Question about Whirlpool Washing Machines
Doesnt finish cycleand flashes up f11 - Whirlpool Washing Machines
  • Whirlpool Master
  • 12,061 Answers
Http://www.applianceblog.com/mainforums/whirlpool-kitchenaid/5173-whirlpool-duet-f11-link-repair-manual.html
The above website has all you need to know and a link for a service manual to download.
Below is a DIY self help troubleshooting website. http://www.acmehowto.com/howto/appliance/washer/washer.php
Posted on Aug 04, 2010
I need to reset my Laptop to factory settings.
  • Turn on your computer. If it is on, restart the laptop.
  • Press the "F11" key during the initial boot screen. This works for almost all manufacturers, but the bottom of the screen will tell you what button is needed for System Recovery, so follow the prompt if "F11" does not work.
    Select "Restore my hard drive to factory settings" and click "Start."
    Let the restore finish, and the laptop will boot into Windows when it is finished.
    Mar 16, 2011 | Computers & Internet
    When i try to play online games that require adobe flash player, my computer won't display the whole picture of the game, i can only see about 60% of whats going on.
    Hi
    Have you installed adobe flash player yet
    also if you press F11 it should give you full screen but remember to repress F11 when you finished playing your games
    hope this way helpful
    Dec 10, 2010 | Computers & Internet
    When switching on my dell inspiration2200 laptop on,the dell logo comes on then screen goes blank with small white dash on top left side flashing.have tried ctrl f11 several times
    By pressing ctrl f11 after when the dell logo comes on, it will do a process to return your computer to its factory settings and will delete all the data in your computer. It will be back to the state when you first bought your computer. Just wait a little longer for the process to finish. If after an hour it does not do anything then the process has a problem. You will have to do a clean install. And to do this you need your Operating System install cd.
    Nov 04, 2010 | Dell Inspiron 2200 Notebook
    My washer is flashing F11- it won't finish a cycle- what is the problem?
    F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
    Apr 12, 2010 | Kenmore HE2 Plus Front Load Washer
    My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
    If your lights are flashing, use these codes to pinpoint the error.
    These codes are reading from the top neon down.
    F01....OFF, OFF, OFF, Flash, OFF.
    F02....OFF, OFF, Flash, OFF, OFF.
    F03....OFF, OFF, Flash, Flash, OFF.
    F04....OFF, Flash, OFF, OFF, OFF.
    F05....OFF, Flash, OFF, Flash, OFF.
    F06....OFF, Flash, Flash, OFF, OFF.
    F07....OFF, Flash, Flash, Flash, OFF.
    F08....Flash, OFF, OFF, OFF, OFF.
    F09....Flash, OFF, OFF, Flash, OFF.
    F10....Flash, OFF, Flash, OFF, OFF.
    F11....Flash, OFF, Flash, Flash, OFF.
    F12....Flash, Flash, OFF, OFF, OFF.
    F13....Flash, Flash, OFF, Flash, OFF.
    F14....Flash, Flash, Flash, OFF, OFF.
    F15....Flash, Flash, Flash, Flash, OFF.
    f16....OFF, OFF, OFF, OFF, Flash.
    F17....OFF, OFF, OFF, Flash, Flash.
    F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
    these are the codes and this is what they mean
    f01 light 4, motor triac
    f02 light 3 motor, jammed/ tacho
    f03 lights 3&4 Ntc fault
    f04 light 2. pressure sw stuck on empty
    f05 lights 2&4, pressure sw stuck on full
    f06 lights 2&3, N/A?
    f07 lights 2&3&4 heater relay
    f08 light 1. heater relay
    f09 lights 1&4 eprom/setup error
    f10 lights 1&3, pressure switch not sensing
    f11 lights 1&3&4, pump/draining error
    f12 lights 1&2, communication error
    f13 lights 1&2&4, dryer ntc/ fan motor
    f14 lights 1&2&3, dryer heater
    f15 lights 1&2&3&4, dryer heater relay
    f16 N/A
    f17 light 4, door lock
    f18 light 3 comms error (3 phase motor) power board
    also try checking this manual
    http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
    Mar 05, 2010 | Washing Machines
    Dv6700 boot up problem. power light on. When power on is pressed, the lights in top panel flash once then nothing happens. does not boot. Tried removing battery, reseating RAM nothing worked
    Try taking the sys to the BIOS screen and set the defaults after that if the sys doesnt boot up do a system restore by going into the recovery manager page from F11 key on startup to a date when the sys was working fine. IF that doesnt work try enabling the low resolution mode from the advanced boot options from F8. If this doesnt work out than finally you will have to run recovery on the sys.
    All the best
    Feb 09, 2010 | HP Pavilion dv9000z Notebook
    Trying to do a factory restall of Dell demnension 2400
    typically you don't need to press ctrl at all -- usually f11 does the trick -- or going into accessories and system tools and looking for factory restore or something similar, the program has different names depending on the manufacturer. System Restore will only bring it back to a previous date...
    Jun 26, 2009 | Dell Dimension 2400 PC Desktop
    THe dishwasher will not start.
    what cycles does your dishwasher offer? there is a cancel reset. its usually holding scrub and econo wash at the same time while the power is on will activate the cancel drain mode then reset the dishwasher next time you power it. if that doesnt help then let me know your full model number and i will tell you exactly which buttons to press.
    your model should read:
    SHU66C05UC/??
    what numbers are ??
    Mar 03, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
    Washing Machines Logo
    425 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
