How can i get my laptopto display on my jvc d series tv
  • 12,061 Answers
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket. Also we have "Component Video" marked "Y" "Pb" & "Pr" these simply go color to color at BOTH ends, this is where the Red, Green, & Blues, colored Ends, of the Wires, goes, remembering that this is ALL only Video. With this method, you still must use the AV, red & White, Audio, Inputs to get the "Sound" into the unit
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
http://www.videojug.com/film/how-to-connect-your-laptop-to-your-television
Video how to above. & below.
http://www.ehow.com/how_2377831_use-tv-monitor-laptop.html
Posted on Aug 04, 2010
After changing the display settings to a seond monitor , it now shows the computer screen on the tv but it does not show any icons or any thing im doing on the internet why ?
Right click on the desktop, choose Screen Resolution ans click Detect and Identify - you should then be able to choose the appropriate display and choose the Multiple display settings as required from the drop down list
Apr 11, 2012 | Computers & Internet
No picture,no display ,no raster
hi there! check the following:
interlock switch, power line into the reciever, power line fuse, open heater in series.
Feb 10, 2011 | JVC AV-27230 27" TV
So, i have a ps3 and when i plug in my rca cable in my JVC D series tv it doesnt play the content that is supposed to be displayed on tv's normally. i dont know what to do.
Perhaps the PS3 is stuck in HDMI setting. While the PS3 is off (red light) press and hold the power button for approx. 10-15 seconds. The PS3 will beep and the system settings should reset.
Jan 11, 2011 | JVC Televison & Video
I have just purchased a used JVC D series tv and the screen rolls until tv warms up what can i do to troubleshoot this issue myself?
got a jvc d series floor model projection tv, it turns on but it rolls till it warms up what is the problem...
Oct 01, 2010 | JVC Televison & Video
My tv will not turn on and the on timer light is
Try the following blog. It has detailed instructions on how to fix a common problem on this JVC TV series. I did and I fixed my TV for 2 bucks at home.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 14, 2010 | JVC AV-36950 TV
JVC TV with time displayed and will not turn off.
use your front control button to try to enter yoyr menu settings and if possible turn off display function.
Oct 22, 2008 | JVC AV-27D302 27" TV
JVC D-Series television time display
this question sorry to say is a complete waste of time because you cannot change the display
Feb 16, 2018 | Televison & Video
JVC 27" D series
there is another problem that requires a tv repairmans expertise when the timer light flashes continuosly ,and the power is not restored.
Apr 21, 2008 | JVC AV-27D502 27" TV
Computers & Internet Logo
265 people viewed this question
Alun Cox
David Payne
David Payne
