> <br /> Reasemble<br /> <br /> Do a cold restart and away it should go.<br /> <br /> Alternative to the hot air gun you can but the board in the oven.<br /> Trust me on this one it will survive.<br /> <br /> Support the board at the edges on small blocks of wood to stop it from touching the pan<br /> <br /> Pre heat the oven to 180 degrees<br /> (soldier melts around 165)<br /> <br /> Put the board in for eight minutes and then remove, let cool befour touching.<br /> <br /> Reasemble<br /> <br /> Do a cold restart and the printer should work.<br /> <br /> Chris<!-- from fixya rte -->
Posted on Aug 12, 2010
    Brigadier General:
  • 4,090 Answers
THE DIMM is a memory module that has either dislogged ( moved the unit recently?) or is damaged. Check the integrity of the Memory module by unseating and reseating first . If that fails to fix it get a new module.
Please rate my hyelp++++Thanks for using FIXYA
Posted on Aug 04, 2010
MEM TEST FAILURE REPLACE DIMM 1
Replacable DIMM repace with same part no, if on board replace formatter..
Sep 05, 2011 | HP LaserJet P3005n Printer
DIMM Error HP P3005n
Are you usingoriginal HP Dimm chip?, does machine turn on and come to ready when it is standing on it own (not hooked to p.c.) if not can you tell me exact light patten displayed
Dec 13, 2007 | HP LaserJet P3005n Printer
Mem test failure replace dimm 1
As the message says, DIMM 1 failed.
It's pretty straight forward fix for a tech.
So the cost should be minimal for the labor and whatever the
replacement DIMM costs.
Jun 28, 2011 | HP LaserJet P3005n Printer
My printer shows memory error on its screen why?
Mem test failure replace Dimm 0 or Mem test failure replace Dimm 1
If either of the are the messages displayed, the problem lies with the mother board (formatter).
DIMM 0 = On Board Memory - cannot be changed. DIMM 1 = Add On Ram - Can be Changed
Make Sure the printer firmware is up to date FIRMWARE
Most Likely the formatter board would require replacing.
Feb 03, 2011 | HP LaserJet 2420dn Printer
Problema con impresor hp laserjet p3005, da mensaje "MEM TEST FAILURE REPLACE DIMM 0", y cuesta que en el panel de control aparezca preparado.
Hello, this error related to the additional memory installed into the printer. It could be just the memory or the Formatter board itself. The memory can can be removed quite simply.
1) Turn the power off to the printer.
2) Slide the right side cover off, moving it towards the back.
3) Remove the memory DIMM from the formatter board.
4) Turn the power to the printer back on.
Does the printer come "READY"? If yes, then the memory is bad, If NO then the formatter is bad and will need to be replaced.
A good source for part www.partsnow.com
Jan 13, 2011 | HP LaserJet P3005n Printer
Mem Test Failure Replace Dimm
The biggest problem with the P3005 is the main board. There has been a warranty extension on the P3005 if it is the main board.
it maybe a memory problem too, but unless you added memory, its usually part of the main board.
Jun 02, 2010 | HP LaserJet P3005n Printer
Problem for HP LaserJet P3005n Printer MEM TEST FAILURE REPLACE DIMM 0
Apr 15, 2010 | HP LaserJet P3005n Printer
Printer will not print. keeps saying
first you pl. check the dimm/sdram module is seated properly in its place otherwise insert new one
Feb 05, 2010 | HP LaserJet P3005n Printer
HP LaserJet P3005n Printer Logo
335 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
